Question about Microsoft Xbox 360 Console
Overheating issues - Microsoft Xbox 360 Console
  • 23 Answers
Blow out the Xbox 360 with compressed air, buy external fans, but don't buy the "Nyko intercooler" as they have been rumored to have cause problems to the Xbox 360 and void warranty. Your best bet is to buy a cheap office fan and point it at the Xbox to cheap the air flowing. Also if possible, move the Xbox 360 into a open space where it has at least 5 inches of space behind it, and at least 2 or 3 inches of space on either side to keep a nice airflow. Best of luck!
Posted on Jul 14, 2010
  • 206 Answers
Try vacumming out all the fans as this can cause overheating in the Xbox 360 and can eventually become fatal to your xbox
Posted on Jul 13, 2010
    Problem Solver:
  • 7 Answers
Blow it out with air and buy external fans and put on it. You can get external fans for about $10.00 on Ebay.
So my car was started but i forgot it was so i went to start again, then my car starts overheating & and also i had fluid leaking too?
Car not starting or turning over indicates towards multiple possibilities. It can be issue with battery or weak battery. But if battery checks out ok, then it can be starter issue or faulty alternator or problem with low fuel pressure or no spark at spark plugs due to dirty spark plugs or faulty ignition coil or injectors getting cracked or dirty and needs to be cleaned.
To confirm the problem, the basic troubleshooting is required.
Click this link below and follow the troubleshooting:------
http://technoanswers.blogspot.in/2012/02/car-starting-issues.html
For car running hot and overheating issues, I suggest to you go through this help links. Click this link below and go through the troubleshooting procedure to take care of the problems: ----Car runs hot? http://howtobyme.blogspot.com/2011/11/car-runs-hot-in-traffic.html
-----------All types of car overheating problems and troubleshooting?
http://technoanswers.blogspot.com/2011/11/all-types-of-car-overheating-problems.html
Car freeze overnight and started overheating while driving?http://technoanswers.blogspot.com/2012/01/car-freeze-overnight-and-started.html-----------Engine Overheats and heater blowing cold?
http://howtobyme.blogspot.com/2011/11/engine-overheats-and-heater-blowing.html
Car overheats and Air blows hot at idle?
http://howtobyme.blogspot.com/2011/11/car-overheats-and-air-blows-hot-at-idle.html
--------overheating? http://schematicsdiagram.blogspot.com/2011/12/buick-century-overheating.html
----------Car engine Overheats and transmission starts slipping?http://schematicsdiagram.blogspot.com/2011/12/car-engine-overheats-and-transmission.html
----------This details will help.Thanks.
Feb 20, 2012 | 1996 Honda Accord
Overheating after driving three miles
I would replace the thermostat. Its a cheap fix and most likely the issue. If you replace the thermostat and are still overheating then you may have a more serious issue. But going 3 miles and overheating sound like the thermostat is not opening up at operating temperature.
Jan 17, 2011 | 1990 Toyota Corolla
Shuts down not allowing Windows XP to start
If the Computer shuts down automatically, then the issue might usually be due to the overheating issues.
The overheating issues develop, if the Cooling Fan in the Computer is malfunctioning.
The Processors are designed to shut down automatically, if there are any overheating issues.
For such issues, it would be better to get the Unit examined at the Service Center.
Replacing the Cooling Fan should resolve the issue.
Hope this helps.
Jul 07, 2010 | Toshiba Satellite A105 Notebook
Compaq presario m2000 overheating, broken fan.
Overheating issues are considered as safety issues and are take very sincerely by Computer manufacturer. Generally, overheating occurs due to any mechanical fault. So, you may contact the customer service of the Computer manufacturer to get any sort of assistance.
Nov 17, 2009 | Computers & Internet
Overheating
You could have several issues here. A blockage in the radiator, bad coolant temp sensor, (not turning the cooling fan on) a bad cooling fan motor. sounds as if maybe one of these may be your primary issue, and the cause of the overheating that originally caused your head gasket problem. Hope this helps
Aug 22, 2009 | 1998 Volkswagen Beetle
Overheating of razor phone
the v3 is known for battery issues. not charging, not holding charge and overheating. my suggesting is get a different model phone. and stay away from razors. they all have battery issues, I know this from multiple customer razor issues. all battery issues.
Jul 22, 2009 | Motorola Mobility RAZR V3
Try to turn on my ps3,after 2or3 sec it turns off and just blinks
HI, the power unit is experiencing some difficulties due the an overheating issue. if the light is turning yellow at any time, this will confirm a overheating issue. Now, if the light is simply turning red and, powering off then system with a red blink, this will confirm a power unit failure. you will need to replace the power unit in this case.
Contact your nearest Sony repair shop of, contact Sony manufacture for this repair.
NOTE(If its a simple overheating issue, you can purchase a cooling device to heel this issue)
Jul 21, 2009 | Sony Playstation 3 (PS3) Console
Gateway hd1700 monitor cuts out
i have the exact same issue. It's more than likely a problem with overheating the mainboard. My issue only differs in that i reseived mine in this condition.
Nov 19, 2008 | Televison & Video
A new xbox360 it over heated and will not work now
To fix my overheating issue I bought myself an N-ter-Cooler that affixes to the back of my Xbox, giving it more fans and alleviating overheating issues.
Now if you're saying it will not turn on anymore after it overheated once, You should call Microsoft and see if its replaceable under warranty because if thats the case, your X-box is probably beyond repair.
May 16, 2008 | Video Game Consoles & Games
Microsoft Xbox 360 Console Logo
99 people viewed this question
Top Microsoft Video Game Consoles & Games Experts
Martin Murray
Stu Morris K
Are you a Microsoft Video Game Console and Game Expert? Answer questions, earn points and help others
