Back to:
Tags:
JVC AV-48WP30 48 in. Rear Projection Television
Blue, Yellow vertical lines. (by 3 users)
posted by conestoga on Apr 20, 2008
My screen is filled with blue and yellow vertical lines, .25 inch apart. Symptom comes and goes.
I have the same problem.
This Problem has been added to the Share Your Expertise Page under "My Work Queue".
2 Other Users Have The Same Problem
Comment by Guest, posted on May 29, 2008
Blue and yellow vertical lines super imposed on bottom half of picture. Using S-Video or RCA input to a KWorld TVBox WS then into a barco projector via component VGA cable and Hermes controller.
Only occurs when source is DVD player (Pioneer DV-55). Does not occur when using KWorld TVBox WS built in tv tuner.
Comment by Luchini, posted on Apr 27, 2008
conestoga's Blue, Yellow vertical lines will not line up. problem, and Looks like the faces have two sets of eyes. have tried all set ups with the picture
Can you Help with these Projection Televisions problems?
JVC AV-48WP30 48 in. Rear Projection...
the molding is in view when my tv is turned on. its...
differnt colors and double words
I am unable to read the value of resistor R-862 due to...
I have a jvc av 48wp30 rear projection screen television....
everytime when i turn on the TV, i need adjust the...
Loading problems.
Repair Service
Find Projection TV Repairman Near You:
Browse the Repair Directory
Repairman, Get Listed FREE
When the original poster rates a solution that was given to his own problem, that rating is locked!
X
Are you sure the solution content is Inappropriate?
Tech buddies can communicate directly to answer questions. Become a Tech Buddy and have direct access to your favorite expert for FREE!
