Question about Acer AL1715 17" LCD Monitor
Every 5 to 10 minutes my monitor gets a white screen. If I turn off and back on the monitor, it goes away
  • 11,361 Answers
You may loose connection between the logic board and the LCD panel connector, or the 5vdc feeding the panel is going out. Look to see if you notice anu caps with leaking.bulging tops.
http://s807.photobucket.com/home/budm/allalbums
http://en.wikipedia.org/wiki/Capacitor_plague
Posted on Jul 14, 2010
Hyundai monitor on for 5 minutes and screen goes black
Have you ever opened up the monitor to clean the dust out,it could be your heating up and then letting it sit will bring it back.If your unsure how to do this ask a tech.
Apr 21, 2017 | Hyundai X224W
Compaq presario 700. The screen, after running for about 5-10 min, gets white lines horiz. and vert. and then goes all white. I have to turn it off for a while and it goes away. (for 5-10 min)
The monitor heat sheild is probably damaged. If you don't have a warranty then you will probably have to replace the lcd panel on the computer.
Hook an external monitor up to it and verify that that screen doesn't scramble. if it does not and the lcd does then the lcd panel is damaged. if both do then you have a motherboard problem with the graphics card. either overheating or damaged. There is also a possibility of memory issues but the first 2 things i mentioned usually over this problem
Feb 12, 2010 | Compaq Presario 700 470024-192 Notebook
Monitor goes white.
if the monitor turn white but the power light is stay on with green, then probably the back light tube was defective, and it will happen randomly in beginning and getting worse after while.
Jan 14, 2010 | BenQ FP71E 17" LCD Monitor
LCD Dell Monitor displaying purple and green rather then picture.
sounds like your monitor is starting to go out. if there are any speakers near your monitor, it is likely magnetic interference. try moving your monitor to a different area and see if it still does this. if it does, i would replace the monitor. if it doesn't, just simply reorganize the area around your monitor and it should go away after degaussing the screen.
Jul 11, 2009 | Dell E177FP LCD Monitor
It turns off after 10 minutes working
When you say it turns off, is the power light going out too?
If the power light is still lit when the screen blanks, it may be a faulty backlight inverter.
After 10 minutes elapse and the screen goes out, if you power it back on, do you get another 10 min, or does it last a much shorter time period, or not at all?
Your best bet is probably simply to buy a new monitor, and sell yours as "broken" on eBay, I'm sure someone out there capable of fixing it would be willing to pay pennies on the dollar to subsidize your replacement screen.
Jul 03, 2009 | Gateway FPD1965 19" Flat Panel LCD Monitor
Vx2235wm lcd flickers a bit then turns white
White screen is an indication of a faulty video board.
A blown fuse in the actual screen will cause the same effect but usually these do not reset on a fresh startup.
You can check the ribbon going from the video board to the back of the screen to see if it is somehow working loose, but I think based on your description that this isn't the problem.
ebaysbammbammfran
Oct 07, 2008 | ViewSonic VX2235wm LCD Monitor
Screen turns white only
http://www.daniweb.com/forums/thread17104.html
check out his forum thread. I think there is good information posted. I hope it helps.
Sep 20, 2008 | Acer AL511 15" Flat Panel LCD Monitor
White monitor
You can degouse it.I think you placed your monitor in any magnetic field or near fan ac or any electric equepment.
Hope this be of initial help/idea. Pls post back as requested, how things turned up or should you need additional information.
Good luck and kind regards.
Thank you for using FIXYA.
Mar 13, 2008 | Xerox XA7-172i 17" LCD Monitor
PC or monitor, signal problems
your monitor is telling you it's on it's last legs..either that or your compaq has a bad video section. either is more vital than a video cable being loose.
Mar 10, 2008 | Computers & Internet
Acer AL1715 17" LCD Monitor Logo
51 people viewed this question
Mohammed Ebrahim M
Mohammed Ebrahim M
Steve Sweetleaf
Steve Sweetleaf
