Question about New Home 2014LE Mechanical Sewing Machine
New Home Model NH 2014lLE. Stopped working
New Home Model NH 2014LE. Starting using machine today. Sewed about 2 inches, went to reverse, machine stopped working. Cleaned everything, turned off machine, still doesn't work.
    Problem Solver:
  • 6 Answers
Something is jammed further then you can see. stop. be patient here. if unplugging and plugging it back on does not fix. just take a deep breath, you do not want it to break. its just a machine. i would suggest taking it to a shop to see if they can clear your jam by an adjustment, for free at your local store. or a tune up of $50.00 bucks . this machine is well worth it! its a bizarre thing that has happened, but to force it you could really hurt it more then you know.
Posted on Aug 26, 2010
Singer Touch-tronic 2000 makes loud humming/buzzing noise, stitch selector lights quit working, needle bar stopped moving.
Sounds like you've got a thread jam going on in the bobbin case area. Good cleaning and a new needle will probably fix it. See: https://answers.yahoo.com/question/index?qid=20091202121550AAHxN8y
Apr 20, 2014 | Sewing Machines
Foot pedal not working
yes, it is possible that the foot pedal can go out,, it would be a good
idea to have the foot pedal checked at a repair shop to see for
sure
Aug 27, 2012 | PfaFF Tiptronic 2040
New sewing machine is squeaking
YOu may have bent the needle. Put in a new needle and re-thread the whole machine. See if that works.
Jun 28, 2010 | Husqvarna Viking 1
The top thread keeps breaking off on my NH 2014 LE
i have the same machine, what do you mean the top thread is breaking off? exactly where do you see it breaking off. is your tension soo tight that it breaks? is your thread soo old that it breaks? explain a bit more.
Jun 18, 2010 | New Home 2014LE Mechanical Sewing Machine
Janome New Home mx3123 reverse button not working
1/28/13 - I have Janome Harmony 2049 that was initially sewing forward with no reverse and then after about 12 inches of sewing would ONLY sew in reverse. After spending an hour getting the plastic housing off...I was able to locate the shaft that made the reverse. It needed lubrication and after working it in and unjamming the part from the down position, the forward and reverse now work!
Huh, right? Hope it continues to work well. It is a smooth running machine, otherwise. Good luck!
Apr 05, 2010 | New Home MX-3123 Computerized Sewing...
Handwheel won't turn, take-up lever not accessable
Make sure the bobbin winding settings are "in-active" - this could be the position of the pin for the bobbin or the center knob on the handwheel, depending on the model you have.
Open the throat plate and bobbin case to be sure there aren't any threads tangled there. This can stop the handwheel from turning.
Feb 23, 2010 | Brother Sewing Machines
Threading a bobbin on the new home 2014le
place spool of thread in , route it towards your bobbin holder, take thread and put through one hole about 4 inches hanging ontop. press it in and slide it to the right where you hear a click, hit the peddle, should be winding, it will automatically stop on its own when full. click it to the left when done, snip it and then drop that into your bobbin holder , cover your plate, thread your upper thread and presto you are now sewing with your threaded bobbin, always remember these steps. #1 material choice #2 thread weight #3 needle size. you got to match those 3 for beautiful perfect stitches.
Dec 16, 2009 | New Home 2014LE Mechanical Sewing Machine
Started sewing backwards now not moving material at all
Sounds like the machine's age is causing the lubrication to get sticky.
Try changing the pattern by moving the pattern selector around.
Take out the bobbin and remove the thread and presser foot, raise the presser lever, set the pattern to zig zag, set the stitch length to maximum and run the machine at full speed. While it's running, repeatedly press the reverse lever all the way down. Run it for at least a few minutes.
Nov 14, 2009 | New Home MX-3123 Computerized Sewing...
STITCHES BACKWARDS SINCE I OILED IT YESTERDAY!!
Sounds like the reverse mechanism has jammed...either with lint or lack of use and oil/lint has frozen the mechanism.
Unplug the machine and remove the base. Clean all the lint with small brush and vacuum.
Try the reverse lever to see where the connecting rods are and identify the collar around the bottom shaft....try to move manually, use a little lubricant where the collar moves on the shaft.
In extreme cases it may take several applications over several days to rectify this.
Please don't use all capitals when typing, it is the online version of shouting, and is difficult to read.
Aug 01, 2009 | Sewing Machines
New Home 2014LE Mechanical Sewing Machine Logo
88 people viewed this question
Top New Home Sewing Machines Experts
Tally Girl
Tally Girl
Nava Hirshenson
Nava Hirshenson
Level 1 Expert
Are you a New Home Sewing Machine Expert? Answer questions, earn points and help others
