Question about Panasonic Room Air Conditioner CWXC104HU
Panasonic cs-c12cxp6 it is forming ice inside and the fan is not shooting as strong as be fore?
  • 478 Answers
You have a cloggeds evaporator coil. You can take it out and clean throughly with a water hose. Or you can get a spray can of evaporator coil cleaqner from one of the bigger homeimprovment stores. Furthermore, make sure that the filter is clean, and clean it often. You'll have to turn it off to allow for full thawing, but if you leave the fan on high it will speed the thawing of unit.
Posted on Jul 14, 2010
Panasonic cs-c9dkh air conditioner
I have problem with aircond Panasonic CS-C9DKH..5minit after start they stop automatic.Why this happens..The cooling fan also not running.It's because of fan or PCB.Please help me.......
Nov 17, 2012 | Panasonic Heating & Cooling
Ice maker problems
HI MAUREEN. i reckon u have left a spring off or the flap pivot pin out of place.start all over again and try.good luck.ali
Jul 12, 2012 | Refrigerators
Why ice is forming in some items kept inside at the back of the refrigerator including the vegetable tray.
Ice at the back of refrigerator section is usually due to a fan there that has become stuck, little fan like 2 1/2" or so, the fan circulates cold from the freezer into the refrigerator. If that cold air is not moved through than it will form ice there from moisture in the air of the refrigerator section. I have had that problem a couple times, could be from something pushed against back wall and got n the way of fan blades causing fan to stop.
Apr 18, 2012 | Samsung Refrigerators
Siemens Refrigerator model KA58NA70NE The ice maker section is not working. Please advice how to fix it.
I had the same problem and fixed it by changing freezer fan found underneath the freezer inside body, just behind the ice delivery/crusher motor. You need to open all the inside upper components like ice dispenser, ice maker, ice crusher motor, lamps assembly and finally the rear upper inside body cover. First, check whether or not the fan has strong air ventilation before trying to change the ice maker fan motor.
Feb 04, 2011 | Siemens KA62DV50GB Side by Side...
Ice sticing in ice dispenser chute
only use ice from the ice maker, some frost is normal, but , lower temp in freezer
May 19, 2010 | Whirlpool 25.6 cu. ft. Side-by-Side...
I have a Panasonic CS/CU-W18DKR - on cooling it works fine, auto aswell as fan, but on heating when it is on manual fan control it used to blow all the time, but not for some reason it only blows...
When the unit heats inside, the outdoor unit cools, and if the outdoor cooling coil gets too cold the system turns off indoor fan, and changes gas flow direction to de-ice the outdoor coil. Ensure both coils, and the filters are clean and if there is still a problem check system gas pressure for leaks.
Apr 18, 2010 | Heating & Cooling
Ice forming on inside of unit air not cold
clean the filters and check the drain, to clear the drain run a jug of warm water down the pipe
Aug 19, 2009 | Dometic Rooftop RV Air Conditioner
Re: Kenmore Top Freezer formed ice, main refrigerator area is not cooling Kenmore Top Freezer (Main refrigerator area) is not cooling; This trouble shooting has happened for the past year. Main...
not easy to diagnose. the basic fault is that the defrost system has packed up.
check that there is continuity thro the defrost heater. there may also be a thermal fuse in series with the heater so check that also.
if those ok, then points to a fault in the main module
Jun 22, 2008 | Kenmore 18.3 cu. ft. Top Freezer...
Panasonic Room Air Conditioner CWXC104HU Logo
81 people viewed this question
Top Panasonic Heating & Cooling Experts
Bill Long
Fotis Papastamatiou
Dennis Boxerman
Are you a Panasonic Heating and Cooling Expert? Answer questions, earn points and help others
