Question about Ryobi 18v Variable Speed Impact Driver Zrp230
Bit stuck in drill
Drill bit is stuck in drill
  • 6,826 Answers
OK, try to grab the chuck tightener and loosen by pressing lightly on the drill throttle button in whichever direction it takes to undo the stuck in drill bit.
I do this all the time.
Posted on Jul 13, 2010
comax
  • 154 Answers
SOURCE: Bit stuck in Bosch PS20 keyless chuck
These units have only been out for a short while and most are on warranty. Take it to a Bosch Service center in your area and they will replace the front of the unit. Unfortunatly this is a problem with this type of unit. The bit will deform slightly from the impacting action and lock itself in the chuck.
Posted on Apr 13, 2009
  • 9 Answers
SOURCE: drill bit is stuck inside my makita drill chuck
Try using the low torque setting on the drill when reversing and something to assist you getting a better grip to hold the chuck from spinning when reversing. This may help.
Good Luck
Posted on Dec 04, 2008
SOURCE: makita 6222D hole drill bit is stuck
When this happened to me I held the shaft of the drill bit tightly with my hand and reversed the direction of drive for an instant. It released at that point. It still does that occassionally though.
Posted on Feb 22, 2008
meleemore
  • 19 Answers
SOURCE: sds drill stuck in chuck
tap it lightly with a ball pin hammer, if that dosnt shake it out try opening it and useing something to push it through
Posted on May 05, 2009
  • 10865 Answers
SOURCE: A bit is stuck in the chuck of my Bosch drill
Hello. Wrap a towel around the chuck and use a pipe wrench or a pair of channel locks to put a little force on the chuck. J.
Posted on Jul 19, 2010
How do I take out a 5/8 auger bit that is stuck in a railroad tie? The drill won't move it ahead or in reverse.
Hey Doreen,
First, remove the stuck drill bit from the drill... You can drill "relief" holes around the stuck drill bit in a circle (use a 3/8" bit) and drill about 6-8 holes deep and close to the stuck bit.. this will relieve the tension on it and you should be able to wiggle the stuck bit carefully (don't break it) until it pulls out.
Jun 26, 2017 | Drills
Ryobi 18v drill stuck chuck
easy to fix
with the drill not running
grab the bottom part of the spinning part of the drill nearest the drill's motor.
then
grab the spinning shaft bit nearest the drill bit
pull them apart slightly
when the two parts are pushed together thay lock the chuck
I own a ryobi hammer drill that does the same thing
Mar 13, 2015 | Ryobi 18v Cordless Drill - P206 18 Volt V
Drill bit stuck in ryobi impact drill
Put the bit in a vise and try to turn the drill to release the bit. You will need to put a wrench on the area of the drill that's holding the bit and do the turning by the wrench.
Jan 12, 2015 | Ryobi Drills
How to remove bit stuck in kango drill
Hello, You might try spraying some wd-40 in the chuck to let soak and loosen up, to be able to turn and remove the bit.
May 15, 2014 | Drills
Ryobi 18v drill keyless chuck stuck
Try holding the bit in a vice and gently tap the chuck off of the bit and see it it releases the pressure on the jaws.
Jun 20, 2012 | Ryobi 18v Cordless Drill - P206 18 Volt V
My bit in my drill is stuck into a large tree stump... that had been cut close to the ground. How can I get the bit unstuck? My dewalt drill is unable to drill in & drill out.
If it's a twist bit try putting a vice-grip pliers on the end and turn it so the fluting pushes the bit out. If it won't move or if it's a spade bit you'll have to split the wood around the bit. You may or may not be able to do this with the offending part of the stump in the ground. Using a wedge, drive it into the stump near but not next to the bit so you don't damage the bit. Don't drive the wedge flush into the stump or you may get the bit out and then have the wedge stuck. Worst case, carefully use a chainsaw to cut out the stump so you can split the wood around the bit.
Feb 01, 2012 | American Tool 6 each: Irwin Metal Drilling...
I have a drill bit stuck in the head. I put the bit straight in and now its stuck. Is there anyway to take it out?
Grab the drill head as hard as you can put the drill on drill setting and the highest number setting and put it reverse
Jun 09, 2011 | Dewalt DC920KA Heavy Duty Xrp 18V Cordless...
Jul 19, 2010 | Bosch Drills
Drill bit is stuck inside my makita drill chuck
Good Luck
Dec 02, 2008 | Drills
Ryobi 18v Variable Speed Impact Driver Zrp230 Logo
1,609 people viewed this question
Top Ryobi Drills Experts
JOHN LAPIER
Are you a Ryobi Drill Expert? Answer questions, earn points and help others
