Question about Cameras
Insignia camera turns off with three beeps
Insignia digital camera NS-DSC10B when turned on, beeps 3 times and turns off. Lens does not move, but the display shows up momentarily.
  • 3,083 Answers
The camera is trying to turn on, but either the lens is stuck, causing an overload in an effort to turn the motor that, through gears, extends the lens. That's a common problem, and the 2nd most common problem is that the batteries are not holding enough charge to drive the motor, contacts are dirty, things like that. There are 2 excellent web blogs that detail the problems, and what you can check and try. Here they are:
http://camerarepair.blogspot.com/2007/12/fixing-lens-error-on-digital-camera.html
http://camerarepair.blogspot.com/2007/11/simple-fix-for-dead-cameras-that-wont.html
Good luck, and hope this helps.
Posted on Jul 14, 2010
  • Damu Radhakrishnan Jan 03, 2011
    I removed the lens system, and LCD screen. But the problem is still there. This is a very common problem now with many cameras. But the solution given is not correct.
I cannot turn the cameras flash on
I am not sure whether this is a recent problem with your camera or you are trying to use the camera for the first time. I suggest you to look at the user manual. If you dont have one, then download it free from:
http://insigniaproducts.com/cms/documents/NS-DSC10A_NS-DSC10B%20UM%20EN%20V2.pdf
In the manual, pages 8 & 9 explains how to set the flash.
If it is a recent problem, then you need to get it repaired. Sometimes, it may be due to a bad capacitor which hold the charge for the flash. It is difficult to replace the capacitor. It is soldered to the inner board. Also, the capacitor hold charge once it is turned on. So it is not advisable to do it yourself unless your are a technical person. You need to discharge the capacitor before you can remove it, else you may get severe electric shock.
The following site explains the capacitor charge:
http://www.andyozment.com/guides/broken_lcd_cracked_screen_canon
Jan 10, 2011 | Insignia NSDSC10A Digital Camera
Camera turns on and makes weird sound. Then is shuts off. Contains brand new energizer lithium batteries.camera model:NS-DSC10B
it is possible that your phone shutter/lens cover mechanism is deffective., Since this is a very delicate and sensite section, all what you could try is to open carefully and check for any foreign particles, dust or moisture that could have made this possible. use a good blower to blow out any dust that have crept in. free the shutter and try it on again. It might release off and free the dust cover or the shuttle mechanism. Please make use of a ggood lens to inspect the shutters, use a good swap to clean. rectify if any mechanical damage. hope this advice helps. Good day
Jun 21, 2010 | Cameras
When camera turns on it shows the insignia sign, gives 3 beeps then turns off. What could be the problem?
Hi there 3 beeps means system error. Remove the memory card and try again. If you get the beeps again then the problem occur in Lens. Its stuck from in side. Its happens when the guide pin is damaged or dislocated. In that case you have to visit service center. After remove the card if problem solve then before fix back the card please, format it and use. I hope your problem will solve then. Thanks.
Apr 11, 2010 | Insignia NSDSC10A Digital Camera
Insignia camera turns on beeps three times and turns back off
Three beeps indicates a low battery or other warning. It also indicates error messages, such as memory full or card error. You should try replacing the batteries, erasing files from the memory, or verifying that your memory card is in the correct format and/or not defective. Additional details can be found in the owner's manual.
Jan 30, 2010 | Insignia NSDSC10A Digital Camera
My insignia 7.0 megapixel camera model NS-DSC7B09 will
A few things. Make sure the batteries are in the camera correctly.
You could test the camera by using an adapter which is for this camera to see if it will work without the batteries. That will tell you if the camera's circuit can work with out the batteries. If it works the camera needs repairs. If the camera does not work with an adapter, then it needs repair or can be sold for repairs or as is on a site such as Ebay.
Nov 09, 2009 | Cameras
Three beeps when i try to turn it on
i had the same problem a while back. I fooled around with my camera lens a bit and it turned out that one side of the lens was sticking out a bit. I pressed down on this and pushed the power button and it worked. The next time I turned it on the same thing happened but if you keep doing the same thing it should work.
Hope this helps!
Aug 21, 2009 | Samsung L100 Digital Camera
My Samsung won't turn on :(
Try to move the lens a bit or straighten it out, that usually works when it makes the three beep sounds.
Jul 22, 2009 | Samsung L100 Digital Camera
Samsung digimax s800 not swiching on
The problem is that the lens is jammed. I had to take my camera apart to unjam mine manually, the cogs that move the lens are not lined up with each other, thats why you hear the motor turning and then you get the 3 beeps because the lens hasnt initialised
Dec 20, 2008 | Samsung Digimax S800 Digital Camera
Camera issues:(
I had the same problem, stuck lens, 3 beeps and shutdown. You must get pissed off at the camera first. Then bite the lens, clenching it like pliars (you could probably use pliars too), turn the camera on and immediately start pilling on the lens in the outward direction. The tooth grip unstuck the lens and vot it worked. you can take this solution to the bank.
Aug 20, 2008 | Polaroid i735 Digital Camera
Cameras Logo
334 people viewed this question
Top Cameras Experts
Steve
Are you a Camera Expert? Answer questions, earn points and help others
