Question about American Standard Plumbing
If L=0.2henry,and C=0.8farads,determine the resistance R,so that the circuit is critically damped
  • 251 Answers
Hi, sorry no answers for your homework but check out this link and the example at the bottom of the page is what you need
http://www.coilgun.info/theoryinductors/dampedoscillator.htm
hope this helps
Posted on Jul 14, 2010
My gas gauge in my 2002 Pontiac Bonnivile shows empty all the time
Fuel Gauge Troubleshooting
Fuel Gage
The IPC displays the fuel level as determined by the PCM. The IPC receives a class 2 message from the PCM indicating the fuel level percent. The fuel gage defaults to empty if:
• The PCM detects a malfunction in the fuel level sensor circuit.
• The IPC detects a loss of class 2 communications with the PCM.
When the fuel level is less than a pre-determined value, the CHECK GAGES indicator illuminates.
DTC P0462
The fuel level sensor changes resistance based on fuel level. The PCM monitors the signal circuit of the fuel level sensor in order to determine fuel level. When the fuel tank is full, the sensor resistance is high and the PCM senses a high signal voltage. When the fuel tank is empty, the sensor resistance is low and the PCM senses a low signal voltage. The PCM uses the signal circuit of the fuel level sensor in order to calculate the total remaining fuel (%) in the tank. The PCM sends the fuel level percent via the class 2 serial data circuit to the IPC in order to control the fuel gage. The fuel level information is also used for misfire and EVAP diagnostics
DTC P0463 (3.8L)
How to test fuel gauge tank sending unit P0463 GM
Mar 29, 2017 | 2002 Pontiac Bonneville
Firing order coil pack 2000 ford explore 5-0
Firing Order is 1 3 7 2 6 5 4 8
JF: Integrated Ignition Coil On Plug Coil 1 Through 10 Failure
2000 PCED On Board Diagnostics II
SECTION 5: Pinpoint Tests
Procedure revision date: 01/31/2001
? JF: Introduction
JF1 DETERMINE WHICH COIL IS NOT FIRING
    Note: Electronic ignition engine timing is entirely controlled by the PCM. Electronic ignition timing is NOT adjustable. Do not attempt to check base timing. You will receive false readings.
  • Determine which coil is not firing using information from Pinpoint Test JB or DTC and the table at the beginning of this pinpoint test.
  • Record cylinder, coil and PCM pin number from the table.
Have the cylinder number, coil driver and PCM pin number been recorded?
Yes
No
GO to JF2.
To obtain required information, GO to JF1 and REPEAT.
JF2 DTC P0351, P0356, P0357: CRANKSHAFT POSITION SENSOR FAILURE
Are any of the above listed DTCs present?
Yes
No
GO to JF3.
GO to JF4.
JF3 CHECK RESISTANCE OF CRANKSHAFT POSITION SENSOR
  • Measure resistance of crankshaft position sensor.
Is resistance between 290 and 390 ohms (for LS8 between 900 and 1300 ohms)?
Yes
No
GO to JF4.
REPLACE crankshaft position sensor. COMPLETE Misfire Monitor Repair Verification Drive Cycle (REFER to Section 2, Drive Cycles).
JF4 CHECK FUNCTIONALITY OF SUSPECT COIL DRIVER (CD) CIRCUIT
  • Disconnect suspect coil (determined from the table).
  • Connect incandescent test lamp between IGN START/RUN and suspect CD circuit (determined from the table) at the coil on plug harness connector.
  • Disable fuel pump by disconnecting inertia fuel shutoff switch.
  • Observe incandescent test lamp while cranking engine.
Is the test lamp blinking consistently?
Yes
No
KEY OFF. GO to JF5.
KEY OFF. GO to JF6.
JF5 CHECK FUNCTIONALITY OF SUSPECT COIL
  • Remove suspect coil (determined from the table) from spark plug.
  • Connect an air gap spark tester 303-D037 (D81P-6666-A) or equivalent to a suspect coil.
  • Reconnect suspect coil harness connector.
  • Observe spark tester while cranking engine.
Is the spark present?
Yes
No
KEY OFF. INSPECT spark plug, REPLACE if necessary. GO to Z1.
KEY OFF. REPLACE coil. INSPECT spark plug, REPLACE if necessary. COMPLETE Misfire Monitor Repair Verification Drive Cycle (REFER to Section 2, Drive Cycles).
JF6 CHECK IGN START/RUN VOLTAGE TO SUSPECT COIL
  • Key on, engine off.
  • Measure voltage between IGN START/RUN circuit at the coil on plug harness connector and ground.
Is voltage greater than 10.0 volts?
Yes
No
KEY OFF. GO toJF7.
KEY OFF. LS6 and LS8: GO to B5.
All others: IGN START/RUN circuit fault. CHECK condition of related fuses/fuse links. If OK, REPAIR open circuit. If fuse/fuse link is damaged, CHECK IGN START/RUN circuit for short to ground. REPAIR as necessary. COMPLETE Misfire Monitor Repair Verification Drive Cycle (REFER to Section 2, Drive Cycles).
JF7 CHECK SUSPECT CD CIRCUIT FOR OPEN IN HARNESS
  • Disconnect PCM.
  • Measure resistance of suspect CD circuit between PCM harness connector pin (determined from the table) and coil on plug harness connector.
Is resistance less than 5 ohms?
Yes
No
GO to JF8.
REPAIR open circuit. COMPLETE Misfire Monitor Repair Verification Drive Cycle (REFER to Section 2, Drive Cycles).
JF8 CHECK SUSPECT CD CIRCUIT FOR SHORT TO VPWR IN HARNESS
  • Measure voltage between suspect CD circuit at the PCM harness connector (determined from the table) and ground.
Is voltage less than 1.0 volt?
Yes
No
KEY OFF. GO to JF9.
KEY OFF. REPAIR short circuit. COMPLETE Misfire Monitor Repair Verification Drive Cycle (REFER to Section 2, Drive Cycles).
JF9 CHECK SUSPECT CD CIRCUIT FOR SHORT TO GROUND IN HARNESS
  • Disconnect scan tool.
  • Measure resistance between suspect CD circuit at the PCM harness connector (determined from the table) and ground.
Is resistance greater than 10,000 ohms?
Yes
No
GO toJF10.
REPAIR short circuit. If symptom or DTC is still present, GO to JF11 to check for damaged coil, otherwise COMPLETE Misfire Monitor Repair Verification Drive Cycle (REFER to Section 2, Drive Cycles).
JF10 PERFORM INTERMITTENT TEST ON SUSPECT CD CIRCUIT HARNESS
  • Connect digital multimeter between suspect CD circuit at the PCM harness connector (determined from the table) and CD circuit at coil on plug harness connector.
  • Wiggle and bend CD harness from PCM harness connector to coil on plug harness connector.
Did resistance fluctuate during wiggle test?
Yes
No
REPAIR intermittent fault in harness. COMPLETE Misfire Monitor Repair Verification Drive Cycle (REFER to Section 2, Drive Cycles).
REPLACE PCM. (REFER to Section 2, Flash Electrically Erasable Programmable Read Only Memory (EEPROM)). If symptom or DTC is still present, GO to JF11 to check for damaged coil, otherwise COMPLETE Misfire Monitor Repair Verification Drive Cycle (REFER to Section 2, Drive Cycles).
JF11 CHECK SUSPECT COIL FOR DAMAGE
Yes
No
Feb 14, 2015 | 2000 Ford Explorer
I have code P0118.wont i may start in just a min,the engine hesitate and going to stop
http://www.obd-codes.com/p0118
What does that mean?
The engine coolant temperature (ECT) sensor is a thermistor screwed into a coolant passage in the cylinder head. Sensor resistance is high when coolant temperature is low and resistance drops when coolant temperature increases. The powertrain control module (PCM) provides a 5 volt reference and a ground to the sensor. The PCM monitors voltage drop to determine coolant temperature. If the ECT reads less than freezing temp. when engine has been running for more than a few minutes, the PCM determines a circuit fault and sets this code. Or if the PCM determines the sensor resistance is out of specs, this code is set.
Potential Symptoms
Symptoms of a P0118 could include:
  • Very poor fuel economy
  • A no start condition
  • Vehicle may start, but run very poorly, blowing black smoke, running very rough and misfiring
  • Illumination of MIL
Causes
A code P0118 may mean that one or more of the following has happened:
  • A bad connection at the sensor
  • An open in the ground circuit between the ECT sensor and the PCM
  • A short in the voltage feed between the sensor and the PCM
  • A bad PCM (less likely)
  • A bad temperature sensor (shorted internally)
Feb 01, 2013 | Cars & Trucks
Engine runs rough if it warms up won't start dtc codes p0118 and p0113 just did head gasket and replaced exhaust manifold all new gaskets new plugs wires and coolant engine timing marks are all c
P0113 Intake Air Temperature Circuit High Input
Low temperature results in a high signal voltage. When the PCM sees a signal voltage higher than 5 volts, it sets this P0113 check engine light code.
P0118 - The engine coolant temperature (ECT) sensor is a thermistor screwed into a coolant passage in the cylinder head. Sensor resistance is high when coolant temperature is low and resistance drops when coolant temperature increases. The powertrain control module (PCM) provides a 5 volt reference and a ground to the sensor. The PCM monitors voltage drop to determine coolant temperature. If the ECT reads less than freezing temp. when engine has been running for more than a few minutes, the PCM determines a circuit fault and sets this code. Or if the PCM determines the sensor resistance is out of specs, this code is set.
Potential Symptoms
Causes
Jan 04, 2013 | 2003 Dodge Stratus
E70 error code on electrolux dryers inspire, it is working but dries the clothes to damp then this code comes up
Hi Nora King - Error code E70, typically means that there is a communication error with the outlet/inlet control thermistor that has an open or short circuit. You will need a certified professional to check the resistance of outlet/inlet control thermistor and check wiring for either short or open circuit.
Sep 17, 2012 | Electrolux Dryers
Am geting a code with this number p0118
OBD Code P0118refers to,
I hope this helps.
Jul 02, 2011 | 2000 Daewoo Leganza
What is diagnostic procedures for DTC p0135 & p0141
Oxygen Sensor problems... P0135 (Bank 1, Sensor 1) and P0141 (Bank 1, Sensor 2)
P0135 - Oxygen O2 Sensor Heater Circuit Malfunction (Bank 1, Sensor 1)
This code refers to the front oxygen sensor on Bank 1. The heated circuit in the oxygen sensor decreases time needed to enter closed loop. As the O2 heater reaches operating temperature, the oxygen sensor responds by switching according to oxygen content of the exhaust surrounding it.
The ECM tracks how long it takes for the oxygen sensor to begin switching. It the ECM determines (based on coolant temp) that too much time elapsed before the oxygen sensor began operating properly, it will set P0135.
Symptoms: You will likely notice poor fuel economy the illumination of the MIL.
Causes: A code P0135 may mean that one or more of the following has happened:
O2 Heater element resistance is high
Internal short or open in the heater element
O2 heater circuit wiring high resistance
open or short to ground in the wiring harness
Possible Solutions:
Repair short or open or high resistance in wiring harness or harness connectors
Replace oxygen sensor (cannot repair open or short that occurs internally to sensor)
P0141 - O2 Sensor Heater Circuit Malfunction (Bank 1, Sensor 2)
This code means that the heated circuit in the oxygen sensor on bank 1 decreases time needed to enter closed loop. As the O2 heater reaches operating temperature, the oxygen sensor responds by switching according to oxygen content of the exhaust surrounding it. The ECM tracks how long it takes for the oxygen sensor to begin switching. It the ECM determines (based on coolant temp) that too much time elapsed before the oxygen sensor began operating properly, it will set P0141.
Symptoms: You will likely notice poor fuel economy the illumination of the Check Engine Light.
Causes: A code P0141 may mean that one or more of the following has happened:
O2 heater element resistance is high
Note: Typically a failed catalytic converter does not cause this code. You're more likely to see a P0420 code for a failed converter.
Possible Solutions:
Hope this helps (remember to rate this answer)..
May 11, 2011 | 2000 Nissan Maxima
No power to fuel injectors
Determin if the injector operating:
  1. disconnect the injector electrical connector and measure the resistance of each injector with an ohmmeter. Compare the measurement with the resistance value Specifications are 11 to 18 ohms.
  2. Replace any injector whose resistance value does not fall within the specifications.
If the injector was not operating but the resistance reading was within specifications, the PCM Powertrain Control Module (PCM) or the circuit to the injector may be faulty.
Check the ignition fuse located in the engine compartment fuse center. Also. check the fuel pump relay.
Note: The fuel pump relay is located behind the radio in the center of the instrument panel.
If the relays are good and the fuel pump does not operate. check the fuel pump circuit. If the wiring and the connectors are
good, replace the fuel pump.
Nov 19, 2009 | 1999 Ford F250 Regular Cab
Nothing comes on
try the battery contacts,give them a rub with sandpaper in case they are tarnished.will camera work when on the charger,if it does you may have faulty battery
May 11, 2007 | Fuji FinePix 6800 Zoom Digital Camera
Plumbing Logo
70 people viewed this question
Top American Standard Plumbing Experts
Donni Steen
john h
TED
Level 1 Expert
Are you an American Standard Plumbing Expert? Answer questions, earn points and help others
