Avol 22" ALT2260M hdmi cable hooked up to an xbox 360 causes the tv to lock up and become unresponsive.
ipodslinger
  • 688 Answers
SOURCE: cant play my xbox 360 on my 22 inch Insignia tv
Is the TV an High Definition TV?
If it's not an HDMI compatible tv them you will need a regular audio video cable for your XBOX 360
you cn get them all day on ebay or at any store.
Posted on May 25, 2009
gage8405
  • 5 Answers
SOURCE: TELEVISION - PS3 AND XBOX HDMI COMPATIBILITY
You have to use the scart connector for on screen menu settings. Go to the video option and enable HDMI and/or match resolution output to your set.
You did not mention the model of the TV so here is another scenario,
Just because the TV is 1 year old doesn't mean that it is a 1080p capable, you could have set the HDMI resolution settings to 1080p and you will not get any picture if your set cannot process the information.
Posted on Jul 03, 2009
SOURCE: No sound with HDMI cable and Xbox 360
FROM THE TOSHIBA MENU, (FIRST MAKE SURE YOU ARE SET TO
THE HDMI PORT THAT THE XBOX IS PLUGGED INTO) THEN SELECT
HDMI SETTINGS, UNPLUG HDMI CABLE FROM THE TOSHIBA TV (LCD
FLAT, MINE IS A 42") WAIT FOR THE SETTINGS TO HIGHLIGHT OR NOT
BE GRAYED OUT, THEN TURN OFF THE THREE SETTINGS, FOR COLOR
AND LIP-SYNC., SCROLL DOWN AND PRESS THE RESET BUTTON,
WAIT FOR MESSAGE TO APPEAR. TURN OFF THE TV AND PLUG IN THE XBOX.
TURN EVERY THING BACK ON. SEE IF IT WORKS.
NOT ALL CABLES ARE THE SAME AND NOT ALL TVS ARE THE SAME.
READ THE TV OWNERS MANUAL CAREFULLY, (RTFM), I FOUND A NOTE ABOUT
THESE SETTING ON THE SPECIFICATIONS PAGE.
Posted on Jul 13, 2009
  • 3 Answers
SOURCE: hooking up xbox 360 to tv
put it on hd. the big plugin that say tv or hvd
Posted on Feb 10, 2010
SOURCE: theres a delay when i play my xbox 360, why?
go to your picture menu and go to advanced video then go to DCM and turn it off. it should work i had the same problem if that dont work then try turning off the dynamic contrast and adaptive contrast along with the DCM. if that dont work then im sorry.
Posted on Mar 13, 2010
Switching from cable to tv
Press Menu button, go to source, scroll though to antenna, press ok / Enter
Feb 19, 2015 | Televison & Video
Avol mod#alt2260m remot code
I have an avol lcd tv. my tv is not operating with remote and have no remote code remote is ARC-U1 tv model is ALT2260M. Please tell me hoow to apply code and which code is ti be applied on the remote.
Dec 09, 2012 | Televison & Video
I am in Afghanistan, Kabul Area. I have an ALT2260M Avol tv. when I use the autotune for channels, All I get are the local channels. We are hooked into the AFN Network cable and it does not pull those...
try going into the autotune then select us then cable select the auto acan then change from auto to irc or std then scan should do the trick.
Dec 06, 2010 | Televison & Video
Hi, i have a flx-2211b element electronics tv and I have a xbox 360 hooked up to it through a HDMI cable but the tv says unsupported mode. what do i do to fix it?
I have the same problem with my 360 i am just going to by a new tv i cant find the remote code. or any thing and the hdmi port don't work that's my answer this TV sucks and it is ****..
Jan 07, 2010 | Element Electronics FLX2211B 22 in. LCD TV
Cant play my xbox 360 on my 22 inch Insignia tv
May 25, 2009 | Insignia 22 in. Widescreen Flat-Panel LCD...
Xbox 360 controller wont connect to xbox, and is otherwise unresponsive. just brought home another controller, which also dosent connect, and hdmi cables, which i have hooked up to the hd tv. looks...
press the little white button on your 360 on the front and then press a button on top of your controller that looks the same, then wait a bit and it
Apr 07, 2009 | Microsoft Xbox 360 Controller
HDMI problem with Xbox 360 to Dell TV
check that the wire coming from the xbox 360 elite to the tv is switched to hd, and the other end of the wire has the red and white for the sound pluged into the tv and that the red green and blue wires are pluged into the tv. also check to see if the hdmi cable to conected to the tv and xbox 360 elite.
Jan 06, 2009 | Microsoft Xbox 360 Elite Console
Xbox 360 hdmi connection to dell W3201C no display
The W3201c IS 720P. You have to adjust the display output on the xbox 360 to 480p then adjust settings up from there...
Jan 03, 2009 | Microsoft Xbox 360 Elite Console
Avol TV remote
I own an AVOL 19in TV, I just got my comcast cable hooked up; I too was plagued by initially having to use my other remote to turn TV/volume on/off up/down. Being the code is not listed in the Comcast universal remote instructions, in the above answers someone mentioned APEX as a parent company with AVOL; I was able to use a code from the APEX codes listed in the Comcast universal remote instructions to get the controller to work with turning the TV power on/off and volume control. The code that worked for my particular TV was 10765. Try these codes for your TV to see if they work- 10748, 10879, 10767, 10890. Hope this helps.
Mar 17, 2008 | Televison & Video
Xbox 360 hdmi cable
Make sure both the xbox and tv are on and tv is on HDMI source. It won't recognize each other unless xbox is turned on and tv is set to the correct source.
Sep 24, 2007 | Microsoft Xbox 360 Elite Console
Televison & Video Logo
500 people viewed this question
Top Televison & Video Experts
Marvin
Marvin
