Question about Acer AL2671W 26 in. LCD Television
Power switch or remote control do not turn on the TV. Sometimes it turns on by pressing the switch or using remote and sometime it does not work at all.
  • 11,361 Answers
Samsung BN59-00849A remote. The Power button will not turn on the TV. It turns off the TV and all other buttons work properly.
Check batteries. Do a Factory reset. Press Menu & then use the arrow keys to navigate. Select the following in order: Support, Enter, Self Diagnosis, Enter, Reset. Enter Security pin as '0000' unless you have changed it. Then select yes & enter. The TV will turn off & restart again & display the Start up screen. if this also doesn't work then you have to contact the TV manufacturer to replace the remote control.
Nov 13, 2016 | Samsung Televison & Video
I have an emish tv box the remote switches it off and on if I press it after about 5 seconds. But if I switch it off with the remote i have to use switch on back of box to switch back on
DIRECTV - Support: Your Remote Control
www.directv.com/DTVAPP/equipment/demoInfo.jsp?assetId...
DIRECTVTrying to get your DIRECTV remote control to work with other devices? ... TV Power On & Off - If your receiver turns off while the TV turns on, press TV Power On ...
Program the remote for your TV - Fiber Help
support.google.com > ... > About the remote control
GoogleThe Google Fiber remote control is not designed to fully control external audio equipment. ... Press and hold the button on the original TV remote that you want to program on the Google Fiber remote. If the learning works, the TV power button on the Google Fiber remote blinks twice ...
Dec 26, 2015 | Televison & Video
TV is on but when is off after sometimes and next time it can't on but it is on sometimes
The cat is not sleeping on the remote by any chance?
My set sometimes does not come on. The reasons generally are:
1) I have turned off the power at the wall.
2) I have not pointed the remote at the TV but rather at the DVD player.
3) Someone pressed DVD on my universal remote and that took it off the control settings for TV.
4) The battery is loose in the remote after someone dropped it.
5) The battery is weak.
6) Someone turned off the TV manually using the switches on the side.
7) The little computer in the TV has become confused by a user trying to switch from channel to channel before each channel is "found" and displayed to screen. You turn it off and back on and proceed slower.
8) The station transmitter is off the air due to power failures.
Aug 26, 2015 | Televison & Video
Why does my t.V keep switching to dvd screen.
TVs turn on in the last screen they were turned off. Try switching screens using the remote control. If the dvd screen keeps coming back, try pressing or tapping on the manual key located on the side or bottom or back of the TV panel. Sometimes this key gets stuck up. If this does not work, try unplugging your home theater and turn on the TV. Most TVs automatically switch to DVD when they sense signal from HDMI cables.
Nov 26, 2014 | Televison & Video
Turn on without remote control
If the TV was switched OFF by remote control for the last time, you can't switch it back ON, without its remote control.
Just try this. Unplug the TV from AC mains wall socket. Wait for at least 5 minutes and plug it back. Switch it ON by its front panel power ON/OFF switch. Just press any button [Ch UP / Ch DN or Vol UP / Vol DN] Sometimes this might turn ON your TV.
Jun 02, 2012 | Televison & Video
Ah59-02342a doesn't control tv anymore
Hi I had exactly the same problem with mine it worked the DVD player fine but not the TV even though previously it had worked both .......... Manual Guide In the manual guide I managed to dig out it says to do the following to set up the remote to work the TV
Press the TV button on the remote
Then whilst holding down the power button you need to enter in the samsung TV codes until your TV turns off (I only got to the first and it did it)
The numbers are 00, 15, 16, 17, 40, 43, 46, 47, 48, 49, 59, 60, 98
Hope this helps
Feb 24, 2012 | Samsung TV Remote Control
Remote control has stopped working.
your remote needs to be put back in TV mode. press the tv button or slide the switch to tv
Apr 07, 2009 | Samsung TV Remote Control
Sky remote wont control on/off , volume, or terrestrial channels
Press tv on the Sky remote
press and hold select and red until the led blinks twice
type in 0 0 6 0
press the power button, if the tv turns off then the press select and the remote should work all the tv functions.
If the tv does not turn off then press tv then the power button and keep doing this until the tv turns off, once it turns off press select and it should work.
If you have any problems let me know
Dazz
Feb 15, 2009 | Samsung LW20M21C 20 in. LCD Television
Wont come on
try pressing one of the number keys instead of the power button on the remote
Sep 06, 2007 | Beko 324250WN 28" TV
Front controls mixed up & remote doesn't work
the channel down button is stuck on, you need to replace this switch internaly to the set.
Nov 14, 2006 | Sony KV-36FS100 36" TV
Acer AL2671W 26 in. LCD Television Logo
241 people viewed this question
Top Acer Televison & Video Experts
Gareth Cockram
Gareth Cockram
Rommel Balcita
Martin Murray
Are you an Acer Televison and Video Expert? Answer questions, earn points and help others
