Creda excel 1200 water leaking out of where you put the washing powder.
  • nijono May 09, 2009
    same problem - started today. did you get it fixed?
5 Suggested Answers
COXY
  • 76 Answers
SOURCE: creda excel 1200 front loading washing machine
This will either be a blocked pressure vessel, or the brushes on the Motor. I am not sure where the pressure vessl is on this model But you will find it buy taking the top of and finding a round or oval shaped component with a plastic tube running from it. carefully pull this tube of and blow down it. it should be clear. unplug machine first.
Posted on Nov 19, 2007
  • 139 Answers
SOURCE: Creda excel 1200
Yes on these three wires you will see if you look carefully that they have written on them neutral ,, one ,,, two,,
these wires connect to the buttons on the front panel,, So if you find the one that says neutral on it... that one connects to the switch on the left hand side of the switch,, its the side that has a connection to the other switch by a small metal strip usually (but some times a wire connection is used ) the other wires connect to the other side of the switches number one connecte to the top switch and number 2connects to the buttom switch i hope this helps....
any probs let me know...
Posted on Jan 17, 2008
SOURCE: water is leaking out of the washing powder drawer
the spray holes in the soap manifold are partially blocked and spraying at an angle. try to reduce the water flow pressure at the feed tap and clean the water holes in the soap tray manifold (above the tray).
Posted on Feb 16, 2008
  • 1462 Answers
SOURCE: Creda Excel 1200 W120VW Front loading washing machine
check motor brushes for a start
Posted on Jul 04, 2008
barkencoa
  • 3463 Answers
SOURCE: Manual for Creda Excel 1200 W120VW
In your browser bar type in:
HOTPOINT USER MANUAL and follow the links.
You will find what you are looking for.Although it says Hotpoint, just type your model in the box, and it will come on screen, then you can save it, or download it to your printer
Plz rate my solution.
Thanks
Posted on Dec 16, 2008
How do i put door on again on creda excel 1200 as it has come off hinges
sounds like maybe you just sit the door on those pins and close it
Jun 04, 2014 | Creda W120VW Front Load Washer
Fabric drawer section fills with water after every wash
the siphon cap in the fab con section of the draw is blocked the water is drained away by using a siphon remove the draw from the machine you should see a up-stand with a removable cap on it take it of and clean all the gunge out
Feb 26, 2014 | Creda Washing Machines
Can my creda excel 1200 be converted to fill with hot water instead of cold water
Unfortunately it will need cold water for the rinses. Also it controls the temperature of the (hot) water itself which it would not be able to do if fed with water that was too hot- for delicates for instance ;-0(
To use your hot water would require a hot AND cold fill washer, sorry!
If this has assisted and/or clarified the situation for you please consider a 4 thumbs up on our rating.
Thanks and good luck!
John C
Jul 09, 2011 | Creda Washing Machines
Excel 1200 water coming out of power drawer
try cleaning the filter located at the bottom of the machine in a small access door
Mar 01, 2009 | Washing Machines
Creda Washing Machine Detergent Dispenser not emptying
does the detergent get wet?
may be the blue trap door that is behind the detergent in the drawer is set for liquid detergent ie 'closed' and needs to be set to open to allow the powder past. or the holes above the detergent section where the waster comes out are blocked so water goes in another route.
you could always put the powder straight in with the wash to get yourself out of trouble.
Feb 03, 2009 | Washing Machines
Thanks
Dec 15, 2008 | Creda W120VW Front Load Washer
Creda W100FW will not take the powder from dispencer and stops during wash
check water supply is on, also you can get low pressure which can cause this problem you could try tablets. and poss your brushes are worn out
Mar 02, 2008 | Creda W100FW Front Load Washer
Creda excel 1200
Have you checked the dishcharge hose inside. Sound like you might have a break in the line somewhere.
Feb 13, 2008 | Creda W120VW Front Load Washer
Washing Machines Logo
107 people viewed this question
Top Washing Machines Experts
Richard Roth
Richard Roth
