Question about SmartDisk (FWFP120) 120 GB Hard Drive
File is reading as locked and it doesnt allow me to delete any files
  • escher6686 Jul 13, 2010
    my esternal hard drive is showing up as locked . it doesnt allow me to delete files from it
  • 6,826 Answers
Http://www.smartdisk.com/support/manuals/fwfp%20userguide.pdf
Unfortunately, when I tried to download I got an error.
So, I do not know how to unlock these files for deleting.
However, you may try the above link at a later time to see if it tells you
how to delete files that are locked.
Good luck on this one.
Posted on Jul 13, 2010
  • 15,935 Answers
Just one particular file - or a folder - or the entire drive?
Thanks!!
  • 1 more comment
    my hard drive shows up as 3 separate drives on my desktop. One of those drives shows up as locked and all the files in it are locked.
    the particular drive shows a lock on it
    i need to know how to get rid of the lock icon that sits on the picture of the drive
Error 8004
Do a Get Info on you hard drive (can just Control Click it and choose Get Info).
Unlock using the Lock Icon at bottom right.
Click the + (plus) bottom left.
Add yourself.
Change the Privilege to 'Read & Write'
Click the gear at the bottom
Choose 'Apply to enclosed Items'
Choose OK when it asks if you really want to do that.
Will run for a few minutes.
If that did not work, use the Disk Utility in the Utilities Menu, near the bottom of Applications.
From there, choose to Repair Permissions on the First Aid tab.
Repair Permissions won't change anything if the Mac thinks you can only Read files, so you have to do the first step above either way.
All the best to you,
Kerry
Jan 24, 2014 | Apple MacBook Pro Notebook
I have an Acer aspire one netbook. ?; why cant i rename a file. Its in, Computer-Ascer(C:)-Users-. There are two files in this folder. Im not able to rename either. Is there a way to rename them?
If you have the file open or part of the content of the file is in use some place in the pc it wont let you rename it
try open the file as an administrator in safe mode or it might be read only attributes
copy paste soem place else see if it lets you then change name
rename and save some place else
There are several reasons why Windows might not allow you to delete a file:
  • The file might be in use in which case you can't delete the file until the program using it gives it up.
  • The file might be marked read-only.
  • The file name might be so long that Windows can't handle it. File names with more than 260 characters in them are often difficult to delete.
There are also several reasons why Windows might not allow you to change the name of a file; particularly its extension. All above apply here; as well as...
  • Your system may not be showing file extensions by default.
We'll cover that one first and the others in turn.
File Extensions Not ShowingThis is the most likely possibility for why you might not be able to change a file's type (i.e., rename the file extension). When Windows installs, one of the defaults is to turn off the showing of the full names for common file types. Basically, in Windows Explorer only the file's rootname shows; the extension is suppressed, yet is "shown" via the description in the File Type column of the Windows Explorer display.
When Windows is set up this way, if you attempt to change a file's name you are only allowed to change the rootname of the file but not its extension. So, if you have a file that shows up as MYFILE as file type Text and you attempt to rename the file to MYFILE.DOC what you really have done is rename MYFILE.TXT to MYFILE.DOC.TXT and the file type in Explorer will remain Text instead of changing to a Word File.
How to you fix this? FILExt has a different FAQ here that explains the procedure in detail.
The File is in UseA file in use by the operating system generally can't be changed while the file is in use. A file in use by a program may or may not be able to be changed. These are not hard and fast rules and exceptions abound; particularly in a multi-user environment. But, if you try to rename or delete a file and Windows complains that the file is in use don't be surprised.
To fix this you have to determine what is using the file. The error message that Windows pops up may or may not have that information in it.
If you don't want to experiment a bit to figure out what might be using the file you can restart the computer with all startup options turned off. This will most likely not run whatever was using the file and the system will allow you to rename the file. Recognize that if you do this and then restart the computer with all startup options enabled some program will likely complain that it can no longer find the file you just renamed. This may or may not affect how your system performs (or even operates at all).
To change the startup options, use the System Configuration Utility.
  • Click on the Start Menu.
  • Click on the Run item.
  • Type msconfig into the dialog box and click OK.
Use the various startup options settings to reconfigure your system startup as needed to find the subject program or process. Remember the caveat about how changing the name of a file a program or the system uses might affect system behavior. Keep good records so you can reverse what you did if necessary.
If you want to experiment a bit, press the Control-Alt-Delete keychord (press all three keys at the same time) only once (if you press the keychord twice you will restart your computer). The Windows Task Manager will appear. Take the Applications tab and see if anything is running. If so, stop those programs (it's usually better to switch to the program and then close it from the program instead of picking Close from the Task Manager). Wait a bit as it sometimes takes Windows a bit of time to release all program assets. Then try to rename or delete the file. If you now can rename or delete the file you know one of the programs was using it (stop only one program at a time if you really, really want to know which one).
If you still can't rename or the file you need to go to the Processes tab. There should be a number of running processes. Two of these are particularly important: Explorer and Systray. Do not end these. The other processes should be able to be stopped. Try stopping those processes you may recognize one at a time. Attempt to rename or delete the file after each has stopped. If you can, then you know what process was using the file. Keep going until only Explorer and Systray are running. If the file is still in use you've got your answer. The most basic processes in the computer are using the file. The same caveat as above applies: the file was in use for a reason and if you rename it or delete it the system may become unstable if you rename the file.
File is Marked Read-onlyThis is the easy one. To find out if a file is marked read-only right click on the file in Windows Explorer. Select "Properties" from the menu that pops up. At the bottom of the dialog that appears are the attributes for that particular file. See if the Read-only box is checked. If so, you won't be allowed to modify the file. To take the read-only attribute off the file uncheck the box. Again, be aware that if some program requires that file to be read-only and you change that attribute or the file's name you may have system problems. Use caution.
Note: If the file is in use (see above) or you don't have the necessary permissions (i.e., you're not logged in with administrator status) the read-only box may be greyed out and until you correct whichever condition is to blame you will not be able to change the attribute.
How does a file get to be read-only? Most of the time it's by copying the file from a CD. Most CD media, by design, is read-only and often when you copy a file from a CD (or an install program copies the file) a read-only attribute will be given to the file because it was read-only on the CD. This doesn't happen often, but does happen often enough to cause some people problems.
File Name is Too LongWindows has special problems dealing with extra long path/filenames. If the combination of the path and file names gets close to 255 characters (127 for Windows 95/98/ME) Windows will likely not handle it well if you try to delete or rename it (you can create it but not change it). While there are programs that can handle names that long or longer (e.g., FileBoss) the first thing to try would be to rename some of the folders that lead up to the file itself. Back the directory display up one level and then select and rename the folder the file is in. Try a single letter (obviously, keep a record of what folder you named to what so you can reverse the process!). Then, go back to the file and see if Windows then allows you to rename or delete it. If not, go back yet another folder and rename that one and so forth. At some point you should be able to find a series of reduced-length folder names that allow you to then rename the offending file to a short enough name to allow you to then recreate the original directory tree and still work with the file in question.
Special Programs for Deleting Files/FoldersSometimes you can't seem to delete a file or folder no matter what you do. In this case there are a few programs that might help you.
If, after all this you still can't rename/delete a file, not certain what else to suggest. Others have this problem often and as different ideas might come up in the FILExt forum I'll change this FAQ to include them. If you find a method that works for you and is not in this FAQ, please drop FILExt a note with details on that method so it can be added to the FAQ.
Jul 24, 2012 | Acer Computers & Internet
How do I change permissions on a file. I can't
Try to eliminate as much option as you can!
Jun 07, 2011 | Video Game Consoles & Games
When trying to format,copy files into flash,deletinf files,i get the message "remove write protection". so how can i remeve it?
One of two things:
Either your flash drive/card has a hardware copy protect on it (usually in the form of a little tab) Just be sure that it is turned off.
Or
You've somehow managed to tick the "read only" box on your files. Highlight the files, right click, go to properties, and unclick the checkbox for "read only". This may have to be done as administrator.
I'm really opting for the first one, Most people don't realize that their card or stick has copy protection on it and wonder why they can't delete files.
If nothing else works, you can always use a software program called unlocker - http://www.softpedia.com/get/System/System-Miscellaneous/Unlocker.shtml
It integrates into windows explorer and allows you to delete files in use, locked files, etc, etc.
May 11, 2011 | Transcend 4GB JetFlash 110 USB 2.0 Flash...
When I try to send file(.jpeg) from other phone to my k810i via bluetooth,it says that my memory is full,and it asks me if I would like to delete some files,I select OK,but it prompts me that there are no...
Make sure the lock notch on the memory card is in the unlocked position. it is a small notch on the one end of the card, should slide back and forth lock/ unlock. if this doesnt work try to put the memory card in a card reader and see if you can browse files on the card, if you cant, the card is probably gone bad..
Jan 25, 2011 | SanDisk 1GB Memory Stick M2 Memory Card
Folders missing due to folder lock..? Helllo everyone... i have locked some folders by folder lock...but when i open folder lock those folders doesnt appear in list of locked files + It doesnt shows where...
Check this. I use it, because it's much quicker. If you wish to "read" the contents of the .regfile, simply right-click on it, and choose, "Edit." Just DO NOT edit the file.
After you're satisfied it is safe, double-click on it. Now, right-click on a folder you don't have access to and choose, "Take Ownership."
https://www.howtogeek.com/howto/windows-vista/add-take-ownership-to-explorer-right-click-menu-in-vista/
Apr 05, 2017 | NewSoftwares Folder Lock
How to format the write protect pendrive in
You will need to remove the "read only" attribute from the files on that drive.Open the removable pen drive in "My Computer". choose the files you want to delete and right click. Select properties. At the bottom of this dialogue box are two check boxes. Remove the check in the "read only" box an click apply, then ok. Now you should be able to delete this file. Do the same to any file that will not allow you to delete it.
Mar 28, 2010 | Microsoft Computers & Internet
How to delete the file ''hiberfil.sys''
http://www.emco.is/download/moveonboot/moveonbootsetup.zip
try this program ...it moves and delete files that are protected at boot...so ...probably after the install a feature will appear on right click pop up ...kinda like the one that allow you to scan a file by right clicking and selecting anti virus run ...I had an earlier version on my pc ...and always worked just fine ...Im not sure about this file cause it appears to be a system file ...but from what I read about this program seams that it doesnt has any problem with any kinda files... so :
install
reboot
select the file / right clic select delete on boot ..
after the ok ...it will be deleted on next boot ...
Jun 16, 2009 | Lenovo ThinkPad T61 Notebook
P6 locks up when opening a project
The software knows whether the file is in use by creating a "lock file". When you "fix" a locked file it usually means the software deletes the file that prevented access your file/document and not that it dropped the user currently using that file instead of you. The software only allows you to fix a locked file, because rarely the software makes a mistake and does not clear the lock file. While it assumes you've verified you're right and it's wrong. In my experience, the file is actually in use either by a system process, through a remote account, or by a user you just couldn't locate. The software locking up when you force the deletion of the lock file is always the result of a read/write error. This is usually a good indication two sources are in fact trying to utilize the same file.
Dec 08, 2008 | Computers & Internet
Olympus DM-10: stuck in "read only" mode
I wasn't the one who posted the initial problem, but this helped me tremendously!!! Thank you!! I had to delete some important files, but at least I can get more tomorrow!
Thank you very much fixya!
May 05, 2007 | Olympus DM-10 Handheld Digital Voice...
SmartDisk (FWFP120) 120 GB Hard Drive Logo
21 people viewed this question
Top SmartDisk Computers & Internet Experts
Sunday Ojelabi
Sunday Ojelabi
 Ian Kayhan
Ian Kayhan
Are you a SmartDisk Computer and Internet Expert? Answer questions, earn points and help others
