Question about Brother MFC-5440CN All-In-One InkJet Printer
Unable to clean cartrigde
My printer won't go past this message. the sponge holder is full of ink. could this be the problem and if so, can I get a replacement somewhere ??
  • Brother Master
  • 379 Answers
The problem is due to the fact that Brother machines excessively self-clean. Each time they self-clean a small amount of ink is dumped in to a holding tank/sponge. When a predefined number of self-clean operations have been performed, the machine refuses to print and gives the error message you have stated. Brother state that the tank/sponge must be replaced before the counter is reset, again by a Brother agent.
However, there is a way of reseting the self-clean counter yourself - if you Google your model number and the error code somewhere in the results you'll find how to do it. The only risk of doing this without changing the tank/sponge is that it will eventually overflow and leak out the bottom, but I did my Brother all in one some time ago and have had no problems yet.
Posted on Jul 13, 2010
Error message reads "unable to
It means that the printer is unable to clean the print head number(s) 46. The print head is located under the ink cartridges. Remove the cartridges, and you should see a plastic piece with a hole in it to put your finger under and snap open. This allows you to see the print heads. The print heads look like a sponge type dabber on top of a plastic case. Grab a hold of the print head and pull it out. Look for ink that has spilled behind it or on any of the brass colored computer connections. use warm water and a lint free cloth to scrub it off. Press the print head sponge with your finger and make sure that ink primes and fills the head then put the printer back together and try a test page. If you stll get the error then you need to contact brother for a print head replacement.
Jun 29, 2011 | Brother MFC-465CN InkJet Printer
Waste ink absorber is full, so the copier will not print.
Hi
For clean the your ink absorber please follow the mention below steps.
  1. Open your printer.
  2. To protect hands from Ink wear thin latex (or similar) gloves.
  3. Locate the Waste Ink Pads on the inside of your printer. They are on the right hand side and are quite small.
  4. You can remove the pads and the holder with a gentle pull.
  5. Using a tissue, soak up as much ink as possible and clean the area around the waste ink area.
  6. There is one more waste holder in the right back bottom of the printer. A kind of sponge. There are few screws and plastic parts to be removed and this sponge needs to be washed, dried and placed again. Be careful and patient. This is no understatement. On the iP1500 this requires the dismantling of most of the printer. Take a photograph (even with your cell phone) so you can trace back your steps. On the iP1500 the drive motor on the side (Just behind the waste ink pads) has to be removed to get to the main sponge. You also need to take care as you lift the slide/carriage. Below this you find 5 little springs.
  7. Carefully replace the holder and the pads. Close printer.
  8. Whilst printer is disconnected from the mains power, press and hold the power button and reconnect to ac power.
  9. Release the power button.
  10. Press the power button again.
For more help see the video
http://www.youtube.com/watch?v=VVpjqBr7KjU
Jun 02, 2011 | Office Equipment & Supplies
Ink absorber is full
Locate the Waste Ink Pads on the inside of your printer. They are on the right hand side and are quite small.You can remove the pads and the holder with a gentle pull.Using a tissue, soak up as much ink as possible and clean the area around the waste ink area.There is one more waste holder in the right back bottom of the printer. A kind of sponge. There are few screws and plastic parts to be removed and this sponge needs to be washed, dryed and placed again. Be careful and patient. On the MP240 this requires the dismantling of most of the printer. Take a photograph (even with your cell phone) so you can trace back your steps. On the MP240 the drive motor on the side (Just behind the waste ink pads) has to be removed to get to the main sponge. You also need to take care as you lift the slide/carriage. Below this you find 5 little springs.Carefully replace the holder and the pads. Close printer.Whilst printer is disconnected from the mains power, press and hold the power button and reconnect to ac power.Release the power button.Press the power button again.
Nov 30, 2010 | Canon PIXMA MP240 All-In-One InkJet...
My canon ip1000 printer does't want to respond. it wrote "waste ink absorber is full". what i should do?
Well under where the Ink heads "Park" there is a "waste ink absorber" pad type thing. This needs to be "emptied". You need to look in tour manual for exact instructions.
Feb 11, 2010 | Office Equipment & Supplies
Brother .unable to clean.brother dcp340cw.have
the message unable to clean comes from either the print head being stuck in the machien for one reason or another, or the sponge insode the machine is full full of ink. you can try unplugging the machine for an hour or two and seeing if that clears the problem but you will probably need service on the machine
Nov 17, 2009 | Brother DCP-340CW All-In-One InkJet...
Clean Unable 46
Clean unable 46 means that the ink tank is full. You need a replacement tank installed and the count reset. This is a holder inside for the used ink,best to be a shop repair.
Jun 23, 2009 | Brother MFC 240C All-In-One InkJet Printer
Wont let me clean
Unable to clean means that the waste-ink "sponge" is full. Unfortunately, that's not something us users can change, but the machine would require to be sent to service. So if your machine is not withing warranty, I'd doubt it'll be worth the service cost.
Jun 01, 2009 | Brother DCP 115C All-In-One InkJet Printer
Help with absorber
Someone else asked same question on this site and got answer:
http://www.fixya.com/support/t198707-ink_waste
I also had that message. This seemed to work to clear the message and let you carry on printing.
Also, I may be wrong, but the actual ink absorber is the sponge part by the rollers underneath when it prints. I dont know if it has sorted the actual problem, but I took the sponge part out (I have an MP130 and the sponge part lifts straight out if you carefully put your finger underneath it on the left hand side) and let it soak in water, sqeezing it to get the ink out (It was full of ink so careful not to get it everywhere as it can be a little messy). When it had dried, I carefully put it back in (make sure you put it in the right way around).
Hopefully that now means the ink absorber is again empty AND the error message has gone.
Not sure about the whole cleaning the sponge idea, but I did it and according to the manual that sponge is labelled as the ink absorber so technically I have emptied it?
I haven't seen any posts about actually cleaning the sponge so take that part as you will.
Dec 18, 2007 | Canon PIXMA MP130 All-In-One InkJet...
I get message carrier stall - error 1200
Try this 1.Disconnect power to printer 2. Force the cartridges to the left and then to the right 3. Clean at the transparent strip behind the cartrigde holder (Encoder strip) Be careful not to pull on the strip Hope this helps.....
Oct 08, 2007 | Dell 922 All-In-One InkJet Printer
RECOGNITION OF GENUINE CANON INK CARTRIDGE
I posted the original problem. Although the cartridge was genuine I had taken it out and reinserted it as I wasn't sure I had loaded it correctly the first time. Advice from my local retailer was that this was a mistake. Canon PIXMA printers no longer recognise a cartridge once it has been removed. Solution was another new cartridge which I shan't remove until it's empty. When this second cartidge is empty I shall try the first cartridge again as it is still full and unused. It has yet to print anything! Why Canon's helpdesk couldn't help is a mystery. I conclude that Canon's printer management systems are unfriendly to users. They are friendly only to Canon. I hope my experience will help others especially those considering buying a Canon printer. dudbob
Jan 22, 2007 | Canon PIXMA iP1600 Printer
Brother MFC-5440CN All-In-One InkJet Printer Logo
128 people viewed this question
James Cagle
James Cagle
Samyfam
Samyfam
Victorman
Victorman
