Question about Sony Grand WEGA KDF-60XS955 60" Rear Projection HDTV
Sony tv blinks 30+ times or once, no picture/no sound, then shuts off
Sony kp-46v25 blinks 30+ times or once, no picture/no sound, then shuts off
tv is more than 4 years old, worked well until it just went black as i was watching tv. no picture/no sound (not even the channel # showing) when i turn it on. it blinks for 30+ times, then shuts off. after that, it'll blink once, then shuts off. i've waited 12 hours and nothing has improved. i appreciate all your help! can this be a quick fix or do i need to invest in a new $ tv. this is a big rear video projector tv and it's hard to move.
thanks,
andy I have the exact same problem above and my tv KDF-60xs955 is about 4 yrs old too. Initially it was sporadic that the tv would shut off (no pic or sound) and the green light would blink 30 times and then the pic would come back on followed by the sound a few secs later. Now the tv doesnt stay on for even a minute and the same exact symptoms occur. Even after the tv comes back on it stsyas on only about a minute and goes through the same symptoms again. At this point you can't even watch tv anymore. Is there a fix to this. There is no code flashing and the red light doesn't even come on; only the green flashing at least 30 times every time. Is it time for a new set or to get sucked in to a service call. Thanks. Tim Carlsen
  • 3,037 Answers
If you are comfortable doing so and have experience with electronics, first try removing the lamp for about a minute or two and then put it back in and see if it works.
If that doesn't work then you will most likely need a new lamp which I can help you with a number from where you can order one.
If you have any further questions please let me know
Thank you for using Fixya and Good Luck.
(Please always be careful when working on electronics)
Posted on Apr 20, 2008
  • Benjamin Patri
    Benjamin Patri Apr 24, 2008
    Please don't forget to rate this solution as that is one of the biggest aspects of all this website works
    otherwise please let me know if you have further questions
    Thank you
    Genius:
  • 1,142 Answers
May i please know the model and the make of the product in details so that it can help me resolving the issue is a more prompt manner
  • 1 more comment
  • Maanita Chadha
    Maanita Chadha Apr 20, 2008
    sounds like a problem in the stand by power supply as the Set is not blinking any code
    indicating its in protective shut down. I would assume its one of the
    low voltage regulators that has shorted. You would need a service
    manual to actually troubleshoot the start up and standby voltages. Let
    me know if you would like a link where to purchase the manual. I will
    post a link that provide free tech assistance to help diagnose and
    repair your set when you get a manual.
  • Maanita Chadha
    Unless you can do tv
    repair your set has more wrong with it then something minor,it more
    then likely has a shorted Hori out put transistor NTE2973 and maybe
    open pico fuses.Take set to repair shop.
  • Maanita Chadha
    the timer/standby indicator blinks for about 30 seconds then goes to the self-diagnosis function. Something is wrong with the video.
    Check video out, Q705, 732, 761 and other components on the C board,
    also check Q218, 219, 220 on the A board. Also unit be in IK blanking,
    try turning up screen slightly."
    So what is the AKB? It is Auto
    Kine Bias; a circuit that holds the video OFF until the picture tube
    (kinescope) is warm enough to run video. So, if there is trouble within
    the AKB it may not be turning on the crt. Or, the crt could be cold, or
    there could be power supply problems (which I favor because the audio
    is gone, too, which means it is not a "video only" matter).
    Therefore, I do not favor replacing the C board (or A board as indicated in the url above). I favor finding out why the AKB circuit is not functioning.
    It is necessary to get the set to come ON long enough to make sure the
    crt is heating up. You may have to manually defeat the protection
    circuit and force the set to come ON. If you can find the ON relay you
    may be able to hold it ON manually - at least long enough to find out
    more symptoms, but not too long or some further damage may occur.
    Go to: http://www.schematicsforfree.com/archive... where you may find a schematic or service manual for this set - or one that is close/similar enough to be of great value.
    Last comment: Some sets will, upon failure of the AKB function, after a few seconds, go into diagnostics
    - which is similar to protection. So, the audio may be working okey.
    Turn the set on with the volume up; if you hear audio for the until the
    set cycles into the flashing light routine it means the audio is really
    good. So, check that carefully. You may have to do a hard reset to
    cause the AKB function to reset. So, do this: Unplug the power cord for
    4 hours or more. That will reset everything.
I have a 51 in. Sony model kp-51ws520. when I turn tv on I get sound by no picture. Standby light blinks 5 times then shuts off . If I power it back on, sound no picture then standby blinks 10 times after...
Ck small blue capacitor next to hori output Transistor 2k volts they have been known to go Bad, if its OK replace Both of your STK ICs STK392-110s use 180s Mats has them 1-800-628-1118
Mar 23, 2010 | Sony KP-51WS520 51" Rear Projection...
My sony KP-51HW40 TV shuts off
the eight blinks indicates you have a high voltage error. you will need to replace the d board. the part number is A-1348-038-A.
Oct 30, 2007 | Sony KP-51HW40 51" Rear Projection...
Sony big screen t.v. Model # KP-46v25 S/N 9002622 on turn on there is no picture, just the standby light blinks...
Yes I did fix the problem which was complicated! I will tell you how I did it for 14.99 satisfaction or your money back!
Thank-you
Travis
Sep 22, 2008 | Televison & Video
Six (6) blinks on the Timer/Standby led
6 blinks means lamp thermal fuse blowing, replace thermal fuse.
See here
Aug 30, 2008 | Sony KP-57WS500 57" Rear Projection...
No picture sound is fine
tv comes on then turns blue at that time it shuts down. The power is on and then it blinks 5 times!!!
Apr 27, 2008 | Sony KP-65WS500 65" Rear Projection...
sounds like a problem in the stand by power supply as the Set is not blinking any code indicating its in protective shut down. I would assume its one of the low voltage regulators that has shorted. You would need a service manual to actually troubleshoot the start up and stanby voltages. Let me know if you would like a link where to purchase the manual. I will post a link that provide free tech assistance to help diagnose and repair your set when you get a manual.
Mar 27, 2008 | Televison & Video
KP-46S4U lose picture after a few second blink of brightness
does the from led blink if so how mant times pause then blink again?
Feb 12, 2008 | Sony KP-48S65 48" Rear Projection...
Tv turns self off when turned on
Does it blink a certain amount of blinks pause a second or just blink constantly with no pauses? Let me know it will blink a code if its going into protected shutdown. And it will blink constantly for another reason.
Jan 22, 2008 | Sony KP-53HS30 53" Rear Projection...
Sony kp-53hs10
does the timer light blink? how many times pause then blink again?
Dec 07, 2007 | Sony KP-53HS10 TV
Sony KP-FX432M91 TV 10 blinks
my sony kp-fx432m91 has a 10 blinks problem. it has no pictures but has sound that goes off after 5 seconds please advice on what to do.
my email address is drbonnyb@yahoo.com
Oct 31, 2007 | Sony KP-FX532M91 TV
Sony Grand WEGA KDF-60XS955 60" Rear Projection HDTV Logo
116 people viewed this question
Top Sony Televison & Video Experts
Are you a Sony Televison and Video Expert? Answer questions, earn points and help others
