Question about Dishwashers
I have a kitchen aid dishwasher. Model KUDA03CTBS3. The unit shuts off before the second wash cycle begins. It does not complete the wash cycle. We replaced the control board already.
  • Dishwashers Master
  • 2,605 Answers
Hello, Welcome to FixYa.
Sorry to hear about your on-going trouble. I would like to start by asking you a question in regards to this problem.
When you state, "The unit shuts off before the second wash cycle begins" and "It does not complete the wash cycle", does the display completely go dead or continue to have L.E.D.`s illuminated and just flashing a clean light or anything of that nature ?
Another question which may seem insignificant...but it isn`t, are you in a rural area or a city/urban dwelling ?
This is what I would be looking for if on site, two things actually.
**turn off the power at the breaker before attempting any service...safety first :o) **
1) the door switch ( there are actually two ) not seating firmly causing the unit to stop intermittently. This is located inside the console next to the control you stated has been replaced. If you are comfortable and knowledgable with electronics, jumper them out and try a test. ( If not, call a pro )
2) the main line/power connection in the junction box under the dishwasher to the left having loose murrets/wire connectors, when it heats up due to "resistance from the amperage/current" the connection becomes so loose it quits. ( too much voltage lost )
I`ll watch for your reply and see what you find. There are other possibilities, always. However, these are the most common for the issue you`re having.
Good luck.
macmarkus :)
Posted on Jul 14, 2010
  • 3 more comments
  • Mark MacDonald
    Mark MacDonald Jul 14, 2010
    CORRECTION : I said "junction box under the dishwasher to the left" when in reality it is to your right...from the front anyway. :P
    Sorry, long day ( that`s my story ) ha ha !
    macmarkus :)
  • Mark MacDonald
    I should add another common occurence with those kitchen-aid dishwasher is related to the door that had totally slipped my mind earlier. During a wash cycle the door can actually get "pushed" open by the wash pressure even just slighlty, hence causing the unit to halt. It is not because of weak springs or hinges or any of those things I've heard being blamed but rather the metal latch that is fastened to the top of the tub...it's flawed/too weak. Replacing it is the only way to remedy the issue to this point according to Whirlpool ( that's who makes them ) but not me. Some have tried bending it down slightly, but that is only a temporary solution. There is also a way using a piece of coat-hanger I use to strengthen the latch ( creating greater downward force ) which makes it harder to open, but prevents it from stopping mid-cycle as well...which is usually a welcome trade off.
    macmarkus :)
  • Greg Smith Jul 14, 2010
    Yes the unit goes dead in the middle of the wash cycle. No lights on the keyboard.
    Don't know for sure its the door latch. What we have to do in order to get this unit to come back on is to unplug the control board completely and plug everything back in. We jump out door switch with no luck.
  • Mark MacDonald
    OK, Based on that info its safe to rule out the switches, the display wouldn`t go completely dead if it was a door opening/switch problem.
    Have you checked the power to the unit at the junction box ? Inspect it thoroughly by physically removing the wire connectors/murrets to inspect the connections for signs of heat or resistance burns.
    The other possible cause could be a severed wire inside the door going to the control. They are prone to getting cut right at the point of bending from the open and closing action...even with the protective covers in place.
    Those are a couple of things I would be looking into, I just don`t see it being a control problem since you`ve stated it`s newly installed.
    Let me know what yoiu find.
    macmarkus :)
Upper drawer dishwasher won't drain
First =check for a plugged drain line
Second = check for plugged screens in the unit.
It could also be your pump. The vanes are only plastic and they sometimes just give out.
Jan 07, 2014 | KitchenAid Kitchen-Aid KUDD03DTSS...
The wash light and the start/cancel button keep flashing. How do I fix it? I have a Kitchen Aide dishwasher model KUDS02FR
The clean light usually will blink due to a failure to heat the water properly. This dishwasher looks for a temperature rise of the water during a heating cycle if it fails to see this rise for multiple cycles it may shut down and blink the clean light.
There are a few things to check before resetting the control.
-The unit not being level so both door switches do not make contact
The sump plugged up so water is not pumping across the heater (see sump clean out below)
- Not enough water filling the dishwasher
- The heat element is not working
To reset the control use this key dance within 5 seconds press:HEATED DRY, NORMAL, HEATED DRY, NORMAL
This will cause you to enter the diagnosis cycle once this is finished or you hit cancel the control should be unlocked and ready to use.
Thank you !
Aug 02, 2010 | KitchenAid 24 in. KUDS02FRSS Stainless...
High pitch whining sound when unit goes into wash or rinse cycle. does not seem to wash well. need to rewash dishes. unit is a kitchen aid model # KUDIO1ILBS6
Hi--  The whining is most likely coming from the motor bearings.  Failure occurs when the seal between the motor and pump begins to leak.  If inspection by flashlight underneath tub reveals the telltale leak by the ---powdery deposits on the lowest part of the motor case,---   then the motor/pump assembly must be replaced. I have replaced well over a hundred of this type motor for exactly this problem.  Therefore, the only solution for the problem is to replace the motor.  The part is about 125$, and is easy to install if you can pull out and re-install the dishwasher.   Please acknowledge this posted solution.  Have all kinds of info on this unit if ya need it.  Thanks-  Ed
Mar 27, 2010 | Dishwashers
My Kitchen Aid dishwasher runs for about 2 hours. Is this normal
It depends on your water pressure. Mine runs a cycle in about 25 minutes, with 92 psi water pressure. Before changing all the pipes in my house, I had about 30 psi and it took about 45 minutes. The longer it takes to fill, the longer it takes to do a wash.
Apr 06, 2009 | KitchenAid 24 in. KUDI01FLSS Stainless...
Kitchen Aid Dishwasher
Hi bluepanther,
I'm Harvey the Master Plumber.
Your problem is: You have a Kitchen Aid Dishwasher that has a light on saying CONTROL LOCK,of which when on you can't do any wash cycles.You tried doing canel out,but no help.What can you do to get off so can use unit?? Is there a reset button underneath that will reset unit.you are very mechanical and can pull unit apart if needed....Thanks Scott
Should not be nessessary. The lock is for keeping playfull little hands from getting into trouble. You must have inadvertently activated it. Try pressing and holding the "heated dry" button. This should deactivate the lock after about six seconds. This same procedure will reactivate it should you feel the need.
Feel free contact me again!
Please give me a rating here at fixya.com before you sign off
Thank you,
Harvey your Master Plumber
Sep 27, 2008 | KitchenAid Dishwashers
Dishwashers Logo
65 people viewed this question
Top Dishwashers Experts
Owen Barnes
