Question about kawasaki Primer Bulb Pump Kawasaki Trimmer Blower Td 18 24 Tg33
What is the correct fuel mixture for TG33? - kawasaki Primer Bulb Pump Kawasaki Trimmer Blower Td 18 24 Tg33
  • 63 Answers
50;1
Posted on Jul 24, 2010
Small engine problem. I have a 3.5 hp Briggs and Stratton engine that runs very roughly. The fuel mixture screw makes no difference, all the way open or all the way off. The model is 91212 0196 01.
Are you running the correct fuel and when was the last time the spark plug was replaced? I think that engine could be a Two Stroke so it's a fuel AND oil mixture. A local lawnmower repair man would be a good person to ask about that. Get the mixture screws back to where they should be and refill it with the correct fuel. Running the wrong fuel will kill the engine.
Oct 25, 2017 | HP Measuring Tools & Sensors
Need fuel tank for homelite TG33.
try e-bay , mower shop that handles homelight or homelite on the net.
Aug 03, 2015 | Homelite Garden
Correct fuel mixture for homelite zip start weedeater.25cc,ut20785..
50:1 five liters unleaded petrol and 100ml 2 stroke oil
Sep 09, 2014 | Homelite Garden
Fuel mixture for mcculloch mt 280 strimer
Fuel mixtures can be viewed at the included links.
You may contact the manufacturer, download manuals, check fuel/oil ratios, order parts, find your local service center, and view other resources using these links:
Contact us
What is the correct fuel mixture for McCulloch products Chainsaw Trimmer...
User manuals McCulloch Service
I trust this information proves beneficial.
Jan 22, 2014 | McCulloch Lawn Care: Trimmer Plus...
Fuel mixture
Use the provided link for fuel/gas mixture.
Contact us
User manuals
McCulloch Service
McCULLOCH PARTS ACCESSORIES
I trust this information has proven beneficial.
Apr 21, 2013 | McCulloch Mcc1635a 16-inch 35cc 2-cycle...
My machine overload,what do i do.the cilinder gets oil and the sparkplug is wet
Marthadelafu:
Remove the spark plug and clean it with rubbing alcohol and let it dry or blow dry it. Look at the carburetor. You will see two small screws next to each other. Those are the fuel/air mixture screws. one controls fuel, the other controls air. First check the air filter to see if it is clogged with dirt and debris... if it is, wash it in a soap and hot water solution and let it dry. After it dries out, reinstall it. Then turn the air/fuel mixture screws in GENTLY all the way. Turn them out one and a quarter turns. Check your fuel/oil mixture to see if you have the correct ratio of oil to fuel (most machines run on a 40/1 ratio... 40 parts gas to 1 part oil in other words, 40 ounces of gas to 1 ounce of oil. If your fuel/air mixture screws are one and a quarter turns out, the fuel/oil mixture is correct and the air filter is clean, the motor should start. You will need to adjust the fuel/air mixture screws a little to get the saw running to your satisfaction.
Jan 18, 2013 | Poulan Garden
1998 toyota sienna failed h c on emisson test
High HC counts are due to a rich mixture, too much fuel. How does the truck run normally? To adjust the fuel mixture at the carburetor, make sure the truck is at operating temperature. Turn the idle mixture screw clockwise until the engine starts to lag then turn the screw back just until it runs smooth. Also make sure you have fresh oil as this could cause high HC's as well since fuel gets into the oil and make sure your PCV valve is operating correctly. If you can't get it adjusted correctly, you may have to pay a shop to hook it up to the emissions machine to get the mixture correct, unfortunately.
Hope this helps. Good luck!
Nov 14, 2011 | Toyota Cars & Trucks
HIGH HYDRO CARBON EDELBROCK 1406 PERFORM 1500 MAN TRAN FAILD EMISS HIGH RPM ONLY
Apr 09, 2011 | 1985 GMC C1500
What is the correct fuel mixture for this machine
Every Stihl I have ever touched requires 40:1 fuel mixture.
Jun 02, 2009 | Garden
My homelite yardbroom 2 won't start. Maybe wrong gas/oil mix
Hi
If you remove the fuel you believe to be the mixture out of the fuel tank and refuel with the correct mixture then remove the air filter. Put a few drops of the correct mixture in to the intake it should start. it may take a few times of repetting putting the fuel in to the intake, but eventually it will clean out the bad fuel and run good.Remember to replace the air filter!
Apr 24, 2009 | Homelite 'Yard Broom' Leaf Blower
kawasaki Primer Bulb Pump Kawasaki Trimmer Blower Td 18 24 Tg33 Logo
461 people viewed this question
Top kawasaki Garden Experts
Jim Parker
Jim Parker
Joseph Mueller
Joseph Mueller
Phil Walker
Phil Walker
Are you a kawasaki Garden Expert? Answer questions, earn points and help others
