Question about GE 30 in. JGP328 Gas Cooktop
I have a GE JGP328 cooktop. Only the right side burners ignite properly. The knobs for both left burners do not make the clicking noise in the lite position. If I turn a knob for the right side I get spark to both sides ?
  • GE Master
  • 43,501 Answers
Here is a tip that I wrote to give details about why your cooktop will not spark to light the burners..
Cooktop Range Stove spark ignition does not work
heatman101
Posted on Aug 30, 2010
When you turn on any burner on the spark igniter will stay on after the burner is lit and the knob is turn from the lite position.
You could of possible got the stove top wet causing the problem.This problem although sounds like your spark ignitor module went bad.
Feb 10, 2011 | GE 30 in. JGP328 Gas Cooktop
Have a four burner gas GE Profile cooktop. How do
The igniter module is working fine. One of the switches (which are on each valve shaft) is stuck or shorted out. Pull a wire off each one at a time to determine which one is bad. Careful! 120 volts to each wire. Also, this can happen after you spill water into the valve area, if that sounds right, let it dry out.
Jan 29, 2010 | GE 30 in. JGP328 Gas Cooktop
After cleaning,one burner won't stop clicking
Sounds like the shaft moved slightly as you pushed on the knob. Just pull it back off and try again.
Aug 12, 2009 | GE 30 in. JGP328 Gas Cooktop
GE Cooktop burner doesn't click or light.
Remove all the burner heads and lift the top. Sometimes easier said than done. How do you know it is the module? It could be a cracked insulator on the ignitor. To verify you can swap two of the connections on the module and if it lights then it is the module.
eric
Jun 20, 2009 | GE 30 in. JGP328 Gas Cooktop
GE XL44 range - electric igniter for top burners not working.
Sounds like igniter problem. Did some one pull the electrical cord or has a fuse or breaker blown/ Things to check. Your igniter is run by electricity.
Dec 30, 2017 | GE Profile JGP636 Gas Cooktop
GE jgp328 front ignitors won't turn off. How do I remedy this?
Did you just clean it? If the swiches under the burner knobs get wet, they cause the electrodes to click. Unplug the unit or turn off the braker for a day. it should dry up and work normal.
May 04, 2009 | GE 30 in. JGP328 Gas Cooktop
All 4 ignators are spaking with the contrtols on off position on my GE JGP328 cook top
It's the Switch Harness. Do not remove the stove and disconnect it from the gas. Turn the gas off under the stove. Take off the: knobs and the plate; burners; hxw screws. Pull burners out and disconnect igniter burners. Lift the top of the oven off. The Switch Harness is on the right, under where the knobs are located. Replace the Switch Harnes.
Mar 30, 2009 | GE 30 in. JGP328 Gas Cooktop
Spark igniter discharging when turned off
Hi
It sounds like somebody clean up the stove and the electric sending unid is wet, try this: the knob that correspond to the ingniter that it's clicking nonestop, take the knob out and you will see the sending unit, pull it out unplug it and dry it out and then try it again, it should work properly after it's dry.
Eddie Rentas
Tupper Lake NY
Jan 11, 2009 | GE 30 in. JGP328 Gas Cooktop
GE 30 in. JGP328 Gas Cooktop Logo
321 people viewed this question
Top GE Cooktops Experts
Marvin
Marvin
Dave Harrison
80stech
Are you a GE Cooktop Expert? Answer questions, earn points and help others
