Question about Dell Precision Workstation 490 - MT - 32bit Dual Core Intel Xeon Processor 5120 1.... PC Desktop
Computer won't boot - there's a flashing 1 and 3
Dell 490 Precision - Computer won't boot - there's a flashing 1 and 3 on the front of the case. It was running - instead of hitting "reboot" I hit "shutdown" and now it's not coming back on.
  • Dell Master
  • 5,531 Answers
Either the power supply has failed or the power cable is not getting power to the board (if the lights are amber). Check that the power cable from the power supply to the motherboard is fully seated. You may need to replace the power supply - you will need one that will fit your case and matches the various devices and plugs that you currently have. (20+4 pin for the motherboard gives the most flexibility, additional power for the CPU (4 pin or 8 pin), SATA if you have SATA devices, regular 4 pin peripherals for IDE hard drives and optical drives, 4 pin floppy, video card (if you have a PCIe card that needs a 6 pin plug), etc.)
I hope this helps.
Posted on Jul 13, 2010
    New Friend:
POWER ISSUE
13:50:41
System
You are now being connected to an agent. Thank you for using Dell
Chat
13:50:41
System Connected with TMPw_SumeetD_197007
13:50:53
Abbas Shah Hi, How are you ?
13:51:40
Abbas Shah
I have an issue that when I use my DELL PC for 4 or more hours and
shuts it down. I will not start immediately and I have to wait until 2 more
hours
13:52:11
Abbas Shah LED 1 and 3 along with power yellow light start blinking
13:52:34
Abbas Shah I have precision 490
13:52:46
TMPw_SumeetD_197007
I am sorry that you are experiencing trouble today, Abbas. I will be
happy to assist you in resolving your issue. Just for your records; I
checked the warranty contract for this system and see that it shipped
on 3/27/2008, and had a warranty that expired on 3/27/2011.
13:52:46
TMPw_SumeetD_197007
Before we get going, I would like to verify the information you entered
into the chat form.
You entered service tag D1WCZF1. The system is a PRECISION 490
DESKTOP.
You provided a contact phone number of: .
When the chat window is closed you will automatically receive a
transcript of our session at: smashah1@gmail.com.
Is all of this information correct?
13:53:41
Abbas Shah Yes, these information are correct
13:53:51
TMPw_SumeetD_197007
Excellent. Based on the symptoms you are describing, I would advise
trying a known-good power cord connected to a known-good power
outlet.
13:54:18
TMPw_SumeetD_197007
If the symptoms still persist, it will be necessary to replace the power
supply unit.
13:54:39
Abbas Shah you mean to say outer power cord, which is connected on back of PSU
13:54:51
TMPw_SumeetD_197007 Correct.
13:55:11
TMPw_SumeetD_197007
For reference, your service request number for this inquiry is
888902151.
13:55:18
Abbas Shah
what does this mean "LED 1 and 3 along with power yellow light start
blinking'
13:55:18
TMPw_SumeetD_197007 Is there anything else I can assist with today?
13:55:42
TMPw_SumeetD_197007 That typically indicates a power supply unit failure.
13:55:46
13:56:12
Abbas Shah
If I do not want to change my PSU, is there any other way that it can
be solved
13:56:13
Abbas Shah ?
13:56:51
TMPw_SumeetD_197007
Try replacing the power cord first. If that does not resolve the issue,
the PSU will have to be replaced.
13:57:06
TMPw_SumeetD_197007
The only other way to resolve the issue would be to replace the whole
computer.
13:57:16
Abbas Shah You are joking
13:57:28
TMPw_SumeetD_197007 I am not.
13:57:46
13:57:51
Abbas Shah Like if I clean my PSU or put it in a freezer to reduce heat
13:57:56
Abbas Shah will it work ?
13:58:16 TMPw_SumeetD_197007 No, that will not work.27/1/2014 Moxie Software(TM) Customer Spaces Channels Customer Client
http://channels2.us.dell.com/netagent/scripts/srvgate.dll?Action=1060 2/2
13:58:21
13:58:35
Abbas Shah then why does it take 2 hours to start working again
13:59:21
TMPw_SumeetD_197007
The PSU is in the process of failing completely. Soon it will not power up
again at all.
13:59:59
TMPw_SumeetD_197007 This is not uncommon for a component which is 6 years old.
14:00:33
Abbas Shah
But it does as I am using my computer right now.. I used my system last
night for 5 hours and shut it down then again I start after 10 minutes it
did not start and took almost 2 hours
14:00:36
14:01:21
TMPw_SumeetD_197007
It currently takes almost 2 hours to restart. Soon it will take even longer
to restart it. Soon after that, it will not start at all.
14:01:46
TMPw_SumeetD_197007 When a PSU is failing, this is a fairly typical pattern of symptoms.
14:01:49
Abbas Shah Do you have any solution other than changing the PSU
14:01:53
Abbas Shah
it will cost me alot
14:05:12
TMPw_SumeetD_197007
The PSU is failing, Abbas. In order to resolve the issue, it should be
replaced. If you have knowledge about how to take a apart a PSU and
examine or replace wiring or capacitors, you can choose to do that at
your discretion, however, there is a risk of fire or electrocution when
taking apart a PSU, and we can not specifically advise doing that, or
provide any instructions on how to do it.
14:05:37
TMPw_SumeetD_197007
Also, the time and expense involved in attempting to repair a PSU is
likely not much less than replacing the PSU.
14:05:47
TMPw_SumeetD_197007 Ok then, is there anything else I can assist with today?
14:06:43
Abbas Shah Thank you for your all assistance. I will contact you later
14:06:45
Abbas Shah BYE
14:07:02
TMPw_SumeetD_197007
Thanks again for contacting Dell Technical Support, Abbas Shah! You
can contact us any time at 877-671-3355 or at http://support.dell.com.
You can close this window at your convenience. Have a great day!
14:07:09
System TMPw_SumeetD_197007 has left this session!
Posted on Jan 27, 2014
Dell Precision T3500 wont boot 1-3 lights blinking
An amber light means your computer isn't reading the hard drive or CD right, Take it to a professional to get this corrected
Dec 16, 2013 | Dell Precision Computers & Internet
Dell Precision M90 no boot and device status light next to power light is green
Here are Few steps which can use to trouble shoot your laptop no display problem.
1. Connect a VGA
cable for external monitor and check if you can see any display on External Monitor.
2.Take out your RAM and Clean it with Pencil Eraser and Put it back. If Possible try with different RAM,
3. Remove your Hard Drive and Try switching on Laptop without the Hard Drive.
4. Make sure that you are using proper Adapter with proper Voltage.
Aug 10, 2012 | Dell Precision M90 Notebook
I have a broken Dell Precision 470 Workstation. The symptoms are as follows: Won't power up; Flashing yellow power LED on front panel; Blank STR_LED on motherboard; Yellow AUX_PWR LED on motherboa
Flashing front powerlight is often a result of a faulty powersupply, try another powersully on the pc and see if the problem gets solved. I've seen a few of these cases personally.
Jul 01, 2012 | Dell Precision Workstation 470 (204816690)...
Dell dimension 3100 keeps rebooting
1. Click Start > Run and type REGEDT32 and hit ENTER
2. Click the plus sign next to HKEY_LOCAL_MACHINE
then System
then CurrentControlSet
then Control
then click CrashControl
3. Double-click on AutoReboot on the right side and change the value from 1 to 0.
Close regedit and restart the computer. Now the computer should shut down normally instead of restarting.
Feb 26, 2012 | Dell Dimension 3100 PC Desktop
Dell precision 490 led 4 remains on
try to clean the memory slot of your computer as well as the memory module then power up your PC. just do hardware maintenance by means of cleaning all any dust inside the computer. Hope it helps thanks.
Nov 02, 2011 | Dell Precision Workstation 490 - MT -...
I have a Dell Precision 490, the Light at 1,3 and the power button blinks and i cannot star tmy computer!
I normally post this link:
http://www.fixya.com/support/r4282412-find_no_post_diagnostic_information_dell
but I think I can get better info for you here:
http://support.dell.com/support/edocs/systems/ws490/en/ug/tools.htm#wp1057769
2 things.
The power led flashing amber can mean a failure of one rail in the power supply, or a bad connection (The cables are removable from the power supply) so you may try reseating power connections internally.
1 & 3 LEDs can mean a RAM failure
Aug 22, 2011 | Dell Precision Workstation 490 - MT -...
Dell precision 490 led 1 & 4 on
As description of Manual of the pc ,
led 4 is means The computer is in a normal
off condition; the computer is
connected to an electrical
outlet
https://www.manualslib.com/manual/36893/Dell-Precision-Dcd0.html?page=35#manual
1 and 3 illuminate for Memory modules are detected, but a
memory configuration or compatibility
error exists.
solutions
• Ensure that no special memory
module/memory connector placement
requirements exist.
• Verify that the memory modules that
you are installing are compatible with
your computer.
• Reinstall the memory modules and
• If the problem persists, contact Dell. (if have warranty)
But you can install and check one module at a time.
if not compatible each other may not display.
https://www.manualslib.com/manual/36893/Dell-Precision-Dcd0.html?page=40#manual
May 15, 2010 | Dell Precision Workstation 490 - MT -...
If you are getting no video at all, then we can use the diagnostic LEDs and the power LED to help determine the failure.
Mar 29, 2010 | Dell Precision Workstation 490 - MT -...
Dell Precision 490 constant reboot after ghost image completed
Hello-
I figured out how to ghost a Dell Precision 490 with a 32 bit Windows XP Image! Like you I had the same problem where it would constantly reboot after I imaged it with an existing 490 image. The answer is actually very simple. Boot up your Precision 490 and hit F2 to enter the bios. Select Drives and then SATA Operation, change it to "Raid Autodetect / ATA". Reboot the 490 and re image the machine, it will now work!
Dec 01, 2008 | Dell Precision Workstation 490 - MT -...
Dell Precision Workstation 490 - MT - 32bit Dual Core Intel Xeon Processor 5120 1.... PC Desktop Logo
3,773 people viewed this question
Alun Cox
mukhtar21 shaikh
mukhtar21 shaikh
