Question about Soleus KY-34 Portable Air Conditioner
Why does my unit work for 1 hour and shuts down?
Since I bought the unit it never worked for more than 1 hour.. The plug/adaptor becomes hot and then it cuts off..
My laptop shut down every one hours Exactly
Remove the battery and use the laptop with the adaptor plugged in to check if it still shuts down after one hour. Do a similar test with the fully charged battery installed and the adaptor NOT plugged in. If no problem with both tests there may be a problem with the charging circuit or possibly the battery.
Feb 28, 2014 | Acer Aspire 5516-5063 Notebook
It keeps shutting itself off ?
When does it shut itself off? Is this happening time you press the power button and during the boot cycle it shuts off without completing the boot to windows? If it shuts down after you've worked on it for a while it could be that it is running hot. If you let it sit a while to cool off then press the power button, if it completes the boot cycle and allows you to work it is definitely running hot. Normally when they run hot if you immediately try to reboot, it will fail. If you let it cool off it will boot successfully. Computers run hot because of a fan not working, dust clogging the fan vents or the Thermal Paste around the CPU and Heat Sink has become hard or too thin to keep the unit cool. If it's not running hot you might have a power supply or motherboard issue. Try removing the power cord and press and hold the Power Button for 30 seconds to release any Static Buildup. Then plug the power cord back in and try to reboot.
Mar 18, 2012 | Dell OptiPlex GX280 PC Desktop
My nes wont even turn on, used to work just perfect
Have you checked your power adaptor if it has become faulty. some time the plug end maybe faulty or the unit. leave it on for an hourand feel if the unit is worm some times this indecate if it is working and it may be a cable issue. New Adaptors are found at http://www.gameoz.com.au/store/nintendo-entertainment-system/nes-accessories/nintendo-nes-power-adaptor-brand-new.html
www.gameoz.com.au
Mar 11, 2010 | Nintendo NES Console
The fridge gurgles and won't cool in a/c or gas.
If the fridge is "gurgling" then there is one of two problems. Either you have a bad thermistor, which is not allowing the fridge to cool down properly, or your cooling unit is becoming plugged. If you run the unit on gas and get no check light, remove the outer cover and place your hand on the cooling unit, if it is just too hot to keep your hand on, then move your hand up the back. Feel the unit to see if there is a spot where the cooling unit begins to cool off. If so, that is where your blockage is.
There is also the possibility of air bubbles in the system. There is a procedure known as "burping" the unit but it is quite extensive and time consuming.
1. Remove the fridge from the unit, paying attention to electrical connectors and being sure to shut off the gas line and remove it from the fridge.
2. Pull the fridge onto the floor in the unit (providing there is room) and lay it on it's right side. Let it set for 8 hours and then turn it on its top for 8 hours and the its left side for 8 finally standing it back up.
This procedure will burp the air bubbles out of the unit and allow it to work correctly.
Hope this helps,
Jeff
Jul 07, 2009 | Dometic RM2652 Refrigerator
Cigarette lighter adaptor becoming very warm in use
the lighter receptacle is dirty and needs cleaning
Mar 23, 2009 | Tomtom ONE XLS Car GPS Receiver
Denon avr-2106 getting hot shutting down
Normally when this happens it is because the impedence load is too small. This unit requires 8 Ohm speakers. If you connect 4 Ohm speakers, it will work, but work harder and generate excessive heat. If the heat is too much, the unit will enter protect mode and shut down. Once it cools off, it will work again. In your case, if the speakers are the correct impedence, check for crossed wires. If that is the problem, running the unit at higher volume levels should cause it to shutdown sooner.
Keep us posted,
Dan
Mar 10, 2009 | Denon AVR-2106 Receiver
Shutdown and DVD Player problem
Hi, as this is a new unit I recommend you return it to your point of purchase and have the problem addressed under waranty.
regards mistyman
Aug 14, 2008 | Toshiba Computers & Internet
Notebook smells like burning plastic.
cud be your onboard voltage regulator for the battery charging. if you remove the battery and use the external power source does it smell also?
if the battery charges normal out of the unit, and the laptop works well with the AC power unit without the battery, then it's your voltage regulator for the batt charging
Mar 17, 2008 | Computers & Internet
Dehumidify mode also cools
Some units do cool/dehumidify only im afraid why cant you let the unit dump its hot air into the room then it wont heat or cool the room?
Sep 03, 2006 | Danby DPAC9031 Silhouette 9,000 BTU...
Soleus KY-34 Portable Air Conditioner Logo
27 people viewed this question
Top Soleus Heating & Cooling Experts
Coss
Dennis Boxerman
Harjeet Singh
Are you a Soleus Heating and Cooling Expert? Answer questions, earn points and help others
