I am chasing extended memory for my laptop m5200ae it's only got 512mb, how and where can I get an extended memory chip.No one seems to want to help me,or please tell me who I can contact.Yours barry Hovell
    Problem Solver:
  • 19 Answers
I had a good luck finding memory update for my laptop going to crucial.com. Need manufacturer, product line and model.
Posted on Apr 20, 2008
How do I install memory in Acer Aspire 5315-2290? It has 2 512MB in it. I have 1 2G chip. Do I remove both chips? Do I need 2 chips to put back in?
One OR two chips will work, mix or match; however,
Don't mix different "speed" chips.
If all three chips are the same speed/type, PC2-5300? Then you can use the 2GB AND the 512MB together (1.5GB total).
Hope this helps!
Sep 12, 2009 | Acer Aspire 5315 Notebook
Memory upgrade not working
It only Accepts two PC–2100 SDRAM memory modules..If both are same then the slot might have some problem...
Jan 29, 2009 | Gateway 450ROG Notebook
Memory chip set.
If you have overheated the computer you may have already done your damage to the mainboard. It may be time to replace the main board if it has been overheated. The CPU could have been overheated and damaged.
Jan 15, 2009 | Toshiba Satellite P35-S609: Pentium 4-3.2...
IBM ThinkPad T40 2GB Max RAM
The T40 has two ram slots, you can put a 1g chip in each totaling 2g. If the chip will remove, then it is changeable. Vista needs a minimum of 256 to run, so, when you change BOTH chips to equal 2g it will probably read 1.744g, or it may read the full 2g. If it only reads 1g, then the second slot under keyboard may have malfunctioned. It could also be that the 256 chip is bad and your really only running 512 now. With all that said, in order to achieve 2g, you will need to put a 1g chip in each slot.
Jul 08, 2008 | IBM ThinkPad T40 2373 Notebook
Memory upgrade
You have one 256 module built in (non-removable), and one socket for memory expansion (removable chip). It maxes at 1280. Take a look at this link, it will help. http://patriotmem.com/configurator/morepartsp.jsp
Apr 27, 2008 | Gateway 7322GZ Notebook
Problem with amount of RAM.
maybe your video card uses 128mb shared memory so 128 for video plus 640 reading equals 768.
Apr 10, 2008 | HP Compaq Presario V2000 Notebook
Dell Inspiron 1100 does not see new memory
Install one memory first to any of the memory slots and boot your laptop... then do the same on the other slot with the same memory.
Now do the same step to the other memory...
That is to see if any of the two memory has a problem or to see which memory slot has a problem... You should find a problem in there... that would be memory or the memory slot.
Jan 25, 2008 | Dell Inspiron 1100 Notebook
Compaq presario c714nr upgrade memory too 2gb laptop
http://h10032.www1.hp.com/ctg/Manual/c01301275.pdf
Page 43 of this manual seems to have the best documentation on memory for this machine. I saw a 2GB max in another document and this shows the biggest module as 1GB. I would believe that infers a pair.
Dec 18, 2007 | Compaq Presario 700 470024-192 Notebook
Installiing memory in inspiron 1000
You compuer comes with this already installed.
  • 512MB PC2100 DDR Memory
  • You can only install another 512MB total 1G.
    To get into where the chip is should be underneath that laptop secured by two screws.  If you find there is no chip inthere already then all you need to do is place the other chip into the slot.  The first is already in there and to get that you have to go through the removing the keyboard.
    Oct 17, 2007 | Dell Inspiron 1000 Notebook
    HOW TO INSTALL ANOTHER MEMORY STICK
    Most newer laptops have easy access to their memory slots, I'd recommend you got to the manufacturer's website and look for the maximum memory your system will allow. If you look at the bottom side of your laptop, you may see several small covers with just one or two screws in them. One of them will be where the memory slots are. It is not uncommon for the laptop to have a very small 'memory chip' icon on the cover. Be aware that many laptops only support two memory chips, and may have both filled already. For example, if laptop has 512MB memory, it may have two x 256MB chips in it. Which would mean, that to upgrade to 1GB memory, you would have to purchase two x 512MB chips. or one 1GB chip.
    Jul 27, 2007 | Toshiba Satellite L10 Notebook
    Computers & Internet Logo
    73 people viewed this question
    David Payne
    David Payne
