Question about LG KS360 QWERTY Keyboard Phone BRAND FREE10 TOP UP
How do i change my lg ks360 phone number to private
5 Suggested Answers
SOURCE: Accessing Voicemail on LG KS360?
I had the same problem and I read the post from
Z1G ZA9, and that solved my problem. To give you step by step, because i had to search thru the fone and find the DTMF option, so here it is, and again a big thanks to Z1G ZA9. 1.press menu button 2.select "settings" 3.select "call" 4.scroll to bottom and select "send dtmf tones" and make sure they are on.
Posted on May 29, 2009
  • 37 Answers
SOURCE: I have put a pin number on my LG KS360 and I have
Contact your service provider and they can provide you with a code to bypass this lock.
Posted on Jan 19, 2010
  • 5 Answers
SOURCE: how to make the LG KS360 fully touch screen
What is inrt file settings, and how do you acces them?
And where do you find your serial code and Pg number?
Pleas help!!!!! i really want this!
Posted on Feb 21, 2010
  • 3 Answers
SOURCE: KS360 QWERTY Keyboard Phone BRAND FREE10 TOP UP: my lg ks360 freezes and none of the keys are activ...
Remove your memory card, if it stops freezing, the card's your problem. Either the card is not compatible (more than 4gb or SDHC instead of SD), or the phone is referring to the card during normal operations eg wallpaper, ringtones etc. Copy these "operational" files to the phone and only use the card for storage of pictures, music etc, but not for anything the phone uses regularly. If the problem persists after you've taken the card out, sorry can't help...
Posted on May 05, 2011
I need FREE unlocking code for my LG KS360 please help i type in 2945#*71001# but then it says password! What is the password????
My friend, no free unlock code in this world even you asking directly from your network provider, they still take a charge from you. Are you sure following the correct step when entering your LG KS360 unlock code in your phones? Since after you type 2945#*71001# you just need Go to "Menu" and then to "Settings". Try to input that lg unlock code from first step and pay attention when you following unlock code instruction step by step.
May 18, 2011 | LG KS360 QWERTY Keyboard Phone BRAND...
Hi! I have a LG KS360! Every incoming calls are displayed as "Unknown number", even people I have in my contact list! What happened? It used to work properly and I didn't change any...
hi friend, this problem occurred becoz, you have saved same number two time in our phone. one is saved as person name other one saved as unknown name. so, please delete your unknown numbers. it will work properly.
Regards: Rakesh
Jan 31, 2011 | LG KS360 QWERTY Keyboard Phone BRAND...
Pls help me with unblocking my phone i forgot my security code for my lg ks360, imei number is 352074-03-335847-3 my number 0727465914
Hi
Every phone has its own unique unlock code, based on the IMEI number. No one cangive you the unlock code, unless they have the IMEI number of your phone. You may call the network provider to get the LG KS360 QWERTY Unlock Code or buy one from third parties.I suggest you the LG Unlock Code site,they have the lowest rate and fast turn around.
Hope this will help.
Thanks.
Nov 29, 2010 | LG KS360 QWERTY Keyboard Phone BRAND...
I need the password for unlocking a ks360
You aren't going to find a free code anywhere online. Check out eBay or an unlocking website such as unlocktycoon.com. They had my Blackberry unlocked in under 5 minutes and answered the question I had almost immediately. Hope that helps!
Apr 03, 2010 | LG KS360 QWERTY Keyboard Phone BRAND...
Lgks360 free sim unlocking codes
Hello.
You can unlock your phone by simplyenter unlock code through keypad.
You can get unlock code at cheapest rate byBlackberry unlock code provider.
I hope this
unlock code provider helps you a lotto solve your problem.
Thanks
Feb 27, 2010 | LG KS360 QWERTY Keyboard Phone BRAND...
Whenever someone calls me the number comes up as private/unknown, even though all the numbers are saved in my contacts list. The contacts are saved on the phone and sim, so it's not that. I have tried to...
It might be that your correspondents have blocked their numbers. Other than that, it could be a mal function with the telephone. Please contact your service provider.
Thanks for your question
Jan 06, 2010 | LG KS360 QWERTY Keyboard Phone BRAND...
I need the pairing code for LG KS360
The default pin code for most devices, especially headsets, is 0000 unless it was changed.
You should be able to go into the bluetooth settings on each phone, and find the security code there, or at least change it.
Sep 15, 2009 | LG KS360 QWERTY Keyboard Phone BRAND...
Whats the code to unlock a LG KS360 if it is with
- power phone ON with original SIM
- type 2945#*71001# to enter unlock menu
- enter unlock code
The unlock code is usually based on IMEI number of the phone, once you get the code this is the procedure to Enter the unlock code into the phone
Aug 18, 2009 | LG KS360 QWERTY Keyboard Phone BRAND...
Unlocking my phone
I was beginning to think there was no one else from the UK on here :) lol
Here goes, beware its complicated and you can mess up your phone :)
This works without uploading anything to the phone. Just follow the instructions carefully.
You will need 4 bits of software to perform the unlock - get them all now
Download the USB flash loader driver here go the the download USB driver section and find the KS360 United Kingdom Driver.
http://uk.lgmobile.com/web/web.product.manualSoftwareRF.laf
Download the Orange Firmware here (it doesn't matter if you are onOrange or not - it does not get uploaded to the phone, it is justrequired to make the following software work).
http://ks360.assembla.com/wiki/show/ks360/Liens_LG
Download the Extract program here
http://www.pb4kn.co.uk/extract.zip
Download the LG Utils zip file at the top of the list here
http://www.assembla.com/spaces/ks360/documents?c=documents.updated_at&d=down&page=1
You will also need the USB cable which came with the phone - but don't plug it in yet.
Youshould also make sure you have saved all your phone numbers just incase - I have carried this out several times without any problems, butyou can never be too careful.
Follow these instructions very carefully:
1. Install the USB flash loader software (contained in a folder in the first download above)
2. Switch off the phone and leave it off. Do not switch it on until you complete step 14.
3. Plug the USB cable in the computer and phone - wait for it to install all the drivers loaded at step 1
4. Unplug the phone and leave it switched off
5. Create a new folder on your computer (I suggest c:ks360)
6. Double click the Orange Firmware cab file downloaded earlier
7.Select all the files in the cab file. Copy and paste them in the folderc:ks360 - you will need to click save file a number of times.
8. Unzip and run the extract program downloaded earlier
o Type c:ks360Inf_WebDnld.dll and press enter
o Type c:ks360V10G.wdb and press enter
o Type V10G_04 and press enter
o Press enter (and wait a few moments)
9. In the folder c:ks360, some new files will have appeared. Rename KS360AT-XX-V10x-ORG-XXX-SEP-23-2008_slb.flb to KS360.flb
10. Extract all the files from the LG Utils zip file downloaded earlier
11. Run KS360-Utils-EN.exe and choose option N
o type .USB1 and press enter
o Type c:ks360ks360.flb and press enter
o Type STATIC_EEP (get ready to connect the phone)
o Press enter then within 1-2 seconds, connect the phone (still switched off) (timing is critical!)
12. If successful, a new file called STATIC_EEP will appear in the folder where KS360-Utils-EN.exe was unzipped
13. Copy STATIC_EEP to the c:ks360 folder
14. Run KS360-Utils-EN.exe again and select option O and press enter
o Type c:ks360STATIC_EEP and press enter
o The unlock code appears - write it down and close the program.
o (If you get an error message, repeat steps 11-14 - the timing at step 11 is critical to this working)
Now you can unplug the phone and switch it back on
1. Enter the following number (as if you were dialing a phone number): 2945#*71001#
2.When prompted for a password, enter the number you wrote down in step14, press OK, restart the phone......SUCCESS!! Your phone is nowunlocked
May 09, 2009 | LG KS360 QWERTY Keyboard Phone BRAND...
LG KS360 QWERTY Keyboard Phone BRAND FREE10 TOP UP Logo
37 people viewed this question
Top LG Cell Phones Experts
skiffy99
skiffy99
Level 1 Expert
Raphael Josiah
Are you a LG Cell Phone Expert? Answer questions, earn points and help others
