Question about Sony Grand WEGA KDF-42WE655 42" Rear Projection HDTV
REPLACED BLOWN LAMP. BUT NOW THE SCREEN SHOWS UP LARGE BLUE AREA'S OF LIGHT
  • agriandrea Jul 13, 2010
    Seems Sony wont be getting our support next time round- I hear Samsung may be better.
    Thanks guys
  • 4,472 Answers
Http://sites.google.com/site/sonylcdrptvproblems/
There is known issues with optical blocks on these tv's. the extended warranty has already expired. There is even class action lawsuits being filed because of this widespread problem. You can either consider having the optical block replaced or purchasing a replacement tv.
Thank you and good luck,
Lee
Posted on Jul 13, 2010
  • Lee A.
    Lee A. Jul 14, 2010
    Normally Sony is pretty good as far as tv goes this was just a large batch of bad optical blocks. They should have made a better attempt at fixing all the bad ones. If I were you I would still call and complain(if you have the time). Samsung makes all the lcd panels that are used in lcd tv's these days so they must be doing something right.
    Lee
I have a 2004 sony 42 inch dlp the back of the screen is blue what is wrong with it
It may be the optical light engine---usually the whole screen will not be a uniform blue but just areas----the lamp shines into the engine and the first part it hits is the blue---some damage can happen since the lamp can burn that area with its heat---best way to look is go to a unused video input and look there.
Nov 07, 2012 | Televison & Video
My other computer, G4 Macbook Pro, has a screen issue. When it is turned on and in process of coming up, the screen shows large sections of odd colors such as light pink or light green or light blue. Then...
Connect an external display to the computer. If the lines and distortion shows up on the external display its the video card, which is attached to the logic board. So, the whole logic board will need to be replaced.
If the lines and distortion don't show up on the external display the issue is the LCD module, which will need to be replaced.
Jan 30, 2011 | Apple PowerBook G4 Mac Notebook
I just recently changed my lamp in my hitachi 50 VF 820 and the screen has a large blue spot on it. I have done it before once or twice and all went well. Did I possibly put the bulb in incorrectly or is...
No. If the set turns on and you have a picture, the lamp is installed properly. Most of the time the optical block is the issue. The lamp shines directly into it. If the picture was good before the lamp was replaced, it is possible that that replacing the lamp might have dislodged some micro dust build up internal to the optical block and it landed in a concentrated area causing the red and green lcd panels not to pass light through as bright as the blue giving you a blue spot. Unfortunately the optical blocks are not designed to be taken apart to clean. Replacing the optical blocks are expensive. Most costing in the area of $700.00 to $1200.00 for the part. It also is a major tear down to get to the optical block to replace it. Once upon a time Hitachi had a couple of recalls on their optical blocks for various models. I do not know however if this qualified.
I hope this helps,
Skyassoc
Jan 06, 2011 | Hitachi 50VF820 Projection TV
I have a 2 year old Mitsubishi WD-73732 - 1080p 73" Medallion Series DLP HDTV - WD73732. I am getting blotches of color when there are large areas of blue color. Looks like irregular moving stains...
It will cost you probably in the area of $700.00 to replace the Light Engine. I don't think it would be a good idea to repair it. DLP sets have been out of production a few years now due to high failure rates of the light engines for all makes and models and the consumer cost for the lamp.
Nov 10, 2010 | Mitsubishi WD-73827 73" HDTV DLP TV
Model: HD - Z70RF7 projection TV Lamp has blown. I have replaced with brand new lamp and now get rapidly flashing orange lamp light on front of TV, blue power light is solid and not...
Tv turn on now,hear alots of clickings too?Yes.Check the Ballast board,this board might be dead too.The ballast board job is,just it to help to ignite the projection lamp.
Oct 28, 2010 | JVC Televison & Video
I have a large screen panasonic tv. The lamp
Turn On tv.
Press and hold Volume Down button on TV Front and PIP/ SPLIT button on Remote at same time for 6 Seconds to reset Lamp Timer and tv will show you timer reset message screen.
Hope this info will help you.
Thanks.
Mar 31, 2010 | Panasonic PT-50LC13 50" Rear Projection...
Blue tint on the left side of the screen
this is caused by the optical block going bad and needing replaced contact sony tech support
Jan 24, 2010 | Sony Grand WEGA KDF-50WE655 50" Rear...
I replaced my lamp on my PT-61LCX65 last year and
Depending on how much you watch this set the lamp could be out again, they don't have to look blown to be blown.
Sep 04, 2009 | Panasonic PT-61LCX65 61" Rear Projection...
Sony Grand WEGA KDF-42WE655 42" Rear Projection HDTV Logo
70 people viewed this question
Top Sony Televison & Video Experts
Are you a Sony Televison and Video Expert? Answer questions, earn points and help others
