Question about Akai LCT2070 20 in. EDTV-Ready LCD Television
Tv turns on and briefly displays picture and then goes black, still has sound. Sometimes you can turn it on and off several times and the picture might stay on the screen.
  • bloodthinner Apr 27, 2008
    picture is only seen for the words akai and then thats it and it is faint. opened the tv up(which was a real chore) and couldn't see anything that looks bad but i dont know what the inverter board looks like.
  • pproctor Jan 08, 2009
    Im trying to figure out how to get into this thing. The service manual is less than forth comming on the secret...
I have a similar condition; the TV powers on fine and displays "Akai," but then goes dark. I can see the letters and shapes the TV puts out using a flashlight, so all of the control electronics are working fine.
A multimeter shows the power supply putting out a steady 12.7 volts.
The capacitors described above are always a good place to check; however, my TV doesn't have a problem there.
Here is a third option. The inverter board (a Greatboard model of some sophistication) will produce an overcurrent signal on pin 7 of the connector if one of the tubes draws too much or too little current. This prevents a cascading failure should one fail. The problem with this is that complete dissassembly is required to access the bulbs. My boss and I estimate that this set has about 3000 hours on it and the endings on the fluorescent bulbs have blackish rings at the ends. (There are 3 bulbs along both the top and bottom each fed from the inverter board.) I haven't in my brief Googlings found replacement builbs, but IF the inverter is good and IF the rest of the machine has enough life left in it and IF you get it all back together properly, it would probably extend the set's life.
Replacing the inverter board might work if it's actually the problem, but having seen the bulbs I'm not about to hunt a spare inverter down.
Four screws hold on the base, four the backside, and one a small piece of the backside. Then it's just snap joints to get that off. After that, the metal shield is held on by eight screws AND the two anchors for the VGA port. Past that is a royal pain; good luck with it. Just look for all the screws and understand light gates and light balancing and lorentz lenses...well, just how to put them back together like they were. ;) (I just finished complete disassembly and reassembly and it was UGLY.)
Posted on Jan 14, 2010
    Problem Solver:
  • 7 Answers
I had the same exact problem. It is not please don't mess with the insides. It is your power supply. It puts off low voltage. You need to find a replacement and your tv will work just fine.
Posted on Mar 07, 2009
  • 36 Answers
I am almost certain that the fault lies on the inverter board,there is a capacitor that is failing and needs replacing,it is normally black or brown and is near the plug on the inverter board,try heating the inverter board up with a hair dryer when the set is cold and it should come straight on,if it does then you know where the fault is,also check the small white fuse(maybe on the underside of the board)hasn't gone open circuit,if it has repace and carry on enjoying your tv.
Posted on Apr 20, 2008
My LG tv will go on then after a few seconds the screen goes from black back to picture of and on a few times then shuts off. Help!
LG LED TV has no picture (black screen) but still sound ...
7 days ago - My 32' LG LED TV has suddenly lost picture! The sound is all right but theScreen is pitch black. After switching it on the picture flashes for a second and thenthe ... LG LED TV has no picture (black screen) but still sound - can it be fixed? Tags: ... a touch on the screen reveals nothing so it's not the back light.
Monitor going black after 2 seconds [Solved] - > Forum > Hardware
Oct 9, 2012 - Brightness goes down, display draws less juice, and you can at least use .... it's the LCD's Inverter ... you have to replace it for it to go back to ... If the screen is turning off every two seconds or so and then it comes ... i turn my tv on it comes right on, but then after a few minutes turns off, .... Digital Trends for LG. No display in monitor
Jan 11, 2013
Ps3 and hdmi cable
Oct 8, 2012
More results from
TV with Black Blank Screen Repair How to Troubleshoot ...
? 3:16
Dec 20, 2015 | LG Televison & Video
Picture goes black with gray fuzzy lines ~ 1/2" apart horizontal.
If your LCD TV or monitor has stopped working, or is displaying one of the following
symptoms, then it's a candidate for some new capacitors
- Flickering screen
- Screen image disappears after several seconds
- Dim screen
- Slow start
- Power LED on, but no picture
- Unusual colors and/or lines
The primary cause of LCD TV and monitor failure is caused by faulty capacitors. You can
examine the capacitors in your LCD TV or monitor and actually see if they are bad.
If they appear bulged on top, then they need to be replaced.
New capacitors will solve a host of problems in LCD monitors and TV's and will extend the life
of your monitor or TV by several years.
Take it to a repair shop.
Apr 05, 2014 | Sanyo DP50749 50 in. Plasma TV
Toshiba Picture Not On
what you suggesting is that the lcd has a good maintenance needs that have to have cold solder or connectors are sulfated
Aug 22, 2009 | Televison & Video
Picture goes black but hear the sound
this is the problem related to display of ur TV screen...please contact the service centre...plz dont try to repair it urself..
Apr 30, 2009 | Sharp Aquos LC-C3234U 32 in. LCD TV
Picture on 15 year old Trintron comes on briefly then goes black
if the sound goes out its not a tube problem . a bad tube would have no effect on the sound .you problem (my guess) is in the power supply . a modern tv power supply has parts of it that stay on all the time unpluging it is not the problem its when you plug it in ! the power supply gets a JOLT . you might get away with it ,you might not . thats why we install surge arrestors on power plugs and with expensive tvs i recomend a UPS a power unit that keeps the tv powered even wnen the line power is out . thats keeps everthing in the sets nice and even ,so the tv lasts longer ... a modern tv turned off uses about 1.40 in electric a YEAR in standby mode , so what are you saveing if you send you set to the landfill early and have to buy a new one ? over 1.40 in electric ? . turn down you water heater or something else simple dont be blowing out you electronics for the sake of a few cents ..... good luck .... if this answer helped please rate a 3 or 4 , this high rateing will hepl keep me in the paid answer department . thank you
Apr 19, 2009 | Sony Televison & Video
The tv turns on but no picture.
Mine did the same but no picture, just sound every few seconds for 1-2 seconds. I unplugged from the wall for 10 seconds and plugged back in, works fine now.
Jan 12, 2008 | Hitachi 60UX54B/55K 60" Rear Projection...
Sound but no picture
Basic repair for skilled TV repairman = solder connections on
vertical output IC.........Can be done in home.....T.
Nov 28, 2007 | Sony KV-35S42 35" TV
Picture goes to black
tube is shorting out needs a new tube
Nov 09, 2007 | Televison & Video
Aug 26, 2007 | Sony KV-36XBR400 36" TV
Akai LCT2070 20 in. EDTV-Ready LCD Television Logo
217 people viewed this question
Top Akai Televison & Video Experts
Jaime Hernandez
Are you an Akai Televison and Video Expert? Answer questions, earn points and help others
