Question about Kenmore 73503 Stainless Steel Bottom Freezer Refrigerator
My kenmore refrigerator is not cooling,, I check the capacitor is good,, check the relay is good,, but I want to check if it needs freon,, but I can't find the ports for it,, can somebody help me please, thank you.
  • 744 Answers
There are no charging ports on the unit. If the unit is not cooling, check the freezer fan to be sure it's working first. Is the compressor running? Is the thermostat set to call for cooling? Is the defrost cycle ok? Is the condenser clean? Is power ok?
If there is a leak, you will need to install a line tap valve, recover the refrigerant from the unit first, repair the leak, install a permanent charging port, pull a vacuum, and then re-charge the system. Adding a charging valve or working on refrigeration appliances is not simple and requires EPA certification (in the USA).
If the appliance is over 10 years old, you may want to weigh repairs against the cost of replacement.
Posted on Jul 14, 2010
Kenmore refrigerator 106.7200 makes rattling noise
i WOULD CHECK THE COMPRESSOR RUBBER GROUMETS AT BOTTOM OR CHECK FOR LOW FREON LEVEL NEXT CHECK FOR CONDENSER FAN NOISE OR BLOCKAGE.
ARE U SURE ITS NOT A CLICKING SOUND OTHER WISE IT COULD BE BAD START RELAY OR CAPACITOR/
Nov 04, 2016 | Kenmore Washing Machines
I have a samsung fridge/freezer. Production date 2007. Model#RS20NRSV5/XSA both the fridge an freezer not getting cold The lights are on but no cold air.An cant hear anything working at the back.
Your compressor is not working that's why its not cooling and you cant hear anything.
Possible cause:
  1. thermostat is set to off or defective
  2. defective capacitor that's why your compressor failed to run.
  3. defective compressor motor
  4. Freon leak or no freon at all.
Solution:
  1. check thermostat switch or relay
  2. check capacitor and wiring.
  3. check compressor motor.
  4. Check Freon pressures.
May 11, 2016 | Samsung Refrigerators
I have a kenmore refrigerator that is not cooling. I found that when I take the production capacitor out of the circuit and jump the two wires together, that go to the capacitor, the comp runs. I bought a...
Your system works with a capacitor and contactor-relay to start the compressor. If you replace the contactor-relay that should solve your problem, if the compressor is okay.
Sep 20, 2011 | Kenmore 50522 / 50524 Side by Side...
My refrigerator is not cooling or freezing anymore
If the compressor is running, there may a refrigerant leak and if not the starting relay may have gone bad. if you can fix yourself, check starting relay and capacitor if there is one (capacitor). If you cannot fix yourself, call a serviceman.
Dec 21, 2010 | Kenmore 57029 Side by Side Refrigerator
Our fridge is running but it is not staying or getting cold. Things are starting to thaw in the freezer. Is there a way to put in more freon?
Many times a freezer and/or refrigeratordo not work right because of a dirty condenser coil...there are also many otherthings that can go wrong. If you are hearing a clicking or buzzing then check out thelast two tips.
If your refrigerator is running but warm, then...
Check out this tip that I wrote about that... it is a great place to starttrouble shooting your unit...and something that you can do rather then callinga repair person to do a simple thing for you...
Refrigerator Condenser Coil Cleaning Refrigerator Repair
Refrigerator Troubleshooting Refrigerator Compressor
Refrigerator Compressor Start Capacitor and Start Relay
Refrigerator or Freezer not Cooling or Getting Cold
heatman101 .
Oct 11, 2010 | Kenmore 50522 / 50524 Side by Side...
My Kenmore side by side doesn't freeze or cool. The fan motor still runs but the "freon motor" makes a buzzing noise when trying to run. Is there a fix or is it time to buy a new freezer. This unit was...
heatman101
Sep 15, 2010 | Kenmore 53642 / 53644 Side by Side...
Not getting cold enough to freeze, How to check Freon
heatman101
Jun 05, 2010 | Kenmore 53082 / 53084 Side by Side...
Kenmore side by side fridge
It sounds like your compressor is having trouble starting, and over heating. this could be one of the following
  1. start relay is bad
  2. run capacitor is bad
  3. compressor run/start winding burned out
Try unplugging the unit for a few hours to let the compressor cool down. Then plug it back in and see if the compressor starts. If it starts after it has cooled down, then it is likely out or low on refrigerant. If its low or out of refrigerant it will run until it over heats, then kick out on thermal overload. This is because there is not enough cold refrigerant being pulled back into the compressor to keep it cool.
Jan 28, 2008 | Refrigerators
Kenmore fridge not cold
You might have to have a repairman check the charge of freon in the system.
Nov 27, 2007 | Kenmore 55612 / 55614 / 5561 / 655619 Side...
Kenmore 73503 Stainless Steel Bottom Freezer Refrigerator Logo
131 people viewed this question
Top Kenmore Refrigerators Experts
Sal De
Jim Goldsmith
Jim Goldsmith
acrman404a
Level 1 Expert
Are you a Kenmore Refrigerator Expert? Answer questions, earn points and help others
