Question about Pioneer SX-205 Receiver
PIONNER SX-205 "POWEROFF"
I have pioneer SX-205 and say "POWER OFF" and did work, someone can help me
Thanks
  • Laura Jenney Mar 08, 2009
    Have Pioneer SX -205 stereo receiver and worked exceedingly well, (kicked ****), for a number of years. Last night, all of a sudden I get the 'power off' prompt. Now, it plays, but sounds all 'crunchy' like it is not getting enough power. I opened her up, and saw that there was a fuse on this model. Though the fuse does not 'look' blown, that is what fuses are for, to blow before the receiver blows. So, the search is on for a fuse for this piece of equipment. The SX-205 is normally such a good product that i would rather have it fixed, (if replacing the fuse does not work), than buy another product. Will report back after I replace the fuse. Good luck with your's Reuben. ...Laura
5 Suggested Answers
tech48
  • 624 Answers
SOURCE: Pioneer sx-205 gives a overload
Does it play normal on any sources, or do you only have the tuner and CD for available sources?
There are many different things that can cause this type of problem.
It could be bad solder connections on in the amplifier circuit or power supply, it could be a bad speaker or a bad output channel inside the receiver if this happens only when it gets turned up loud.
The overload warning happens when the amplifier circuit has excessive current or DC voltage on the outputs. Unfortunately the only way to determain if it is the speakers is to change them with other known good speakers and see if it still happens. But before buying any speakers you need to have the receiver ruled out as the source of the problem.
It can also go into overload if you have the wrong type of speakers connected, or too many speakers connected. Each speaker jack should only have one speaker connected toit. If you are using for example, 4 speakers connected to the "A" speaker jacks meant for just 2 speakers, it will create a load to the amplifier that the amplifier is not rated for.
Look on the back of the receiver and it will have listed the proper impeadance for your receiver. Most will say:
8 ohms or more "A" or "B" speakers
16 ohms "A" and "B" speakers
That means you must use 8 ohm or higher ohm rated speakers if you are using only speakers"A" or only speakers "B", but can not use 8 ohm speakers if you are using speakers "A" and "B" at the same time. Then they must be 16 ohm speakers.
Two 8 ohm speakers in one speaker jack is a 4 ohm load, that is why you can not use more than 1 speaker per speaker jack.
I hope you found this information useful, and if I can be more help just let me know.
Dave
Posted on Jun 28, 2008
dunnbiker
  • 8546 Answers
SOURCE: PIONEER SX-205. Left chanel out of order.
You haven't mentioned what you have done to isolate the problem so I have to ask some stupid questions.
Is the Left Channel failing no matter what source you select?
N: Source problem / Identify the source and ask another question with new data
Y: continue...
Turn the receiver OFF.
Toggle the Tape Monitor Switch up a number of times to wear off any oxidation. Any change?
While you're at it, toggle, twist and operate every control throughout its range for the same purpose. Lower the volume.
Turn the receiver ON.
Tune an FM station.
Swap the Left Speaker leads and the Right Speaker leads at the receiver. Did it move with the speaker?
Y: bad speaker or wire
N: internal receiver problem.
Posted on Apr 03, 2009
SOURCE: Looking for replacement remote for Pioneer sx-205
The Pioneer SX-205 does not have remote control capabilities.
Posted on Nov 05, 2009
  • 49 Answers
SOURCE: Pioneer Receiver SX-205 flashing
usually it is a technical indication of the output being shorted. disconnect all speaker wires and try again. still blinking?
Posted on Mar 06, 2010
How can I control volume on my Pioneer SX-205 receiver from the couch?
There is a couple ways you can do this.
1.you can use the maufacture remote control, or if you dont have one you would need a universal.
2.If your receiver is hidden, or behind closed doors than you will need a radio frequency capable universal remote
Jan 07, 2011 | Pioneer SX-205 Receiver
I need to program my pionner sx-315 reciever in my directv remote control
I can help you with your Pioneer Receiver & DirecTV remote control.
This is a list of all the Pioneer Receiver control codes for DIrecTV remote controls:
31023, 30150, 30244, 30289,
30531, 30630, 30801, 31123,
31343, 31384, & 31935.
There are so many codes to try for Pioneer Receiver and DirecTV, you might want to go ahead and do a DirecTV Remote Control Code Search.
I hope that helps.
_________________________________________
DirecTV Remote Control Code List Download
DirecTV Remote Control Manual Download
DirecTV Remote Control Code Entry
DirecTV Remote Control Onscreen Setup
May 25, 2010 | Pioneer SX-315
Blown Fuse / SX - 205 / Pioneer reciever
Check the area where the fuse was...it's usually marked on the board or next to the fuse holder. Check the size also, 2 types 5x20mm or 1/4x1 1/4 in. Usually slow blow.
Mar 30, 2010 | Pioneer SX-205 Receiver
Pioneer Receiver SX-205 flashing ''overload''? Nothing in owner's manual troubleshooting chart.
Mar 06, 2010 | Pioneer SX-205 Receiver
Hi, I wold lik to know why, when i push "power" buton the receiver stay on only feew seconds? the receiver is " Pionner SX-315. Thank you; Luiz
ITS feature a Protective circuit breaker to avoid any overload or an IC or any part went Bad , need to be
taken to a REPAIR SHOP.
Oct 23, 2009 | Pioneer SX-315
SX-205. Left channel doesn't work.Internal problem. Should I change any semiconductors / transistors,diods or other/? How to find out,which semiconductor is bad? Please,help me.
Check the final output relays first. They are mechanical and have been known to fail after so many cycles. The click you hear about 3 seconds after you push the power button are those relays.
Apr 04, 2009 | Pioneer SX-205 Receiver
Pioneer SX-203
a little bit foolish thing: see if you have both the speaker channels (A and B) down. if you have both down it doesn't work - didn't for me.. and obviously make sure you have the right letter down - same outpout as your boxes
Dec 06, 2007 | Pioneer SX-205 Receiver
Pioneer SX-205 Receiver Logo
260 people viewed this question
Top Pioneer Audio Players & Recorders Experts
 Grubhead
Grubhead
John
John
Are you a Pioneer Audio Player and Recorder Expert? Answer questions, earn points and help others
