Question about Cameras
I have 5.1mega pixels but the screen is not clear and waved and blurry
  • 3,083 Answers
Inside the lens assembly, there is a round, free-wheeling focusing lens and plastic enclosure with electromagnets on it. When dust, lint, dirt, sand, etc. works it's way into the lens assembly, it can get jammed up. When this happens, you can try to spray compressed air into the front of the lens assembly, with the lens facing downward. Hopefully, you will free it up. The other thing you can try is to hold the camera, lens facing up, and gently tap the side with the palm of your hand, hoping to free up the lens. If neither of these things works, the camera will have to be serviced. It's quite a job, and will be expensive, since the whole camera will have to be disassembled. Get an estimate, since the cost of repair can exceed the cost of a new camera.
Posted on Jul 13, 2010
Why is picture blurry?
Sounds like a misalignment problem. the lens has a specific optical plane the DLP chip must be positioned at in order to provide the proper focus on the screen. Try repositioning the board or adjusting the lens to clear up the fuzzy picture. Regards.
Aug 17, 2015 | Mitsubishi WD-73733 73" HDTV
My picture is blurry,and words are blurry,what do i do
A blurry image on a high-definition LCD TV is typically the result of a mismatch between the TV's resolution capabilities and the resolution of the signal that is coming from connected devices, such as a DVD player or satellite TV receiver. Typically, blurry pictures result when a peripheral device connects to the TV through nonHD cables and jacks.
If your TV's connected devices do not have HD capability, they will transmit content to the TV in standard, analog signals. These types of signals are only capable of resolutions of up to 640 by 480 pixels. Pixels, for picture elements, are the tiny dots that make up the screen image. Most HD LCD TVs are capable of resolutions of as low as 1,366 by 768 pixels and as high as 1,920 by 1,080 pixels. When this big of a discrepancy occurs, the images display on the TV scaled, stretched and blurry.
Jan 24, 2015 | Televison & Video
My tablet screen is not clear. the display is blurry and pixelated. .
hi,
if there are no damages such as liquid or physical damage than you can call Samsung, and if you have the receipt - or date of purchase registered then call Samsung and see if it falls under the warranty
thanks
Oct 19, 2013 | Samsung Galaxy Tab 101 Tablet...
Blurry pixel display of AOC monitors.
Hi, In my experience, it looks that the screen pixels are damaged in some areas. It could be due to mishandling, may be fallen or it could be a manufacturing defect. If the device is new, ask for the replacement as it may enlarge due to heat. Rest is your luck :)
Sep 28, 2017 | AOC Monitor
The webcam image is not clear when it is in full screen mode
its a low resolution image, the larger the image is made, the larger the pixels become and this makes the image blurry. unfortunately nothing can be done about this besides buying a higher resolution camera.
Jun 18, 2009 | Computers & Internet
People say my web cam is blurry when they watch it
you will have to adjust the lens of your cam or do the settings with the web cam
as u say it is 3 years old so it might not be with the mega pixels technology. so it is possible that the person who is watching you might not see you clearly
Nov 23, 2008 | Logitech Webcam
55 inch Philips
I have 50" philips magnavox big screen. I recently started to have a problem with the edges of my tv. They became blurry. the center of the tv is clear and the edges are blurry. what should I do to fix this problem.
Sep 06, 2008 | Philips 9P5034C 50" Rear Projection...
Fuzzy page continious.
Yeah I just read a tip. There seems to be a problem with the wave amp board, I will send you the engineering note. Sometimes though that encoder needs replaced and cleaning is not the total fix. The encoder may need replaced, but I found this also.
I just received this, this morning.
Failed Wave Amp
Solution: thumbsup.gif Fixed! thumbsdn.gif Did not fix. Historically blurry print was caused by oil on the drum encoder wheel. This can be caused by the wave amp board. A cracked capacitor on the board causes the wave amp to produce a malformed amplified wave signal to the printhead. This in turn causes the printhead to eject ink at the wrong times, so the prints look blurry.
You can generally distinguish a wave amp problem from an oily drum encoder. The wave amp problem will usually be an infant failure. The printer will start producing blurry prints soon after it is installed and running. With a failed wave amp all prints will be blurry with no improvement. The drum encoder, on the other hand, may produce good prints and then bad prints and then good prints. Blurriness changes depending on how the oil is interfering with the encoder.
May 05, 2008 | Xerox Phaser 8500/DN Printer
My screen is blurry
When you say "blurry" do you mean optically blurry or skipping frames, or maybe just very pixelated? Blurry as in fog on a window means optics are probably dirty. A fingerprint, some KFC juice...all could cause blurry. You also didn't mentionw hat you are recording it on, but hope this helps a little.
Aug 27, 2007 | Logitech Webcam
Cameras Logo
Top Cameras Experts
Marvin
Marvin
Are you a Camera Expert? Answer questions, earn points and help others
