Question about Frigidaire GLRS264ZA Side by Side Refrigerator
My indoor ice despencer and water have stopped working why is this?
You might need to replace the water filter
Posted on Aug 07, 2010
Ge side by side ice maker not filling up
most of the time when that happens first thing you do is make sure water is getting to the solenoid for the ice maker if you have a water despencer you have water the solenoid for the ice maker is normally found in the back of frig near bottom pull frig out till you can get behind it look where water line goes into the frig solenoids for water and ice maker should be there. leave frig plugged up have someone use the water despencer feel whitch one that is replace the other one
Aug 20, 2014 | GE Refrigerators
The ice in the tray melts and runs out the despencer outlet.\r\nMakes ice but the front part of the ice tray slowly melts and water runs out the despencer outlet. Have had service man work on it four...
Your freezer temperature is not coldenough, inspect for hardness of frozen foods. Make sure that the temperature is 5 degrees Fahrenheit or lower. Carefully feel the side of the ice maker if itis warm the unit is stuck in heat for release mode. Check and replace control module.Call repairman to check this.
Thanks
Feb 05, 2011 | Electrolux Refrigerators
Hotpoint refridger ice maker not despencing ice or water
my ice maker stop making ice there is ice cubes in the tray but the ice maker does not dispence the ice
Apr 04, 2010 | Hotpoint HSS25GFP Side by Side...
WHIRLPOOL ICEMAKER DESPENCER STOPPED WORKING.
It is either the motor going bad or the switch at the ice lever. The little micro switch that is activated by the ice lever is likely held in place by two little, week, plastic pins. They break easily. After one pin breaks, the switch can still be close by the lever, but it is hit and miss. It is a ****** to replace the bracket unless you have some experiance. One other long shot would be the freezer door light switch that shuts power off to the dispenser when the door is open.
Apr 15, 2009 | Whirlpool 25.6 cu. ft. Side-by-Side...
Water Despencer
there is two solinoids in the rear of the fridge one is for ice and the other for water . each has a seperate screen . also if you activate the water you should hear a click sound from the solinoid behind. the switch in the door can be mechanical or light sensor . i have changed both kinds before. hope this helps
Sep 08, 2008 | Whirlpool GS6NBEXR Side by Side...
Ice despencer won't make ice any more
Is it the despencer or the icemaker which thing showing the problem makes a difference to giving you info on the repair.
Jan 31, 2008 | Whirlpool GS6NBEXR Side by Side...
Kenmore Refrigerator stopped dispensing water
Look up through the ice despencer on the front door of the freezer. Is the flapper door open? If so it needs to be fixed. If its not then try leaving the freezer door open for 3+ hours to defrost the frozen line in the door. If that doesnt work, the water valve must be changed.(located behind fridge, take off back cord board panel at bottom, the valve is blue)... GOODLUCK!
Dec 31, 2007 | Refrigerators
Frigidaire GLRS264ZA Side by Side Refrigerator Logo
62 people viewed this question
Top Frigidaire Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
Dan Webster
Dan Webster
Are you a Frigidaire Refrigerator Expert? Answer questions, earn points and help others
