Question about Hotpoint 24 in. HDA3400G Built-in Dishwasher
Will not drain, pump runs, how to unstop it - Hotpoint 24 in. HDA3400G Built-in Dishwasher
    President:
  • 1,382 Answers
A clog in the drain line or air gap (if there is one) is the usual reason that a dishwasher won't drain. Often the problem is at the point where the drain line attaches to the garbage disposer or household drain line. If you remove this line, you can clear any debris from the hose or hose connection. Be sure to reattach the hose before starting the dishwasher again.Many dishwashers use a drain valve with an electric solenoid. When electricity flows to the solenoid, the valve opens and diverts the water to the drain. Sometimes the solenoid, or the diverting lever, sticks and prevents the dishwasher from draining or filling properly. Try to free up the solenoid to lubricate the lever. Otherwise, you may have to replace the solenoid or pump assembly. With these systems, the motor always rotates in one direction. When it's energized, the drain valve diverts the water.
Other dishwashers simply reverse the direction of the motor to drain the dishwasher. These units don't have a drain valve. Instead, there's a drain hose connected directly to the pump housing.
Thank you !!
Posted on Jul 14, 2010
Bottom of freezer has a layer of ice, that returns after removal, no aparent drain or leak
there is a drain hole in the bottom of freezer near back wall if its a side by side. take out bottom crisper drawer to locate drain. than take hot water in a turkey baster and run hot water doen drain hole to unstop drain.
Aug 31, 2014 | KitchenAid KFXS25RYMS 25 cu.ft. french...
Tip
How to unstop a toilet without a plunger!!!!!
O.K. guys. Get your iron stomachs ready for the most sought after college age tip. HOW TO UNSTOP A TOILET WHEN THERE ISN;T A PLUNGER TO BE FOUND!!!
Here is what you will need:
1. Yourself
2. Your nerves
3. Ability hold your breath if necessary
4. Standard 30 gallon trash bag
Simply place the bag over your arm and pull in all your finger while leaving you palm extended upwards. (like you are doing a palm thrust). Slowly stick your hand into the bottom of the toilet until you reach the drain. Fit your fist into the hole and pump your palm up and down while leaving your knuckles on the ceramic wall. Pump quickly and with as little movement of the elbow as possible to reduce unwanted "splatter". The toilet will quickly begin to drain and you are free to pull the top of the bag over your fist to capture any unwanted materials you wouldn't want transferred about the bathroom.
AWESOME!!!!! NOW YOU CAN USE THIS SKILL TO COME TO ANYONE'S RESCUE!!!!!
GOOD LUCK AND PLEASE RATE THIS TIP!!!!!!
on Feb 22, 2010 | Plumbing
How do I unstop my dishwasher?
Turn the breaker off for five minutes and the turn back on. Start the dishwasher and see if it will drain. Sometimes power bumps can mess with the control board. Otherwise it could be the control board or the pump.
Apr 24, 2014 | General Electric Dishwashers
Manual icemaker
do you mean drain pump? if so is there water standing in the bin? unstop the drain if not then replace the pump.
Jan 22, 2014 | Scotsman CSW45 15" Ice Maker with 26 lb....
The hose detached from the garbage disposal. I re-attached it and now the water can't pump out of the bottom of the dishwasher
You have a clogged drain, remove the sink trap and use a plumber's snake to unstop the clog. Reattach the trap under the sink and disposal should drain. The pressure from the dishwasher pump more than likely caused the drain to slip loose, it's a drain, and it should not have any backpressure.
Jul 08, 2012 | Whirlpool Dishwashers
There is water in the floorboard when the air conditioner has been running
CONDENSATE DRAIN IS MOST LIKELY PLUGGED , DRAIN IS LOCATED NEAR BOTTOM OF FIREWALL ON PASSENGER SIDE ... COMPRESSED AIR WORKS GREAT TO UNSTOP THE DRAIN
Aug 08, 2010 | 1996 Jeep Grand Cherokee
I am having problems with A/C condensation leaking inside with flooding the front and back floor of Car
check your drain hose for blockage, if it's clogged up the condensation will leak into the floor
Jul 19, 2010 | 2004 Mazda RX-8
Hose not draining, bucket only fills
The easiest way to unstop the hose is to blow air through the end enough to clear the clumped up dust at the other end using air compressor or air pump.
Jul 12, 2010 | Frigidaire FDF70S Dehumidifier
Drain hole stopped up in freezer and we cant get it unstopped and it is leaking down in to frige. do you know how we can get it unstopped?
pull back panel in freezer, take hair dryer and melt ice around drain hole until it starts to drain may take sometime usually 20 30 mins pour hot water in drain pan to verify that it is draining
Jan 03, 2010 | Roper Refrigerators
How do I unstop my pump?
Short of removing it and placing on back. No other way.
Jul 09, 2008 | Maytag 24 in. MDB5600A Jetclean II...
Hotpoint 24 in. HDA3400G Built-in Dishwasher Logo
154 people viewed this question
Top Hotpoint Dishwashers Experts
Are you a Hotpoint Dishwasher Expert? Answer questions, earn points and help others
