Question about Lanzar Vibe 250 Car Audio Amplifier
Which wire do i hook up i see a gnd power and a 12volt do the battery wire go to the 12volt and the ground wire go to the gnd and power
    Problem Solver:
  • 5 Answers
In your ***
Posted on Jul 14, 2010
How should I hook up a 2000 watt schumacher inverter to a 12volt battery
i normally mount it under my seat run one lead straight to the positive (red) lead of battery with a 30 amp fuse using an inline fuse holder fully sealed.than the ground (black) using a ring connector to the chassis or seat mounting stud.must run positive under carpet and through fire wall using a grommet or other possible wire channels.
Aug 16, 2014 | Schumacher Electronics - Others
How to Replace a p1355 on a 2000 volkswagen new beetle
Is this for a ignition coil output stage open circuit? If so you need to rerun the ground wire. Just but the wire close enough to the coil that you can still get to the wire and splice another wire to it. Just splice a wire to the brown wire and run the rest of the wire to a ground lug under the battery. You will need to remove the battery and the tray. Also when you hook the battery back up make sure the key is on. This will reset alarm and radio. Remember, you are grounding the coil so the wire should go from the coil to ground. Hope this helps
May 29, 2014 | 2000 Volkswagen Beetle
I unpluged my amp from my car and i forgot where all the wires went i need help to hook back up right
There should be a group of screw terminals. They should say pos or (+), remote, and ground, GND, or (-). This is the power terminal. The power from the battery goes to the (+), the remote turn one (thin wire) goes to the one labeled remote (usually inbetween the ground and power wires), and the ground to the (-). RCA jacks should be labeled input and output. Plug the appropriate colors in the input ones. The speaker terminals are labeled left and right + and -. If it is a 4 channel amp, it will also have front and rear. Depending how you wired your speakers is how they will go to the amp. Follow the speaker wires to the appropriate prongs positive or negative. Hope this helps.
Aug 26, 2011 | Crunch Car Audio & Video
Nitro 483 amp where do you hook up the power it has a gnd rmt and +12v what hooks up where
Fused 12 volt power wire from the battery connects to +12V at the amp. Chassis ground wire connects to gnd at the amp. Switched 12 volt power wire (accessory) (remote turn on from after market radio) connects to rmt at the amp.
Jan 18, 2011 | Nitro BMW-483 Car Amp
Have hooked up al conections properly acording to diagams but amp will not pwer up. tested wire conections and i am getting juice to the amp but still no responce fuse are good amp is brand new out the box...
If this is new out of box make sure you have 12volts to the amp turn on wire. You should have constant 12volt + to the battery terminal 12volt- to the ground and 12volt + from the head unit (radio) to the amp The turn on wire on most car stereos is a thin blue wire. run this wire to the amp's terminal and when you turn on the radio the amp should turn on.
Sep 29, 2010 | Pioneer GM-D7400M Car Audio Amplifier
I have the dual xdv8125 car stereo and i hook all the wires up but nothn comes on. its hooked upto a 12volt dc power converter box. it wont do nothing at all.
Make sure that the DC has more than 3/5Amps rating with good DC to make the set working. Test with a car battery to confirm your connection if not check the speaker connections, the main power, switched power and ground must be in order.
Aug 28, 2010 | Dual XDV8125
How to hook up my amp?
first what are u trying to push, second, the amp is 150w rms. that mean constant power, and 250 @ 2 ohms, now you have power, gnd=ground, and remote<- that turns the amp on when you turn on the car, power or the + sign is what gets connected to the battery, then the ground/gnd or - sign is what gets screwed to the metal of the car, then there is the remote this wire gets connected to your radio, or to any accessory fuse, i.e. lighter, radio fuse, or if you have an aftermarket radio, then it gets connected to the blue with white stripe wire, that will be the amp turn on wire.
You will need red wire about 17ft, black wire about 1ft, and 15 to 16 ft of remote wire, or you can just by an amp kit, that will be easier.
now that the amp is done, time to do the speakers;
You have + and - on the amp, and your speakers have the same signs as well, just make sure when you wire the speakers + goes to + and - goes to -. if you need more help call me @ 6314330567
Feb 19, 2010 | Car Audio & Video
I need a installation manual for audiobahn a8002t amp.
very simple run a ground from gnd on amp to a good ground spot on car run 12 volt power cable from back of fuse relay by battery to 12v+ on amp then splice blue wire on back of stereo splice in another wire about seven feet run that to remote on amp then hook up speakers its pretty simple to hook up an amp hope this helps
Apr 18, 2009 | AudioBahn A8002T Car Audio Amplifier
Help
From what did the wire become disconnected (amp, battery, cap...)?
Jun 18, 2008 | Audiofonics ADF-241 Car Audio Amplifier
Lanzar Vibe 250 Car Audio Amplifier Logo
49 people viewed this question
Top Lanzar Car Audio & Video Experts
Chris Ward
Are you a Lanzar Car Audio and Video Expert? Answer questions, earn points and help others
