Question about Metra Ford/Chry/Jeep 1974 99
My car is a '99 Ford Mustang with about 169,000miles. The cylinder 1 is misfiring. We have replaced the sparks plugs, air filter, relay, and coil pack(i am not sure what all may be significant) so far, and it is still misfiring. We have also switched cylinder 1&2 plugs and wire, which would mean it would say cylinder 2 misfire when i get it checked but it didnt it still said cylinder 1. What else can i do?
  • Metra Master
  • 17,130 Answers
According to the inputs you have done a good job to identify the cylinder that makes the difference. hence it would be good to take a compression test on the cylinder with respect to the others. If the readings are poor then it is possible that you have a defective valve or settings. Also please check if there is any oil smear on the plug youhad pulled out from the 1st cylinder, if so there could also be a possible rings failure as your car had done this mileage. I am surre you will be able to test this out. helpful? Good day
Posted on Jul 20, 2010
2012 ford mustang ignition coil resistance
Pull an easy one and check. The resistance should be really close. I don't check. I pull another and swap them. If the misfires goes to that cylinder, replace the coil. If not, I check wiring for the original misfire. You can use a noid light for the coil plug also.
Sep 01, 2016 | 2012 Ford Mustang
Both coils do not fire on 1 and 4. Will start but only running on 2 cylinders. Could both coils be bad or should I look elsewhere?
Part 3 -How to Test the Ignition Module and Crank Sensor ...
easyautodiagnostics.com > Ford > 2.3L
Mar 1, 2012 - Spark plugs for cylinders #2 and #3 get spark at the exact same time. ...voltage -12 Volts) to both individual ignition coils within the coil pack. ... Ford Mustang or Ranger (or 2.3L Mazda B2300), this is what you'll need ... for this 'Switching Signal' at the coil pack... but you can also test this ... 1991, 1992, 1993.
How to Diagnose a Misfiring Cylinder (2.3L Ford Ranger ...
troubleshootmyvehicle.com > Ford > 2.3L
Apr 3, 2012 - Bad Fuel Injectors can cause a Misfire Condition. ... the ignition system on the 2.3L Ford Mustang or Ranger consists of 2 ignition coil packs, ...
2002 ranger misfire rough idle - Discussion on Topix
www.topix.com > Ford Ranger
Jul 27, 2007 - My truck is giving the code misfire in number 4 cyl. I replaced my spark plugs, Wires, Coil packs (both of them) and all my fuil ... three (3.0L v6) go bad, the fuel/air mixture gets messed up. Judged: 2. 2 ... My truck runs rough only at idle. ...code for ford ranger 2002, 2.3 5speed. truck runs like a champ but that ...
Extremely stumped! I need the best and brightest 1994 Ford ...
answers.edmunds.com > Edmunds Answers
Jan 31, 2016 | Cars & Trucks
On 99 mustang we have checked the fuel pump,an sencer, filter, mass air flow,coilpack plug wires,plugs,cut holes in cats, relays, it acte like it was out of gas but wasnt was ok a day but got worse,
Check the power supply to the fuel injectors at the injector end of the wiring. Have someone do this who knows what they are doing otherwise you can fry the computer.
Dec 26, 2015 | Mustang 94-00 Ford Heater Core 1994 95 96...
Ford freestar 2006, cylinder 6 code po301 cylinder 1 misfire
Standing on the passenger side.looking at the engine. Number 1 is the first cylinder on your left. Follow the wire to the coil. unplug it at the coil, lay the end of the plug close to the tip of the cap and start the engine. If there isn't multiple sparks, replace the coil. If there is , replace the plug and or wire. If you still have a misfire after that, do a compression test on number 1 cylinder.
Jul 07, 2015 | 2006 Ford Freestar
98 passat # 2 missfire help
If your getting a P0302 ( cylinder #2 misfire detected), the first thing to check is the spark plug. If it's new then the next thing to check is the plug wire. If it has individual coils, then swap it out with another one and see if the misfire moves too. If so then the coil is faulty.
May 07, 2011 | 1998 Volkswagen Passat
How can you fix a cylinder 3 misfire on a 2003 ford mustang
Hi hope I can help.
1.Fist change the spark plug. this is the main cause of most misfires,
2.If that don't work switch your coils. (remove one of your other coils and switch it with the #3 coil. If the misfire moves to the other cylinder then you know you have a bad coil and it need to be replaced.
3.preform a compression test.
4 Also check your fuel pressure.
Hope this helps
Please leave feed back
Thank you urnuts73@ FixYa
Mar 05, 2011 | 2003 Ford Mustang
2003 Hyundai Sonata with 4 cyl. PO301 error code. Have replaced spark plugs, wires, coil packs, and mass air flow sensor. Replaced air filter due to heavy gas smell. Car was starting after tapping gas 3...
P0301 - Cylinder 1 Misfire Detected.
Possible Causes:
- Improper spark plug at cylinder #1
- Insufficient compression at cylinder #1
- Incorrect fuel pressure
- The injector circuit is open or shorted at cylinder #1
- Fuel injector #1 may be faulty
- Intake air leak at cylinder
Possible Solutions:
- Perform Injector Service
- Replaced Spark Plug #1
- Replaced Injector #1
- Replaced Ignition Coil #1
Being you have a heavy gas smell I would look into the injectors. If injector #1 is over producing it can cause a misfire. Test your compression and fuel pressure.
Jan 17, 2011 | Hyundai Sonata Cars & Trucks
CODES-PO301-PO303-PO316- CHANGED PLUGS & WIRES. STILL MISS ON START UP, GOES AWAY MOST OF THE TIME ABOVE 1000 R.P.M
Causes:
- Intake air leak
Solutions:
P0303 - Cylinder 3 Misfire Detected.
Follow info from P0301.
P0316 - Misfire Occurred In The First 1,000 Engine Revolutions.
Causes:
- Damaged CKP sensor.
- Ignition System.
- Fuel Injectors
- Running out of fuel
- Fuel Quality
- Base engine
- Damaged Powertrain Control Module
Solutions:
Usually the P0316 is combine with a P03XX codes. The P03XX code indicates in which cylinder the misfire occurred.
Jan 17, 2011 | 2002 Mercury Sable
Giving a 300 and a 301 code where do i start sounds fine when started and then when you put in gear it start misfiring
P0300 - Random / Multiple Cylinder Misfire Detected
Possible Causes:
- Fuel injectors may be faulty
- Intake air leak
Possible Solutions:
- Replaced Spark Plugs
- Replaced Injectors
- Replaced Ignition Coils
P0301- Cylinder Number 1 Misfire Detected
Possible Causes:
Possible Solutions:
Most likely your issue is with cylinder number 1. Follow the info I have provided and you should be able to solve this issue.
Jan 14, 2011 | 2002 Toyota Tacoma
Getting a intermittant misfire and an occasional srvc eng soon light sthe code says misfire cyl 1 but after i reset the light i goes back to intermittant missing
Check your ignition coils. If you don't have a coil for each plug then I'd bet thats going to be your problem. That or your spark plugs. I'd start with the coil that cylinder 1 runs through first though.
Nov 14, 2010 | 2001 Ford Mustang
Metra Ford/Chry/Jeep 1974 99 Logo
77 people viewed this question
Top Metra Car Audio & Video Experts
xxxxxx xxx
Are you a Metra Car Audio and Video Expert? Answer questions, earn points and help others
