Question about Hotpoint RVM1625 Microwave Oven
Turn table doesn't rotate
The turntable doesn't rotate anymore. the micro is lessthan 1 yr old.
  • 5,911 Answers
If the oven is still heating, but the carousel isn't turning, this problem is commonly attributed to a turntable motor that has worn out and may need to be replaced. The motor is attached to the center plastic piece (called a turntable shaft, turntable ring or coupler) under the middle of the glass tray. The following link explains how to access and replace the motor:
http://www.fixya.com/support/r3555716-replacing_a_turntable_motor_on_a_microwa
This is a very simple repair, that usually is not expensive. The price range will be determined by the model and manufacturer. This repair can also be performed on an over the range model microwave oven WITHOUT uninstalling it.
You can refer to any of the following websites for comparison:
searspartsdirect.com
pcappliancerepair.com
appliancepartspros.com
repairclinic.com
The first three sites listed have helpful exploded view diagrams to assist you with locating and properly identifying the part(s) you may need.
If the model number is correct, the part number for a replacement motor is WB26X10038. If the coupler is stripped and needs replaced, the part number is WB06X10138. The average price for a motor is about $35. The coupler is less than $20. If you have any questions, please post back with your complete MODEL NUMBER and let me know. I hope this helps you.
Posted on Jul 13, 2010
Microwave turn table quit rotating
With the model number, we may have been able to give you a link to the actual service manual. Without it, we can only give you general answers.
The first thing I would suggest is a hard reset. Unplug the unit for a minute or so. Then plug it back in, set the clock and try again.
If that doesn't work, leave it unplugged for about 5 minutes, then try it again.
You can find links to helpful exploded view diagrams and part ordering help here.
I recommend that you bookmark that link to your favorites.
The turntable pad is used to turn it off for cooking without the turntable, then to turn it back on when you do want to use the turntable.You can find links to helpful exploded view diagrams and part ordering help here.
The turntable system consists of the motor, the coupler, the turntable support with rollers, and the tray.
You can see and hear a video of how a turntable motor should sound when you rotate it by hand.
If yours is not set to be off via the control panel, and it won't rotate or it sounds like it's grinding, etc., you may have a bad motor or plastic coupler.
To replace either, you need to unplug power, then remove the bottom cover of the oven.
In some brands, you have to cut the motor cover off with snips, then use a screw when reassembling it.
Aug 10, 2013 | Microwave Ovens
Sharp r-1850a turntable problems
turntable motor p/n 46-841666-3, available from searspartsdirect.com, use correct model #!!
Feb 09, 2013 | Sharp R-1850A Convection/Microwave Oven
Frigidaire FMT 148GP Microwave oven. Turntable
1. the motor to rotate the glass table in the micro wave may have stop working or the switch to the motor is defective.
Mar 13, 2010 | Frigidaire FMT148GP Microwave Oven
Intense squeaking noise
When microwave is running, turntable squeaking when rotating. Can problem be fixed? Microwave is about twelve years old.
Mar 07, 2010 | GE Spacemaker JVM1640SJ Microwave Oven
I have a GE Spacemaker II microwave: JEM25GY that died. It seems less expensive to replace rather than fix. Power works; it doesn't heat. New models all apparently have turntables; mine didn't and I...
YOU CAN TRY REMOVING THE GLASS TRAY AND TURNTABLE AND REPLACING IT WITH YOUR OLD GLASS TRAY (IF YOU HAD ONE) OR JUST ANY GLASS MICROWAVE TRAY. WITHOUT THE TURNTABLE, I CAN'T SEE HOW IT CAN ROTATE.
Nov 28, 2009 | GE Spacemaker JVM1640SJ Microwave Oven
I have a microwave oven i purchased jan/07.Themodel#nn-s605wf,serial#6BN6040597,. mY TURNTABLE will not turn can you tell me why.THANKS
Remove the glass turntable, then the roller ring. Then seta glas of water in the unit and turn it on for 5 to 10 seconds. Look through the door window and see if the drive hub is rotating. If it is, then check the underside of the glass table to match up the drive hub. If it isn't turming, the drive, then it is internal and should have a 1 yr warrantee minimum. Remember, the, the turntable and drive must engage each other and the roller ring in place. Good Luck, and let me know please. One more thing, make sure there isn't a Turntable on/off swirch set in the off position. Good Luck, Ne
Oct 14, 2009 | Panasonic NN-H504WF Microwave Oven
27 day old MH1160XSQ micro-wave- turn table will not turn.
Since it's less than one year old, it should be fully covered under warranty. I'd suggest contacting the manufacturer to get it fixed free. Whirlpool customer service is here.
For owners whose oven is out of warranty, read on:
If yours is not set to be off via the control panel (and your model does not have this feature) but it won't rotate or it sounds like it's grinding, etc., you may have a bad motor or plastic coupler.
You can usually find helpful exploded view diagrams and order parts by entering your full model number here.
There should also be a "mini-manual" hidden inside the unit behind the control panel or hidden on the left side behind the grille, which is very helpful when troubleshooting & testing.
Aug 13, 2008 | Whirlpool Microwave Ovens
Goldstar MV-1501 1000 Watts... Problem:
if micro. new then its defective
if micro. old then you need replacement or service the heating element and turn table motor
Jun 02, 2008 | Goldstar MV-1501 Microwave Oven
Noisey turntable
try pulling on the plastic drive and inspect it you just pull up on it to remove it
Jan 30, 2008 | GE JVM1440 Microwave Oven
Glass plate turntable won't spin any more
no microwave 1.5 yrs old has a belt - they're all motor driven
Jan 10, 2008 | GE XL1800 1100 Watts Microwave Oven
Hotpoint RVM1625 Microwave Oven Logo
90 people viewed this question
Top Hotpoint Microwave Ovens Experts
William Miller
William Miller
Jim Thurston
Are you a Hotpoint Microwave Oven Expert? Answer questions, earn points and help others
