Question about LG 42LC2D 42 in. LCD HDTV
The tv only stay in standby but it woun't work and the led blue keep on turnig on and off.
  • 11,361 Answers
Tv keeps switching to standby
Main digital board fault. Check and replace it. If you wish to get more details visit the site linked here. http://electronicshelponline.blogspot.com/
Feb 17, 2017 | Televison & Video
Tip
Error code by led indicator samsung SP67L6HX1X
<img src="mas_baz.jpg" /><br />There are three LED indicators. LAMP, TIMER, STANDBY/TEMP. Each Led or combination leds indicated problem.<br /> <ul> <li>LAMP blinking : The picture will automatically appear in about 15 seconds.</li> <li>TIMER and STANDBY/TEMP blinking : A cooling fan inside the set is not operating normally.</li> <li>LAMP and STANDBY/TEMP blinking : Lamp cover on the rear of the set is not properly shut.</li> <li>STANDBY/TEMP blinking : Check if the ventilation hole on the rear of the set is blocked, because if the inner temperature is too high, the power will shut off.</li> <li>All LED blinking : Lamp may be defective.<br /></li></ul>It takes about 30 seconds for the TV to warm up, so normal brightness may not appear immediately. The TV has a fan to keep the inside lamp from overheating. You'll occasionally hear it working.<br /><br /><br />
on Mar 29, 2011 | Samsung HL-R6167W 61" HDTV
The blue standby light on my bush 19" lcd tv stays on all the time but i get no picture or sound can you help.
The II2 Bus has the fault. It detects some malfunction from other circuit boards. Your TV need a through checkup. Contact any experienced service technician, as the work is a very skilled one, and not a user reparable.
Jan 05, 2013 | Televison & Video
How to Unlock panel Key skyworth LED TV Model 32E65
I accedintaly turn on the disabled panel and i turn the skyworth 19e20 led tv plug out from outlet and when i plug it back the tv stay in standby mode, the remote control is not working, the panel also not working, i read few guid still not working, nothing is working. The tv is working properly its just the panel and the standby where remote cant bypas. Please help my dad will going to kill me.
Dec 26, 2012 | Televison & Video
32 inch, hannspree tv.1080P I need code to get my sky remote to work.
1) Switch on the TV set
2) Press the TV button on the Sky Remote
3) Hold down the select and red buttons for 2-3 seconds until the LED blinks twice
4) Press the TV button on the Sky Remote again
5) Enter the 4 digit code for your make of TV (try 0206)
6) The LED should blink twice, if not recheck the 4 digit code used and go back to 1
7) Press the standby button on the Sky Remote (The TV should go to standby)
8) Press select to store this setting If the TV does not go into standby press the TV button then the standby button, then TV then standby, keep repeating this until successful. This will scan the codes used for a particular make of TV.
Mar 15, 2011 | Hannspree XV32 32 in. LCD Television
I have a 56" samsung rear projection tv that won't turn on. the red standby light is lit and when i push the power i hear two clicks and the green timer light flashes quickly then the green led stays lit...
I suspect you probably have a bad LED assembly. It could be either the red, green or blue that is bad and give you the same symptom. The problem is locating parts for it as it looks like the light engine is no longer available. I would have a technician look at the TV to verify this and what parts are needed for repair.
Nov 03, 2009 | Samsung HL-S5679W 56" HDTV
Sony KP-65WS500 65 in.
Check your CRT boards on the end of the tubes for burn spots, and burnt components, check the resistors to make sure they are not shorted, burnt, and they read the correct resistance. Check the diodes to make sure they conduct in one direction only and are not shorted or open.
Mar 24, 2017 | Sony KP-65WS500 65" Rear Projection...
Bad picture color. red LED blinks 5 times. Replace picture tube?
Definitely bad picture tube==not worth fixing......T.
Oct 11, 2007 | Sony KV-36FS16 36" TV
LG 42LC2D 42 in. LCD HDTV Logo
89 people viewed this question
Steve Allison
Steve Allison
