Question about Estate ETW4100SQ Top Load Washer
My washer stops just before the rinse cycle sometimes the dial makes noise sometimes not
  • 5,911 Answers
The most common cause of the problem you just described is a lid switch malfunction or lid actuator problem. Symptoms may include, filling and stopping on the intial fill cycle, stopping right after the wash cycle, not advancing to rinse or spin cycles, and a wash tub that will not drain.
The lid switch is usually mounted under the washer top casing, on the right hand side on most top load models. It is activated by a plastic piece on the lid (called a "Lid Strike" or "Actuator") through a small hole on the rim of the wash tub opening. In many cases the lid strike breaks off the lid, or the lid switch becomes loose and no longer makes contact. Inspect the lid to make sure the lid strike is still intact, and then inspect the mounting screws (adjacent to the small opening on the wash tub rim) and make sure they are snug. If you determine the switch to be defective, the following link explains how to replace one:
http://www.fixya.com/support/r3557193-replacing_a_lid_switch
On some models, the lid switch is located under the top casing by one of the lid hinges. You will know if you if you have this type of switch, because it does NOT have a lid strike (actuator) and the small hole on the right hand side of the wash tub will not be present. This type of switch is actuated (toggled) by a rod on the lid hinge. With this type of switch, if you locate it and it can be toggled by hand, you may only need to adjust the actuator rod by bending it slightly.
NOTE: You do not have to drain or bail the water from the washer tub to perform this repair. Once a defective lid switch is replaced, the washer should drain normally.
Replacement parts (if required) can be purchased at any of the following web sites:
searspartsdirect.com
pcappliancerepair.com
appliancepartspros.com
repairclinic.com
If the model number is correct, the part number for a replacement switch is 8318084. The actuator to the switch will be a rod on the left hinge of the lid.
The average price of a replacement lid switch for this model washer is about $15 - $20 if you perform the repair yourself. Prices will vary between sites so shop and compare. If you have questions, or need additional assistance, please post back and let me know. This is a very simple repair that you can easily perform without the assistance of a repairman.
If this advice does not help you enough, repairclinic.com has a Repair Manual you can order to assist you with all your repairs. The part number is 1170635 and is priced at about $20.
Searspartsdirect.com also has a repair manual for about the same price. Part number 4314044L. I hope this information is helpful to you.
Posted on Jul 13, 2010
Kenmore model 23832100 washer will not spin in rinse cycle kenmore model 23832100 washer fills, agitates, and drains, but will not spin. Makes noise after draining. BUT if I manually turn off the machine...
Check door switch: If the lid switch is bad it will not drain or spin. Try this test: With lid open let it finish wash cycle. Press lid switch down with screwdriver. Washer should begin draining. Release switch. Motor should stop. Press switch a second time. Washer should start spinning as it continues to drain. If motor doesn't come on while lid switch is pressed, replace the switch. OR
http://www.youtube.com/watch?v=q942xn_2VXY
Mar 30, 2013 | Washing Machines
Loud banging noise during rinse
Most noises from a washing machine occur during the rinse or spin cycle. If you hear loud thumping during the spin, the load of clothes may have become unbalanced. Stop the washer and redistribute the clothes, then re-start it. Repeat these steps if necessary.This will solve your problem.
Apr 08, 2010 | Whirlpool GHW9100L Front Load Washer
Stuck on rinse cycle
Often what appears to be a significant problem, may be something simple. I would recommend checking your lid switch. If the washer fills and doesn't do anything, or stops right after the wash cycle and then does not advance to the rinse cycle and drain, this is commonly caused by a lid switch malfunction. The lid switch is usually mounted under the washer top casing, on the right hand side on most top load models. It is activated by a plastic piece on the lid (called a "Lid Strike") through a small hole on the rim of the wash tub opening. In many cases the lid strike breaks off the lid, or the lid switch becomes loose and no longer makes contact. Inspect the lid to make sure the lid strike is still intact, and then inspect the mounting screws (adjacent to the small opening on the wash tub rim) and make sure they are snug.
If not activated by a lid strike, other models have the lid switch located under the washer casing next to one of the lid hinges. It is activated by a rod contacting an actuator. The mounting scews for this type are located under the operator console.
If you determine the switch to be defective, the following link explains how to access the washer interior and replace one:
http://www.fixya.com/support/r385198-replacing_lid_switch
If the switch requires replacement, a new one can be purchased on line at appliancepartspros.com, searspartsdirect.com, pcappliancerepair.com, or repairclinic.com.
If you need further assistance, please post back with a complete model number so that I may be able to assist you better. I hope this helps you.
Aug 15, 2009 | Kenmore 24032\24036 Top Load Washer
Washer stopping mid-cycle
Push down on lid. You may have a bad lid switch. Start machine and press the switch down with something like a screwdriver and see if the motor runs.
Jul 01, 2009 | Whirlpool Ultimate Care II LSQ9549L Top...
Kenmore front-load washer stops at rinse cycle
When the washer initially fills for the wash, is it only hot water entering the drum? Try switching the water temperature between hot and cold as it fills. If any of them show little or no water getting through, it sounds too easy but check to make sure water supply taps are on, and that the cold/hot fill hoses aren't reversed. Remove the fill hoses and check any of the screen filters for blockage (in the hoses and in the inlet water valve). When the machine stops and waits to fill but all you hear is a hum, it sounds like there is power going to the valve but water is not able to get through it.
Mar 03, 2009 | Kenmore 43142 Front Load Washer
Washer stopped after the wash cycle and after the 1st rinse cycle...stopped 2nd rinse cycle...I reset the dial and started the wash cycle and the washer agitated a few times then stopped nothing after...
Friend,
ngfam1 At your service!
The only way to repair this is to try this first.
First unplug the washer and wait a few minutes then restart it like rebooting your computer when its acting strange!
If it corrects the problem GREAT!!!
If not only a trained laundry tech can make the electronic diagnoses.
Like we used to be able to fix my own cars, but not today they need diagnostic equipment!
Below I referred you to a great service nation wide!
If none of these tasks remedy the heat problem then here is a good company that's found nation wide.
A&E Factory Service
A&E has schedulers available to take appointments 24/7
And they do warranty work too, for most manufactures!
1(800) 905-9505
You will be fine
Bless You ngafm1
PLEASE GIVE ME A GOOD RATING BEFORE YOU SIGN OF
Aug 31, 2008 | Whirlpool Washing Machines
Asko w6221 front load washer stops after wash cycle
Do all of your cycles work when you turn them manually? If one cycle does not work when you turn the dial on it then it will be your timer (The dial assembly $100-up) If all your cycles work manually, then it could be your timer motor which is attached to your timer assembly. If you turn the dial pass the wash, on to the rinse, does the dial automaticly move (when finishng the rinse cycle)to the spin cycle? If so then your timer motor is ok. The only wires close to the bottom are the motor, but these should be high enough out of the way.
Apr 01, 2007 | Asko W6221 Front Load Washer
Estate ETW4100SQ Top Load Washer Logo
218 people viewed this question
Top Estate Washing Machines Experts
Dan Webster
Dan Webster
dweatherby
Are you an Estate Washing Machine Expert? Answer questions, earn points and help others
