Question about 2wire 2700HG-B Router (2700HGB)
Port forwarding - 2wire 2700HG-B Router (2700HGB)
  • 481 Answers
This isn't a very detailed question, so I have to give you a very general answer.
Port Forwarding is configured in the "Firewall" tab of your router's configuration screens. This set of screens is described in the manual beginning on page 35. You can find the manual here:
http://www.2wire.com/pages/pdfs/5100-000326-000.Rev.A.pdf
Posted on Jul 13, 2010
Port forwarding instructions
Port forwarding used to forward a port request from wan side to local systems on lan to use specific services provided by servers.
go to Setting, use Port forwarding option. Now click on Add. Enter the Local Ip address of system providing the specific service and then add the starting port number and ending port number, (it may be same). Now click on Save.
Aug 17, 2014 | NetComm Computers & Internet
Linksys port forwarding
This WEB site shows how to port forward.
http://www.wikihow.com/Port-Forward/Open-Ports-on-a-Linksys-Router
May 05, 2013 | D-Link DSL-G604T Wireless Router
Can't view IP cam externally
Follow The Process:-
1.Visit https://www.yougetsignal.com/tools/open-ports
input the port 5000 and check is it open or not, if it is not open it means you need to check port forwarding in your main internet router/modem.
2. By Default Routers/Modems Http port it 80. so you need to change ip camera http port 80 to 81 and do port forwarding and to view on android devices check another ports in ip camera network settings. so same port forwarding and check in yougetsignal website.
Visit Here for next level help:-
CCTV Networking Technical Support
Jun 10, 2017 | D-Link Securicam Network DCS-950G Wireless...
NetGear WGR826V has no clear port forwarding section in the setup, the mamnual is as clear as brick as to forwarding...so how do I forward a port on this brain dead router?
Forwarding Port – If you select 'Same as Incoming port' then all incoming traffic on specified Service is forwarded to LAN server without modifying Destination Port. – If you select 'Forward to another port range' then all incoming traffic received on the Service port (or range of ports) is forwarded to this port or range of ports of the LAN Server. – This field is disabled if action selected is "Block Always". – If you want to forward the traffic to a single port then enter port value in start port and leave finish port empty. – If you want to forward the traffic to range of ports then enter non zero value in finish port and make sure that service record attached to this rule has range of ports and range is equal to that of forwarding ports. – For example if you select Service as HTTP (TCP/80), LAN Server IP address as 192.168.15.10 and Forwarding port as 8080 then all traffic coming from internet on – TCP/80 (HTTP) to this Router is redirected to TCP/8080 port of 192.168.15.10 • WAN Users: These settings determine which packets are covered by the firewall rule, based on their source (WAN) IP address. Select the desired option: – Any All IP addresses are covered by this firewall rule. – Address range If this option is selected, you must enter the "Start" and "Finish" fields. – Single address Enter the required address in the "Start" fields. • Log: This determines whether packets covered by this firewall rule are logged. Select the desired action. – Never - never log traffic considered by this firewall rule, whether it matches or not. – Match - Log traffic only it matches this firewall rule. (The action is determined by this firewall rule.)
Ok well this is out of the manual, to me it seems straight forwards, but it is a brick too though, there is an example to help you, basically you tell it the Address of the PC, (Right click on NIC and get address) that you want ports to go to.. then ALLOW it, UN-disable actually.. in the tables.
Feb 05, 2010 | NetGear WGR826V Router (wgr826vna)
HOW CAN I FORWARD A PORT? THIS ROUTER IS NOT LISTED IN PORT FORWARDING APPLICATIONS LIKE SIMPLE PORT FORWARDING ETC.. OR SUGGEST ANY OTHER WAY TO FORWARD PORT
In order to get to the page you need to port forward you need to know your default gateway.
Usually:
192.168.0.1
192.168.1.1
192.168.2.1
Enter those into your web browser, if nothing comes up then go to Start. Then click run(or search if you have vista) type "cmd" then type in ipconfig
Start>Run>Cmd>Ipconfig
There is where you can see your default gateway. Enter that into you browser. I t might ask for a password, it's usually admin.
Also a lot of the port forwarding issues are due to your firewall settings. Make sure you add the ports to there as well.
Jul 10, 2009 | Computers & Internet
Forward ports in linksys wrt45g so magicjack will work
Check this link it has the step by step instruction on how to do a port forwarding on your linksys router , this is just a sample so what you need to do is just replace the value for the port number of your magicjack... http://portforward.com/english/routers/port_forwarding/Linksys/WRT54G/Lingo_VoIP.htm
Hope that helps..........
Oct 05, 2008 | Enterasys Distributed Forwarding Engine...
Asking about port forwarding
for that please log on to www.portforward.com there you can find how to do the port forwarding..
Sep 27, 2008 | Enterasys Distributed Forwarding Engine...
Port forwarding
hi there,
this is a basic step used to forward ports to your system.
Port Forwarding Steps for Routers 1. Log into your router. Usually the URL is http://192.168.1.1/, and enter the username , and the password . If you have never set a password, the password (which you should change) is admin. Consult the manual if you have never set up your router before or need to reset the password. 2. Click on the "Applications & Gaming" tab or Under Advanced, click Port Forwarding.
3. Click on the "Port Range Forward" tab .
4. In the "application" field, type "web" (if you are forwarding wb traffic on port 80) or "torrent" (if you are forwarding bittorrent traffic on port 40156). This is just a "nickname" so that you can recognize what you were trying to do when you come back to it.
5. In the "Start" field, enter: 80
6. In the "End" field, also enter: 80
7. Set "Protocol" to TCP. Web and Bittorrent servers use only TCP, so there's no reason fo forward UDP traffic too and create an unnecessary security risk.
8. In the "IP Address" field, enter: 192.168.1.11 or your system IP address.
9. Click "Save Settings." Forwarding should begin immediately.
Apr 15, 2008 | Computers & Internet
Port Forwarding
To Enable Port Forwarding for MR314 or RP114 1. Type the router's address in an Internet browser's address bar. (By default the router's address is 192.168.0.1). 2. Enter the router's username and password. 3. Click Advanced > Ports on the left menu bar. 4. Enter the first port number in an unused Start Port box. 5. If only one port number is to be forwarded, enter the same number in End Port. To specify a range of ports, enter the last port to be forwarded in the End Port box. 6. Enter the IP address of your local server in the Server IP Address box. 7. Click Apply.
Feb 19, 2006 | NetGear MR314 802.11b
Port Forwarding
Feb 19, 2006 | NetGear RP114 Router
2wire 2700HG-B Router (2700HGB) Logo
121 people viewed this question
Top 2wire Computers & Internet Experts
Prashant M
Prashant M
Michael Galve
Michael Galve
Are you a 2wire Computer and Internet Expert? Answer questions, earn points and help others
