Question about Yamaha R-V1105 Receiver
R-V1105 amplifier ICs ASICs
Can you point me to where I could find the correct replacement amplifier ICs? Google searching has shown me that they are ASICs but can't find anything beyond that.
  • i802206 May 17, 2008
    Have the same problem with my Yamaha R-V1105. And also want to find out where and how much a replacement IC would be. As far as I can tell, the R-V1105 has one IC for all functions and its a so called ASIC (Application Specific Integrated Circuit), with Yamaha part number: YSS-918. I got that info from the official www.yahama.com web site. However, I've googled-searched for that part number on a dozen or so sites but with no luck. Can any one help?
    Genius:
  • Yamaha Master
  • 1,550 Answers
Can you give me the numbers of the IC.
Posted on May 05, 2008
  •  Francisco Mauricio G
    Francisco Mauricio G May 22, 2008
    Go to http;//www.loadparts.com/index.asp there you can find him.Good luck.
My repairer just misplaced the ic for stereo integrated amplifier su-v50 class AA. So please help me with the ic number
A search with Google shows no such number. If this is truly a Class A amplifier, in my experience, there are no output ICs. Even so, unless they process both channels in one IC, there would be a complementory IC on the other channel.
Jun 26, 2015 | Audio Players & Recorders
I have a green line converge issue i can't get it to line up, i get it close then th red line moves out of wack. The right side of the picture starts to look 3D. What can I do
Convergence issue, if you cannot fix it by convergence adjustment, is un-doubtedly due to malfunctioning STK amplifier ICs. There are two of them that need to be replaced . They are located behind large aluminium heatsinks as shown in the image below.
http://media.photobucket.com/image/deflection%20IC%20heatsink/bretski_fc/tv/IMG_4335.jpg
The ICs can be purchased on ebay by using the IC numbers in your set as search keyword. You will have de-solder the old ones, apply silicon based thermal grease to the replacements and solder them into the board. Note that you have to make sure that they are making good contact with the heatsink when you replace them. You will also need to test and replace any resistors that the ICs may have taken out when they have gone bad. I hope you know how to use a multimeter(or ohm-meter) and can read resistor color codes.
http://media.photobucket.com/image/resistor color code chart/Live4soccer7/360fullres/resistor_color_code_chart.jpg
If there is any thing else you would like to know, please let me know.
PS: Bad rating = No further help
Sep 16, 2011 | JVC AV-56WP74 56" Rear Projection...
Handset setting are embeddeon my phone for my MMS & mobile internet
Apr 22, 2011 | Computers & Internet
Do not have full 64 point convergence control on the green crt. Most all ofrt of the picture is in convergence but the top first two lines are bowed and the middle bottom line is arced in the center....
No,the tv convergence board the 2 STK convergence ICS and some or all of it resistors are dead.Tv convergence board must be replace the 2 STK convergence ICS and also must test all of the resistors and replaces all those dead resistors too.
Mar 02, 2011 | Philips 60PP9753 60" Rear Projection...
Searching for a good Asics running shoe. There just so many models - I'm kinda confused..any help appricaited.
I have been running for 50 years and I have tried almost every shoe. The Asics gel-150 or 160 TR has the best support of all the brands I have tried. If you have a low arch these are the best. Running in these shoes my arch no longer gives me any pain.
Oct 27, 2010 | Clothing Accessories
Looking for schematic for a Behringer MX-9000. Mike preamps blowing out badly. Out of 24, only 9 are good. Also looking for anyone who sells parts for this board, specifically the ribbon cables as one...
If the mic preamp ICs are getting destroyed, there is something else wrong. Look for the correct B+ and B- voltages. I suspect that there is an offset here that is stressing the ICs to the point that they fail. These ICs should be 4558s or something similar and are readily available for low $$. Contact Beringer directly for the ribbon cable.
Dan
Mar 22, 2009 | Audio Players & Recorders
Shuts itself off randomly
Go to the site http;//www.loadparts.com there got the ICs you need .
May 17, 2008 | Yamaha R-V1105 Receiver
R-V1105 Will not turn on
Change the audio amplifiers ICs because they are damaged,that's why your device protect himself from a bigger damage.Good luck.
Apr 18, 2008 | Yamaha R-V1105 Receiver
R-V1105 Yamaha receiver
Your audio amplifier ICs are damaged,you gotta change it.
Nov 17, 2007 | Yamaha R-V1105 Receiver
Jvc
I am going to assume by out of line you mean that you have a green image besides the original image, or that the green image is somewhat distorted. If possible can you supply a picture? However based on your description you may have a convergence problem which is quite common in these types of televisions (projection TVs). You will have to have the Convergence Correction Amplifier ICs changed out the part number of the ICs are STK392-110. There are lots of resources on the net that explain how to change these components out so there is actually no need to retype it here just go to google and type in STK392-110 installation. This is of course if you have a background in electronics, if not I would advise that you have a TV repairperson come to your house and troubleshoot and replace thes malfunctioning components.
I hope this helps,
Thank you,
Shuttle83
Oct 12, 2007 | JVC AV-48WP30 48" Rear Projection...
Yamaha R-V1105 Receiver Logo
251 people viewed this question
Top Yamaha Audio Players & Recorders Experts
 Grubhead
Grubhead
Are you a Yamaha Audio Player and Recorder Expert? Answer questions, earn points and help others
