Question about Kitchen Ranges
Maytag stove in lock mode display. Oven wont turn on. Model mer5765raw
  • 247 Answers
SOURCE: Maytag Stove Model MER5570BCW purchased
welocome-
when it says F9 on the screen it means ther is something wrong with the Door Latch - Check door latch, switches and wiring. I would start here first.
thank for using fixya and let me know if you need any more help.
Tom
Posted on Dec 19, 2008
jumptrout51
  • 3361 Answers
SOURCE: maytag stove burners work but oven won't
Check the electronic ignitor. Even if it glows it can be bad eenough not to open the gas valve.
Posted on Mar 24, 2009
SOURCE: F9-6 fault code on maytag gemini double oven range
I waited until the next morning and hit the cancel button. It cleared the error
Posted on Sep 17, 2009
heatman101
  • 43501 Answers
SOURCE: Maytag oven doesn't fire, but stovetop burners work fine
This will sound crazy but I had to work through it on my own stove a few years ago. The ignitor (glow tube) was getting hot but the oven would not owrk. When investigating the problem I found that the gas valve will only open when the ignitor pulls a specific amperage or draw of current. As the ignitor ages it pu;;s a reduced draw of current. This causes you to be fooled by the glow nut no gas. Replace your ignitor and your oven will begin to work again!
You can get ignitors easily online by doing a search for "appliance parts" and then entering the model number of your stove. Look for ignitor and you will be good to go. Also check out a few different sites as the prices of the parts can vary quite a bit.
Posted on Nov 20, 2009
Testimonial: "Thank you very much for your help. I was looking for a thermocouple but that must be old school. I couldn't figure out what told gas to flow."
SOURCE: maytag oven - error message
Thank you so much, u had the same problem and your directions helped me out. Thank you so much!
Posted on Feb 13, 2010
Maytag Oven model MER5755QAQ has lock on the display and the oven will not operate.
If one of the position switches on the latch assembly is not reading, the control will sometimes lock because it "thinks" a clean cycle has been initiated, if replacing the control did not fix the lock icon, test the switch... Incorrect temp probe and thermostat failures can also make a control "think" it is in a clean cycle. Maytag Range Stove Oven Door Lock Motor and Switch Assembly WP74008702 Maytag Range Stove Oven High Limit Thermostat 74008715
Jul 06, 2016 | Maytag Kitchen Ranges
Maytag MER5765RA oven door won't unlock
Seems like you found out the hard way what I wrote about in this tip...
Check it out it also contains some thing to try on how to unlock that oven..
http://www.fixya.com/support/r3969401-self_cleaning_oven_problem
heatman101
Apr 11, 2010 | Maytag MER5765RAW / MER5765RAQ /...
My Maytag Performa oven and stove top will not turn on (heat up)
When I turn on my Maytag performa using the "bake" function, everything looks ok on the display, however the temp. never rises above 100. I've tried "bake" and "convect", and neither one work. "Clean" doesn't work either. The oven will lock, and display shows that it's heating up, but temp. never rises.
However....."broil" feature works just fine.
Please help.
Mar 09, 2010 | Maytag 30" Built-In Single Electric Wall...
We have a maytag gas single oven stove. Where do
Hi.
The beeping sound is a warning because the oven is in lock condition. The oven is not faulty, and the code is not 5AB, but SAB.
SAB means that the oven is in Sabbath mode, and the control board will be locked for 72 hours with SAB on display.
If power is disconnected a new 72 hours cycle will start.
Push and hold the Clock button for about 10 seconds, that will reset SAB mode.
If that does not work leave the oven connected and off for 72 hours. If the oven does not unlock after three days, then the electronic control may be stuck in SAB mode because it is faulty, in that case contact the manufacturer at the number listed on the owners manual.
Regards.
Mar 04, 2010 | Ovens
F1 is displayed on Maytag Electric Oven I ran the self-clean cycle on my Maytag Model MER5530 oven yesterday; before it completed F3 was displayed and beeps sounded. I pressed CANCEL, the F3...
Hi
F1 error means that you have either a bad ERC (clock) or a bad touch pad. To check these please follow these simple instructions:
  1. Disconnect power to stove
  2. Gain access to the back of the clock (electronic range control or ERC).
  3. Unplug the touch pad ribbon connector from the ERC. This will be a flat wire approx. 1 1/2" to 2" wide.
  4. Make sure everything is clear and will not short out when power is turned back on.
  5. Turn power back on to stove.
  6. Watch for the F1 and listen for the beep.
  7. If you get the F1 and beep, replace the ERC.
  8. If after approx. 30 minutes you do NOT get the F1 and hear the beep, replace the touch pad...
thank u
rate me!!!
Aug 14, 2009 | Maytag Ovens
I was setting the clock on my maytag model # PER4311ACW stove/range and then a code "5 A6" popped up on the display and now the oven won't turn on altough the stovetop still works and the display...
If your code is SaB i just did this myself....i accidentally turned on the sabbath mode. I fixed if (after 2 days of trying) by holding down the cancel button for about 5 seconds, and then the clock button for about the same.
Aug 09, 2008 | Maytag PGR5710 Performa Gas Kitchen Range
Oven is locked
press Clean again and add time the quickly open the oven . Before it lockes in clean mode it unlocks soo yea hope this helps.
Feb 22, 2008 | Maytag CWG3600A Gas Single Oven
Maytag top oven lock won't lock
Do you get any error codes? What shows on the display when you try? does it make any noises , like it is trying to lock? Is it a manual lock with a lever?
Jan 19, 2008 | Maytag MER5775Q Electric Kitchen Range
Kitchen Ranges Logo
118 people viewed this question
Top Kitchen Ranges Experts
Oloyede Monsuru
Marvin
Marvin
Paul Carew
Are you a Kitchen Range Expert? Answer questions, earn points and help others
