Question about Craftsman 17.5 hp 42 in. Deck Lawn Tractor - CA Model
Kohler 17.5 HP floods after turned off over night. Gas spits out of muffler when you try to start. It`s hard to start but run fine after engine starts
    Problem Solver:
  • 10 Answers
Probably a leaking float valve. If it has a fuel shut off, use it, and run it out of gas after each use.
If you pull the bowl off the carb, it's the valve attached to the float. cleaning it may help, or replace it.
Posted on Jul 25, 2010
Gas spits out muffler
if gas is making it to you muffler that mean it getting way to much gas, but you would a ssume it would flood out. it could just be running out of your carborator and down the inside and seeming like its from the exhaust. end result check to make sure your carb floats are at the correct height or the motor get to much or to little of fuel
Dec 17, 2013 | Briggs & Stratton 5 Hp Outboard Service...
Have a murrry mower with 12 hp moter put a cut off on gas line some times runs ok then will start flooding if you cut gas line off start engin it will run a second or two then start blowing oil out an
If you have a float style carb I believe the float has become a "sinker". Pull the float bowl off the carb and set aside. pull the float pin and also set aside. carefully remove float and needle, set needle aside. Shake the float near your ear. If you hear sloshing in the float, replace it. No? check needle and seat for wear, or since you're into the carb this far replace them. This info is based on Tecumseh carbs, but B&S or Kohler should be similar. If there are any other questions don't be afraid to ask. There is no such thing as a stupid question.
Jan 29, 2013 | Briggs & Stratton Garden
17hp kohler ohv runs rough and muffler glows red hot
muffler full of carbon remove muffler heat up red hot throw in bucket of cold water remove and throw as hard as you can on pavement clean carbon out of exhaust part of headt make sure piston is all the way up you dont want carbon in your motor reinstall thank me
Oct 06, 2012 | Briggs & Stratton Briggs Stratton Intek V...
Carburetor flooding BIG TIME!
replace the needle valve seat and also replace the needle again check the float shake it and see if you hear gas inside of it there shouldn't be any in there
Aug 03, 2012 | John Deere Garden
I can get it to run but its spits out alot of fuel from behind the carb
Sounds like you have either a clogged muffler ( carbon and oil residue) or a stopped up spark arrestor screen inside the muffler....remove the muffler and scrape the gunk out of the inside and clean the screen....while the muffler is off try starting the machine and see if it runs properly...if it does then you know it's the muffler !!! Hope this helps ;-D
Jun 27, 2010 | Poulan/Weed Eater No. Te475 952711797 17"...
Craftsman riding mower will not start
Same thing happened to me with my 26 horse kohler craftsman. Replaced EVERYTHING (spark plug, fuel filter, oil filter, and degunked the carborator), and still was flooding. It ended up being the flywheel key. Cheap part, quick fix. I guess it can happen when you hit something hard with the deck, or it can just happen without reason... I hit a snowbank hard with my snowblower attachment, but I didn't even realize it until afterwards because it kept running fine. Supposedly, even after the strain to the engine, it won't always stall out. It will keep running (but maybe rougher) until you shut it off. Then when you go to start it again, you will have no luck because all the timing is out of whack. It cost me $80 to have a repair company fix it. I think the part was only $5.
May 19, 2010 | Craftsman 17.5 hp 42 in. Deck Lawn Tractor...
I've just had the same problem
check the fuel cap for a vent it needs to be vented . the air displaces the fuel no vent on fuel try running with the cap off . if it runs the vent was clogged or the wrong gas cap
Aug 07, 2009 | Poulan 42-Inch Steel Deck 17.5 HP Briggs &...
Murray riding mower 12.5 hp briggs & stratton spitting oil & gas out of carb & muffler when trying to start
Drain oil... it is full of gasoline due to a bad float pin and rubber gromet in your carb. When your float pin and gromet fail, gas just keeps flowing into your carburetor, eventually flooding your motor with gas and oil mix.
Jul 07, 2009 | Craftsman 17.5 hp 42 in. Deck Lawn Tractor...
Craftsman Lawn Tractor/ hard start/ whitish smoke
does it turn over slow or fast if it turns slowly thats the problem so it could be battery or starter they have to have a good amount of rpms to burn fuel right when starting if not it floods out the engine with gas hope this helps thanks wade
Jul 05, 2009 | Craftsman 21 Hp 42" Deck, Ys 4500 Lawn...
Craftsman 17.5 hp 42 in. Deck Lawn Tractor - CA Model Logo
730 people viewed this question
Top Craftsman Garden Experts
Wade Mobley
Wade Mobley
Dean Gruber
Roland W VanLue
Roland W VanLue
Are you a Craftsman Garden Expert? Answer questions, earn points and help others
