Question about Schumacher & Fast Charge Starter Charger
Schumacher Mity-Mite model PS-70A. I want to
Schumacher Mity-Mite model PS-70A. I want to replace the battery HB1270. Local stores have 12V 7 Amphour batteries, but the terminals are wrong. They all have quick connectors. My battery has solid tabs with holes, for a bolt-on wiring connection. Where can I buy the right battery HB1270?
  • 6,826 Answers
Http://www.alibaba.com/product-gs/206111785/dry_type_deep_cycle_battery_12V.html
Does the above fit the description of having solid tabs with holes?
Or is this the quick connector type?
Posted on Jul 13, 2010
I need a replacement Power pack 12V-3A 36W. Can you please tell me where I could get one from?
Cherryl, You could try local stores that sell computers and electronics, Walmart, the source, staples etc. Check the attached links,for power pack/charger, Good luck
"I hope this helped you out, if so let me know by pressing the helpful button. Check out some of my other posts if you need more tips and info."
Premium 4 8 1 7mm Replacement Power Supply Cord Laptop Battery Charger...
Genuine Asus LCD Monitor 12V 3A 36W Ac Adapter Charger ADP 36EH
Laptop AC Adapter 12V 3A 36W 1 7 4 8mm
Amazon ca power supply 12v 3a
Apr 28, 2016 | Computers & Internet
I have an error code of FOO ?
Joseph, No F00 maybe contact company. Digital Battery Charger Error Code Explanation Chart. Check the attached links,
ERROR CODE DESCRIPTION REASON/ SOLUTION F01 The battery voltage is still under 10V (for a 12V battery) or 5V (for a 6V battery) after 2 hours of charging. Could be caused by trying to charge a 6V battery on a 12V setting or charger, or the battery could be bad, have it checked or replaced. F02 The charger cannot desulfate
the battery. The battery could not be desulfated, have it checked
or replaced. F03 The battery was unable to reach the "full charged" voltage. Could be caused by trying to charge a large battery or bank of batteries on too low of a current setting or the battery may have a shorted cell. Try again with a higher current setting or have the battery checked or replaced. F04 The connections to the battery
are reversed. The battery is connected backwards. Unplug the charger and reverse the connections to the battery. F05 The charger was unable to keep the battery fully charged in maintain mode. The battery won't hold a charge. Could be caused by a drain on the battery or the battery could be bad. Make sure there are no loads on the battery. If there are remove them.
If there are none, have the battery checked or replaced. F06 The charger detected that the battery may be getting too hot (thermal runaway). The charger automatically shuts the current off if it detects the battery may be getting too hot or the battery may have a shorted cell. Have the battery checked or replaced.
FAQS
Schumacher XP2260 Owner Manual
XP2260W Schumacher Portable Power 1200 Peak Amps
Mar 05, 2016 | Schumacher XP2260 6-in-1 Jump Starter
Have a mity mite ps 120 a automotive jump starter but no chord to charge it. can i just use any chord or do i need to buy a replacement chord? And if so where can i purchase?
What Cord?
Your asking about plugging it into the homes
electrical outlet ?
Can't use just any cord,not a two prong lamp cord
type extension,no
You use a three prong grounded extension wire
Does it not have several feet of wire on it & a three
prong plug?
You use a standard outdoor extension, like you
would for a vacuum cleaner outside
If you use it a lot, buy a short 6 foot one,just to
use with it
How about the owners manual ?
Nov 25, 2014 | Cars & Trucks
I can't recharge my Schumacher PSJ-1812 jump starter. I can't get an extension cord to plug into the outlet on the machine. I think it had a 12V power source adapter unit when I bought it bu
Not unless you can get the pc. back from the person lent it to or make him or her buy a new one or find the one that came with it !
PS. never lend your tools out
Oct 10, 2014 | PSJ-1812 DSR Jump Starter and Portable...
Schumacher charger parts
Probably not worth repairing. Meaning, the cost to repair will most likely exceed the value of the charger.
Sep 04, 2014 | Schumacher SCUSE826 SE-82-6 6 Amp 12V...
Missing battery leads
use meter it will give u a negative reading if your leads are backwards
Jan 07, 2014 | Schumacher SCUSE826 SE-82-6 6 Amp 12V...
Schumacher battery charger sf-1252-ma thermal fuse does anyone know what the number is off of this fuse
The thermal fuse (1 shot fuse) is a #U25 from
Uchihashi Corp. The link below will take you to their page showing the fuse type and ordering information. Probably not found at a local electronics store.
http://www.uchihashi.co.jp/english/image/pdf03ae.pdf
Nov 20, 2010 | Schumacher & Fast Charge Starter Charger
Is it possible to replace the batteries in a 12v makita battery pack
Unfortunately there are no repairable parts in a battery. Once a battery is dead it's usually best to find a good recycling center for it, most The Home Depot's have one. Makita lists battery 1234 (Part #193157-5) for this tool but it's the old Ni-MH battery. I'd use battery 1222 (Part #192598-2), it's the better Ni-Cd battery.
May 19, 2010 | Makita 12V Cordless Impact Driver -...
Ademco 6128 keypad beeping at random times & says bat on the display screen now - is there a battery in there we need to change?
you need to change your main control battiery.
the main control panel takes a 12 volt 7 amphour or a 12 volt 4.5 amphour battery. the larget the amphour the longer the system will last when the power is out. available at fry's radio shack or on line. ps: if the key shows a zone number with the bat, that means you have a wireless sensor low battiery.
mj
Aug 29, 2009 | Honeywell 5804 Ademco Wireless Security...
Schumacher & Fast Charge Starter Charger  Logo
810 people viewed this question
Top Schumacher Electrical Supplies Experts
D. E. Hev
Are you a Schumacher Electrical Supply Expert? Answer questions, earn points and help others
