Question about Asko W6021 Front Load Washer
Washer not spinning properly
After the washer finish there is a F4 in the glass window and the clothes are not beenspum properly
  • 713 Answers
Hi, there may be excess water in the water reservoir. Empty the washer Turn it off at the mains, and unplug it, then put some old towels on the floor, tip the washer forward until the excess water comes out. Reconnect and try again.
Posted on Jul 13, 2010
I have a aeg washer/dryer- it washes fine but then I have problems drying Any idea how I can solve this? problem
Please start with your clothes after the washer finishes it's washing cycle.
Take them out and see how dry they are.
They should be nearly dry.
If not, perhaps the reason you are having problems is they are too wet to begin with for the dryer to properly do it's job..
This is not a rare problem.
One possible reason for the clothes not to be dry when the washer finishes is a loose or worn out belt under the washer.
Another problem some washers have, particularly washer/dryer combos, is that they are sometimes not very effective.
In that case, either smaller loads or rerunning the spin cycle at the end of the washing cycle might help you.
God bless your efforts.
Nov 30, 2015 | AEG Washing Machines
My front load washer will not spin on the final spin cycle. Washer spins in wash and rinse cycle spin. Cloths are still soaking wet.
I appreciate your post, Rachel Kovach!
From my understanding your Frigidaire frontload washer is not spinning the final spinning and the clothes are still wet. If you washer is overloaded it will not spin properly to release the water out of the clothes. Also, a small load will cause your washer to not spin properly. You should additionally check the drain hose to make sure it not kinked or twisted that could cause your improper draining. If all that checks properly it could be an issue with your drain pump, motor, and control panel. I would suggest consulting with a technician for proper diagnosis and repair. This will help avoid unnecessary part purchases. -Matt
Nov 19, 2014 | Frigidaire Washing Machines
Clothes are sooaking wet when cycle finishes and they smell bad
The wetness is due to the spin cycle either not working properly or not being allowed to finish. For the smell, with the washer empty, run a cycle on hot/whites with bleach only, after the first cycle drains, open the washer and add more bleach directly into the washer.
Apr 20, 2009 | Maytag MAH6700AWW Neptune Front-Load...
Clothes wet at program finish
The clothes are wet after spinning When the clothes are wet at the end of a cycle, check these:
Motor coupler
Spin cycle
Siphoning
Water-inlet valve
Motor coupler To test the motor coupler, re-start the washer in its spin cycle. Let the machine run for a minute, and then open the lid and notice whether the tub is spinning:
  • If it's spinning when you lift the lid, the coupler is fine.
  • If it isn't spinning--and your machine was produced by Whirlpool®--you may have a broken coupler. Many Whirlpool-made washers use a small, relatively inexpensive device called a motor coupling. This plastic-and-rubber component is mounted to the shaft of the motor on one side, and to the transmission on the other. Over time, the coupler wears out and fails. When that happens, you need to replace it completely.
Spin cycle If the washer doesn't reach its proper spin speed, the clothes may be too wet at the end of a cycle. Check to be sure the load is properly balanced and run a spin cycle again. If the clothes are still wet, you may have a worn or loose belt (Maytag®), a worn clutch (GE®/Hotpoint®), or a worn motor pulley or tub bearing. Replace the applicable component.
Alternatively, there could be clothes caught between the inner and outer tubs. Read the "It spins but won't pump" section of the "It won't drain" section. Also, there could be other things that cause friction on the drive train. Seek the assistance of a qualified appliance repair technician.
Siphoning If the water that pumps from the machine goes right back into the machine after the spin cycle, it may be because your washer is siphoning the water from a laundry tub with a slow drain, back into the washer. Try to improve the draining of the laundry tub. (Is there something stuck in the drain?) Also, be sure the drain hose doesn't reach more than about 4 inches into the laundry tub. If it does, cut off the excess.
Water-inlet valve Water-inlet valves eventually fail. One problem that may develop with a water-inlet valve is that it can no longer completely shut off when the electricity is turned off to it. Then, the valve may leak and drip water into the clothes tub--you may notice that your washer has water in it when you haven't used it for a few days. To fix this, replace the valve.
Apr 01, 2009 | Bosch Washing Machines
Model 110 washer will not go into a final high speed spin.
hi, i would suggest the timer/programmer is faultyas it is ok on the other cycles, the noises you have described may have caused some damage,
Feb 10, 2009 | Washing Machines
Kenmore Top loading washing machne F4 error. (110.20052994)
It spins, but doesn't pumpIf your washer spins but doesn't pump the water out, the drain line is probably clogged. In many washers, a small sock or other piece of clothing can get between the clothes tub and the outer tub that holds the water. If the clothing gets between the tubs, it may then get into the drain hose that's attached to the pump--or even into the pump itself. If it's in the pump, you need to remove the hoses from the pump and pull the item out.
To remove the sock from the outer tub port, open the washer's main access panel and remove the large-diameter rubber hose that connects the pump to the bottom of the outer tub. Then, using needle-nose pliers, try to grab and remove the clothing through the port.
Sometimes you can't remove the stuck clothing from below. Then you have to remove the agitator, top of the outer drum shield, and inner clothes tub. This isn't easy to do--and you may need special tools--so you might be happier getting a qualified appliance repair technician to do the job.
If the drain line isn't plugged, the problem may be with your pump. Even if the pump appears to be turning, the internal impeller may be broken. If so, you need to replace the pump.
It doesn't spin or pump
If your washer doesn't spin or pump water out but the motor is running, your washer probably has a frozen pump pulley. If so, you need to replace the pump. To check the pulley, remove the pump from the washer and try to rotate the pulley manually. If it doesn't turn freely--if it's frozen or stiff--replace it.
It pumps, but the water returns
If the water that pumps out of the machine goes back into the machine after the spin cycle, your washer may be siphoning the water from a laundry tub that has a slow drain, back into the washer. The usual remedy for this is to improve the draining of the laundry tub. (Is something stuck in the drain?) Also, check for these problems:
If the drain hose reaches more than about 4 inches into the laundry tub, cut off the excess.
If your drain hose is lower than the washer's cabinet, install an air gap/siphon break assembly.
Nov 30, 2008 | Kenmore 22422 Top Load Washer
Spin cycle not working properly, clothes still wet!!!!
Motor coupler Totest the motor coupler, re-start the washer in its spin cycle. Let themachine run for a minute, and then open the lid and notice whether thetub is spinning:
  • Ifit isn't spinning--and your machine was produced by Whirlpool®--you mayhave a broken coupler. Many Whirlpool-made washers use a small,relatively inexpensive device called a motor coupling. Thisplastic-and-rubber component is mounted to the shaft of the motor onone side, and to the transmission on the other. Over time, the couplerwears out and fails. When that happens, you need to replace itcompletely.
Spin cycle Ifthe washer doesn't reach its proper spin speed, the clothes may be toowet at the end of a cycle. Check to be sure the load is properlybalanced and run a spin cycle again. If the clothes are still wet, youmay have a worn or loose belt (Maytag®), a worn clutch (GE®/Hotpoint®),or a worn motor pulley or tub bearing. Replace the applicablecomponent.
Alternatively, there could be clothes caughtbetween the inner and outer tubs. Read the "It spins but won't pump"section of the "It won't drain" section. Also, there could be otherthings that cause friction on the drive train. Seek the assistance of aqualified appliance repair technician.
Siphoning Ifthe water that pumps from the machine goes right back into the machineafter the spin cycle, it may be because your washer is siphoning thewater from a laundry tub with a slow drain, back into the washer. Tryto improve the draining of the laundry tub. (Is there something stuckin the drain?) Also, be sure the drain hose doesn't reach more thanabout 4 inches into the laundry tub. If it does, cut off the excess.
Water-inlet valve Water-inletvalves eventually fail. One problem that may develop with a water-inletvalve is that it can no longer completely shut off when the electricityis turned off to it. Then, the valve may leak and drip water into theclothes tub--you may notice that your washer has water in it when youhaven't used it for a few days. To fix this, replace the valve.
More information can be found here:
http://www.repairclinic.com/0088_11_1.asp#Level1_12
Oct 29, 2008 | Kenmore 24032\24036 Top Load Washer
GE washer, does not spin
You probably broke the 4 black snubber straps on the top of the tub lid and it is cousing your washer to always be off balance and not reach a full speed spin
Oct 30, 2007 | GE WBSR3140DW Top Load Washer
Asko W6021 Front Load Washer Logo
117 people viewed this question
Top Asko Washing Machines Experts
Gerry Harvey
Gerry Harvey
Joseph Hoffmann
marley mcelhinney
Are you an Asko Washing Machine Expert? Answer questions, earn points and help others
