Question about Microwave Ovens
I have a LG smooth top stove and its hard to keep clean is there an easy way to clean it
  • 2,335 Answers
Bon Ami is a great product for cleaning 'glass' top ranges.
There's also a product called Weimann Glass Cook Top Cleaner which is good for that once-a-month full cleaner, & I recommend Windex Vinegar Multi-Surface for the daily wiping.
I hope that helps.
Posted on Jul 14, 2010
Lg microwave above the stove, lt is level but door wont stay open,as your putting items in it starts to close ,is there any adjustment on the door
Only gravity keeps the door in open position. You can try to tilt front down by loosening the top mounting bolts.
Apr 29, 2017 | LG Microwave Ovens
My microwave not starting
My microwave on top of stove oven,whirlpool gold. When i closed the door but it keep said"door"and won't start.
Jul 21, 2011 | LG MS-0744Y Microwave Oven
I am disassembling a Kenmore stove top gas burner to clean under the stove top. To do so you actually need to unscrew the burners, which I've done, but then I need to unhook the spark electrode, which...
The electrode is held onto the burner head with a screw through the mounting tab. They can get crusted over and it's not always easy to see the screw head, but it's there.
Jul 04, 2011 | Microwave Ovens
When I boil water on the stove top, the electronic buttons on the microwave do not work. After a period of about week the electronic buttons work again. A repairman said I need a new door for $325.00. ...
CONTACT LG FACTORY TECHNICAL DEPTN, ASK IF THERE IS A SERVICE FLASH ON THIS MODEL OR INSULATION TO KEEP THE CONTROL PAD FROM FILTERING WATER STEAM..
Feb 18, 2011 | LG LMVM2075 Microwave Oven
About 1 hour into the 4 hour clean cycle an alarm started gong off. Code is F3. Frigidaire smooth top electric slide in stove.
The F3 code means
The oven temperature sensor is open Check for open wire connection between EOC (Electronic Oven Control - Clock) and the oven temperature sensor. Replace sensor if no wiring problem. Check oven temperature sensor, 1100 ohms Good Luck
Nov 27, 2010 | Microwave Ovens
Does stove-top need downdraft if microwave has oven-hood combo?
We have a stove with no downdraft, and a microwave with a hood above it. It works just fine. I expect you could keep your downdraft and put a microwave without a hood above it, and that would also work. I don't think, however, you can buy an above the range mocrowave oven, that slides in on brackets, which will not have a hood.
Jan 08, 2009 | Microwave Ovens
LG over the stove model lmvm 1935
The turntable system consists of the motor, the coupler, the turntable support with rollers, and the tray.
You can see and hear a video of how a turntable motor should sound when you rotate it by hand.
If yours won't rotate or it sounds like it's grinding, etc., you may have a bad motor or plastic coupler.
In some cases, cleaning them helps. Lubrication is not recommended.
To replace either, you need to unplug power, then remove the bottom cover of the oven.
To order Goldstar / L.G. parts, visit Vance Baldwin Electronics.
Dec 07, 2008 | LG LMVM1935 Convection/Microwave Oven
Cleaning vents
GE Spacemaker Profile X1800.
I would take out the grills and boil them, but cannot see how to do that.
Also, the GE stove top (Model JGSP44BEY) has so much baked on crud that I may never use it. I poured a whole bottle of easy off onto it and still cannot loosen it all. Same goes for the removable parts from the burners.
May 28, 2008 | GE Spacemaker JVM1640SJ Microwave Oven
Microwave Ovens Logo
15 people viewed this question
Top Microwave Ovens Experts
William Miller
William Miller
Marvin
Marvin
Are you a Microwave Oven Expert? Answer questions, earn points and help others
