Question about Maytag 24" Built-In Single Gas Wall Oven - Stainless-Steel
Maytag 30" PGR571DBDQ stove. Oventook over 30 minutes to reach 350 degrees
  • Maytag Master
  • 43,501 Answers
If your electricMaytag 30 - 2_bing.gif oven is not heating then you probably have a bad heating lelement in your oven. This is not that hard to fix yourself...
Check out this tip that I wrote about the Oven not heating problem..
Oven Problems Electric Oven is Heating Slowly or Poorly
http://www.fixya.com/support/r4511800-oven_problems_electric_oven_heating
heatman101
Posted on Jul 18, 2010
Oven shuts down before reaching correct temperature
You will need to check the oven calibration using a thermocouple based thermometer(the one you stick in the oven is not reliable). Electric ovens should keep a near constant tempature so if you have it set to 350 the oven should stay around 350 once temp is reached. Now gas ovens are a little different. Most use a on/off thermostat and that means the temp can vary from 320 degrees to 370 degrees to keep an average tempature of 350. So if it is a gas oven you will need to let it warm-up for 10 minutes then start taking the lowest and highest 5 consectutive readings. Then add the 5 reads together and then divide the number by 5 and it should be within 10 degrees of the set tempature. If it is off by more than 50 degrees then you might not be able to get it back to proper calibration. The calibration methods are different for each range and depend on the type of thermostat you have digital(push button controls) or manual(knob). The owner's manual for your range might contain the instructions or consult the manufacture's website for the instructions.
Dec 21, 2009 | Whirlpool Ovens
Oven does not reach full temperature
Are you checking with a store bought thermometer or your recipe. If it is your recipe then ur thermostat might need a calibration or need to be changed completely if it is really off by more than 100 degrees. If it is 99 or less a simple calibration may just do it. If you have a steady hand. With your thermometer inside the oven and the door closed set at 350. Then take the oven knob off and take a small flat screw driver (really small). And insert it in the valve part where the knob was. With a flash light u can see the small screw. Turn it a hair at a time (1-2mm). Wait 20 minutes and see if the temp does rise. If not turn another hair. Repeat until 350 is reached. You must wait the 20-30 minutes for it to reach the temp. If all else fails changing the thermostat would be next. I do not recommend u do this alone. approx cost is: $400 - 500 front access, 500 - 600 rear access Good luck.
Sep 04, 2009 | Viking Ovens
F1 when bake on oven is 350 degrees.
You also have a defective electronic control. Replace the clock.
Aug 30, 2009 | Frigidaire 30" Self-Cleaning Freestanding...
Maytag oven needs temp calibration
Take your temp knob off and look in the center of the stem and you should find a small set screw. Using a small precision screwdriver, turn the screw until you see the light come on. (You won't have to turn it far.) Turn it a little at a time, maybe a 1/16 of a turn. Leave your thermometer in the oven with the door closed and at or near the temp probe that is in the oven. This way, you are getting a true reading.
Dec 30, 2008 | Maytag CWE4800A Electric Single Oven
Oven only reaches temp of 220 degrees.
meter the electric-220 metering the positives...110 metering 1 positive & ground at a time...Ohm the element if shows open(10 dollar multimeter doesn't move) then is bad.Can be reached from the back just above where the power attaches,for safety disconect the power
Jul 22, 2008 | Maytag 30 in. Electric Single Wall Oven...
Kenmore electric oven
Sears Kenmore Electric Wall OVen, Mod.#9114012192 purchased in 1993. Set oven for 425 degrees, reaches set temperature, stays on about 10 minutes and temp. display goes out and oven starts cooling down. Will not stay on desired temp.to cook. Can you tell me what my problem is? Thanks. Doug.
Dec 02, 2007 | Ovens
Maytag 24" Built-In Single Gas Wall Oven - Stainless-Steel Logo
163 people viewed this question
Top Maytag Ovens Experts
Dan Webster
Dan Webster
 Fix Your Board
Fix Your Board
Mack Baxter
Are you a Maytag Oven Expert? Answer questions, earn points and help others
