Question about Nintendogs: Dalmatian & Friends for DS
I don't get any icons and the names of my dogs are a different color and the first time I turned it on it started all over right back to the begining. I don't know what to do. The game was used so that might have something to do with it and I know it's nothing to do with my ds because I tryed it on 2 dses. What do I do? I need help!
ShadowLinkx
  • 3 Answers
SOURCE: New game first dog keeps forgetting its name
Dogs can't die on Nintendogs.
And for your problem, perhaps you should speak alittle louder and clearer. If that doesn't work it could be a flaw in the game card.
Posted on Sep 15, 2008
rat tails 57
  • 11 Answers
SOURCE: Ds-how do you do multiplayer on eragon ds game
you cant use a connecter cable for ds you need to go to the multiplayer screen and have the other ds go to the ds download screen and you all should instantly connect up if not you need to make sure that the other person clicks on the little row that has the eragon name to it.
Posted on Feb 01, 2009
SOURCE: Nintendo DS start up menu disappeared.
take out all of the games in the ds then the menu should come up then click the little ds picture at the bottom. that will take you to another menu. click on the wrench in the pink box, then click the top box which has an arrow pointing into a box. click the top box which says manual mode then press confirm. the ds will go off then when you turn it on it should go to the menu even with a game in. hope this helps! =)
Posted on Feb 10, 2009
SOURCE: Dog has learnt its name and first command. Now it won't come
u have to say to the dog hdhehulej
Posted on Feb 23, 2009
  • 10 Answers
SOURCE: no icons with nintendogs
well its a new game system its not going to work the same ....... the dogs game has been out for a while and D.S i is new .... i have a D.S game that has a sticker on the front that says ABLE TO BE PLAYED IN D.S i......... you may have a game thats not compatible with the D.S i because its older than the games that are new ... try putting a new game in ur new system and then answer bacK THANK YOU
Posted on Dec 27, 2009
Model # 64 60 viking sewing machine looking for manual for sewing leather or canvas which cam to use in it
As to your question about leather, the 6460 has a special stitch for sewing leather. Select Colormatic cam C and install in the cam hole at the back of the machine. To remove/add a cam turn the upper left hand dial on the front of the machine to the small dot. This disengages the cam. Gently remove the cam by pulling straight out from the back of the machine. Install cam C straight in, ever so slightly twisting it back and forth into the hole to find the sweet spot. You'll hear a click when it's all the way in.
To use Viking's leather stitch, turn the upper left dial to the color yellow. (Note: The slash line on the upper left dial is a stop. You can't turn past that point. Go in the other direction to get to the icon or color you want.) Turn the upper right and bottom right dial to yellow also. The upper left dial is what selects the particular stitch on the cam, the leather stitch in this case. The upper right dial selects stitch length, and the lower right dial selects stitch width. You can move the right dials within the color range. Experiment on a scrap of cloth to get the stitch size the way you want it. The leather stitch looks like a straight stitch with a block style edging to the right of the straight stitch. This is supposed to give a stronger stitch to the leather rather than a straight stitch by itself.
If you don't have the manual for your machine: Select which of the eight cams you want to use. All the cams are removed/installed by turning the upper left dial on machine front to the small dot. At the rear of the machine, pull/insert cam straight in or out and twist slightly as you push in or remove to find the sweet spot. Move the dial away from the small dot to lock the cam in.
Turn upper left dial to stitch type you want and match the other dials to that same color. Upper right controls stitch length, lower right controls width. Bobbin tension is controlled by the dial at front left of the machine, above the needle.
Cams A-C are the workhorse cams and the rest are embroidery stitches.Straight stitch, button and stitched zig-zag will work on any cam. These stitches do not rely on matching a color code. To use those three: To select straight stitch, on the upper left dial, choose the icon that looks like a buttonhole with a zig that trails off to the right. Select stitch length on upper right dial and turn the lower right dial to zero, going by number rather than color.
To select stitched zig zag, turn upper left dial to the broken zig zag icon (to the right of the straight stitch icon). Select stitch length and width.
To move the needle to the side for buttonhole stitching or other times when you want the needle off center, turn the upper left dial to the button icon. If stitching a button hole, set stitch length to zero and lower right dial to desired stitch width. Push in the small white button that's beneath the lower right dial in order to prevent the feed dogs from moving the fabric forward. Pushing that button in is also handy for putting cloth under the foot before sewing as it prevents snagging and is used for tacking.
Jun 06, 2011 | Husqvarna Sewing Machines
How do i restore my garmin nuvi 205 to its original factory settings? i have selected a foreign country by accident as default
With the satnav turned off press the bottom right corner of the screen and turn it on. This brings up an option to reset it. There may be an easier solution however that will not lose you your favourites etc. I presume the problem is that it's in a different language and you want it back to English. Resetting it will not do this. To get back to English;
  • Press TOOLS (The spanner symbol on the bottom right corner of the screen which shows WHERE TO and VIEW MAP) This may take some trial and error if it's in a foreign language but should be possible)
  • Press SETTINGS (The spanner icon) or LOCALE (the blue icon) on some models that don't have a settings menu)
  • Press LANGUAGE (the lips icon)
This brings you to a screen with 3 items; VOICE, TEXT LANGUAGE and KEYBOARD. Press each one in turn and select English or American English if you're in the USA. With the VOICE setting you may have to select a name rather than English. If so select the name of a person from an English speaking country.
I hope this solves your problem.
Jun 02, 2011 | Garmin nuvi 205W GPS Receiver
Elna Envision 8007 feed dogs dropped and can't get get them to go back up ...the switch doesn't make a difference. Had this problem before and thought it was fixed. This is the first time I needed to...
Have you actually starting stitching a seam after sliding the feed dog control back to normal position?
In most cases, the feed dogs don't magically pop up until the machine has moved through a stitch sequence.
Put a piece of fabric under the pressure foot, lower the pressure foot, then turn the flywheel towards you two or three turns or use the needle up, needle down control button to make a couple of stitches - this should get them back.
Apr 15, 2011 | Elna 8007
When you first get Nintendo dogs do you have to earn the supplies and go out list?
The first part of the game is a training session and you won't see the extra icons until you have finished training. Basically you have to name it and then keep calling him so he recognises his name again and again! Then you will be invited to train him to sit, when you do this an icon in the top right will appear when you click it you record 'sit down'. Again you have to do this lots of times until your dog gets it then the game will move on and you can feed it etc. Good luck!!!!
May 20, 2010 | Nintendogs: Labrador & Friends for DS
Nintendogs - icons has disappeared!
dont know her friend might of turned it of while it was saving turning the game saved data to scramble :/ u might need to start again sorry :l hope i helped (:
Jun 17, 2009 | Nintendogs: Labrador & Friends for DS
I bougt my dog in nintendo dogs and gave it a name but it forgot
its normal you just need to tap the picture of the human patting the dog a couple times
and start patting it then a little question mark will appear inside a speech bubble
and then you tap it say its
name keep on continuously do that and your dog will get its name right.
Apr 26, 2009 | Nintendogs: Dalmatian & Friends for DS
Training icon wont appear
at base, press the hand icon and call pet's name over and over until your dog remembers it's name. rub pet's head and swipe down with stylus or finger. press icon (?) in upper right corner. recording will start, tell dog to sit (several times) and stores and items should unlock. care section in items category will have books for tricks and care tips.
good luck!
Jan 03, 2009 | Nintendo DS Console
No icons on Nintendogs
my copy is new and i have the same problem
Mic
At the very first beggining, when you come in with your 1rst puppy, follow the instructions. When it says to give your puppy a name, you will have the mic icon in the middle of the screen. Tap with your pen and then say the name, but not too far of your DS. You will see, during you say the name, like a colored "timer" on the mic icon. For the tricks, when your puppy is doing a thing, for exemple, sit or roll over, a bulb icon with show off in the up-right corner of your touch screen. Tap it with the stylus, and do the same thing : say the name of that trick ( ex."roll over"). You will see the colored mic timer and your puppy will save the information with little stars around its head. You have to repeat it like 4-5 time before it really knows it and do it again. It depend on the puppy ( some are 3-4 time, some more...) I hope it answered your question. You can visit this site http://www.gamefaqs.com/portable/ds/file/928837/39820 you have a whole section on the very beggining.
It's hard sometime...I just passed 30 minutes to get the dog a name he remembered...Choose a name that you can repeat with the EXACT same intonation.
Dec 30, 2008 | Nintendo DS Console
Nintendogs: Dalmatian & Friends for DS Logo
114 people viewed this question
Top Nintendo Video Game Consoles & Games Experts
Raj Patel
Julian Wainwright
juanmireles1
Are you a Nintendo Video Game Console and Game Expert? Answer questions, earn points and help others
