Question about Gigabyte GA-8I945GZME-RH Motherboard
Micro ATX motherboard ATX case?
I bought a micro ATX motherboard and I have a regular ATX case, it fits but when I hook most of the cables but it does not power on. :'(
This is the motherboard I bought
http://www.gigabyte.com/products/product-page.aspx?pid=2304#ov
Any ideas why it doesn't power on?
  • Gigabyte Master
  • 11,800 Answers
Two possible causes - either you have installed it badly and it shorts to the case (take it out of the case and try it there) or not all the necessary cables were connected (check especially the power cables and the power button).
Posted on Jul 14, 2010
Motherboard Brand and Model Number
This case will fit any motherboard that are Micro ATX or ATX format.
Jul 08, 2014 | Cooler Master (CAC-T05-UW) (CAC-T05-UWA)...
I have an Hp m260n. I just need to find out what type of case it has (ATX or uATX).
http://h10025.www1.hp.com/ewfrf/wc/document?lc=en&cc=us&docname=c00026876
Motherboard: ASUS P4SD Motherboard Specifications
http://h10025.www1.hp.com/ewfrf/wc/document?docname=c00022505&lc=en&cc=us&dlc=en#c00022505_doc
Board Form Factor: uATX
uATX stands for Micro-ATX,
http://en.wikipedia.org/wiki/MicroATX
http://en.wikipedia.org/wiki/Computer_form_factor
http://en.wikipedia.org/wiki/Computer_form_factor#Tabular_information
HOWEVER, the Power Supply is an ATX form factor,
http://www.911forpcs.com/hp-media-center-power-supply.html
,of a sort.
Form Factor related directly to desktop computer Motherboards.
Now has 'evolved' to relate to the computer case, and Power Supply.
When referring to a Power Supply, and the ATX form factor; you are not only referring to the size, and shape of the Power Supply's case; but also the type of power cables used, and the technology used within.
Size and shape of an ATX power supply is approximately;
6 Inches Wide, 5.5 Inches Long, and 3.5 Inches in Height.
(152.39mm Wide, 139.69mm Long, and 88.89mm in Height)
Power cables included with Power Supply's nowadays, will include all the power cables you'll need, with probably some left over.
HOWEVER, looking at the 'ATX' form factor designated for your computer, to wit from the ad above, it does NOT fit the above size, and shape.
More like 6 Inches Wide, 4 Inches Long, and 3.5 Inches in Height.
Looks like they just crammed everything into one small box.
Remove motherboard, and all internal hardware, into a new computer case?
No prob!
Most Mid-Tower to Full Tower size computer cases, will have a Support Plate that accommodates a Micro-ATX form factor motherboard, OR an ATX form factor motherboard.
Just look at the Support Plate mounting holes.
Ones for a Micro-ATX (uATX) motherboard, will have uATX next to them, or MATX, or mATX.
Ones for an ATX motherboard, will have ATX next to them.
However check the computer case manufacturer info to be sure.
[ The motherboard mounts to a Support Plate.
The Support Plate can be an integral part of the metal frame, of the computer case; or a separate metal plate that attaches to the computer case metal frame ]
Not what you had in mind Joel? Post back in a Comment.
Regards,
joecoolvette
Feb 17, 2013 | HP Media Center PC M260n (DF200A#ABA) PC...
Not getting any video from a msi 880gma-e55 integrated video motherboard
This may sound simple, but make sure the monitor is set to correct input. Many are auto detect, but you never really know.
You could also check BIOS for onboard video. Disable if you have an add-on video card. Enable if you don't
Reseat the video card if it an add-on.
Jan 08, 2013 | MSI Computers & Internet
Can a Dell F5949 be replaced with any brand motherboard?
Micro-ATX motherboard to fit your Dell would be difficult to find.
If you find a micro motherboard, check the motherboard mounting holes line up with the Dell's mountng plate.
Jan 22, 2012 | Dell (F5949) Motherboard
My motherboard (an old one) has gone kaput!. It's an Asus P3V 4X. Can I buy a replacement which will fit into my existing casing? My current processor is an Intel Pentium 3.
Yes. That motherboard is a standard size called ATX. Any other ATX or micro-ATX motherboard will fit into your current case.
Aug 03, 2010 | ASUS Computers & Internet
Motherboard replacement
ok it goes with size of board and there will be screw holes under the motherboard and spacers on the holes for yours if it will only fit a micro then youll need to get a micro board if the case has room then you can get a normall size board my advice here tho is to replace the board and the cpu i would get a 775 motherboard with pci e and ddr 2 you can get one from ebay for 35 pounds new and 10 pounds used and you will get a pentum d 820 used for about 10 to 15 pounds its a cheep way to upgrade as this is in my op the best boards around and the cheepist best cpus (you can alsow get micro boards 775 socket like the bio star board ) hope this info is of some use to you
Mar 18, 2010 | Pine Technology XFX MIA78S8209 GeForce...
Will new micro atx boards fit inside of a hp 4550z case?
Yes i think you will be ok as i can see and your old motherboard is microatx but i strongly recommend you to change case because is not only about motherboard.You will need and better and new power supply and if you want to build a good system with air flow for not overheating your new cpu and other hardware i strongly recommend you to change and chassis!!You can find a "nice" case with $50-$70 bucks if you dont want to spend money on case,but you will need power supply for sure
Jan 07, 2010 | HP Computers & Internet
What is Mini Tower ATX Cabinet
A mini tower is a PC desktop case which is approx half the height of a full size desktop tower case. ATX probably refers to a ATX switch mode power supply.
Sep 10, 2009 | ASUS TM-220 (generic) Micro ATX Mini Tower...
Pc tower motherboard upgrade
you can put in any new micro-atx motherboard no problem. I can be 100% sure if the case is Atx full size- best way to check is to see how many pci expansion slots are available at the back of the case. Any Atx case can hold micro-atx mobo's but a micro atx case wont hold atx mobo.
May 27, 2009 | Compaq Presario 5000 PC Desktop
MOTHERBOARDS THAT CAN FIT A ADVENT T9102 CASE
The Advnet case you have is a micro ATX (mATX) case. I would suggest that you purchase an inexpensive ATX size case. You'll have more room to work and the potential for better air flow for cooling.
Feb 01, 2009 | Computers & Internet
Gigabyte GA-8I945GZME-RH Motherboard Logo
74 people viewed this question
Top Gigabyte Computers & Internet Experts
David
David
Alun Cox
Gbenga
Are you a Gigabyte Computer and Internet Expert? Answer questions, earn points and help others
