Question about Samsung PCL545R 54" Rear Projection Television
Samsung PCL545R Color adjustment!
We bought this TV from a friend and all the pictures are red, yellow or orange. We have tried to adjust the contrast, brightness, sharpness and all the ones on the menu screen, but nothing has help. We have no manuel for this tv.
Please help if you can?
Thanks Rhonda
  • bmx123 Apr 30, 2008
    I have a vision quest tv new for two weeks. the screen shows mostly ready. I cannot adjust to factory settings
    Genius:
  • 3,587 Answers
I'd recommend you return it to your friend..sounds like quite an issue with the innards.
Posted on Apr 20, 2008
Picture is yellowish and dim hard to see during daylight
you will have to change the coolant under the blue and maybe the red crt lens
Apr 18, 2010 | Samsung PCL545R 54" Rear Projection...
RED CONVERGENCE SCREEN PATTERN BOWING AND CAN'T ADJUST
The most likely cause is shorted convergence chips and possibly a few pico fuses.
These sets need to have all three colors - RED - BLUE - GREEN - lined up correctly on the screen in order for the picture to look normal. This is called convergence.
When its out of alignment the video will look 3-D, wavy, distorted, etc. Most of the time you just need to adjust your convergence in the menu. If you cannot adjust it in the menu - then your convergence is broken and needs to be repaired. Convergence problems are very common on all Projection TV sets including Sony,Samsung,JVC,Philip Magnavox,Panasonic,Akai,Pioneer Hitachi,Mitsubishi,Zenith and others.
You can get a convergenece repair kit with instructions from the links below.
Here are some of the most common problems with these sets...
Problem #1) Convergence
Yours may have one or more of the following symptoms...
*Screen Looks 3-D
*Colors wont align
*Screen may look distorted or warped
*No Audio/Video - TV Shuts down - May also make a constant chirping sound
Problem #2
Another common problem is dull or washed out video.
Your set may have one or more of the following symptoms....
*Dull looking picture
*White looking picture
*Halos around objects
*Red/Orange looking picture
You can see some more examples and find a fix herebb0cf99.pnghttp://www.fixya.com/support/r2861467-solution_video_looking_whiteish_dull
Jun 13, 2009 | Samsung HC-P4752W 47" Rear Projection...
Blurry, Multi-Color, Multi-Line
covergence problems and its not adjustable you need work done on the convergence board or a new board and realignment which can be timely.
Nov 01, 2008 | Samsung DLP HL-P4663W 46" Rear Projection...
Picture blury
Its behind the speaker grille up front , remove the grille and then a small access panel and you will see the focus control with 1 button for each CRT 3 buttons in all.
Jun 16, 2008 | Samsung PCL545R 54" Rear Projection...
No green or blue color in pictures!
You need to find a qualified servicer. You have component failure.
Look for TV Repair on craigslist or yellowbook.
Craig www.classtorations.com
Apr 20, 2008 | Samsung PCL545R 54" Rear Projection...
Rear projection tv
the wing-nuts on the tubes are for focus. try adjusting the screen control for all 3 tubes and see what you get. there will be a square type object that you see in the front near the picture tubes. turning left will decrease the luminous for that specific tube and right will increase***do not turn too far right because you could make the set go into shutdown. if you see lines in the pic then start turning it back the other way*** if that works then glue the knobs so next time you don't have this problem again. otherwise you might have loosened a connector somewhere inside tv.
Feb 20, 2008 | Samsung PCL545R 54" Rear Projection...
Bad ghosting of all colours
When its out of alignment the video will look 3-D, wavy, distorted, etc. Most of the time you just need to adjust your convergence in the menu. If you cannot adjust it in the menu - then your convergence is broken and needs to be repaired. Convergence problems are very common on all Projection TV sets including Sony,Samsung,JVC,Philip Magnavox,Panasonic,Akai,Pioneer2_bing.gif Hitachi,Mitsubishi,Zenith and others.
*Screen Looks 3-D
*Colors wont align
Problem #2
You can see some more examples and find a fix herebb0cf99.png http://www.fixya.com/support/r2861467-solution_video_looking_whiteish_dull
Jan 09, 2008 | Samsung PCL545R 54" Rear Projection...
Blue and yellow color
Blue should converge on top of "yellow".Bad connection(s)
on blue convergence IC.Replace both IC's for durable repair.
Check pico fuses.Reset convergence alignment.
Oct 17, 2007 | Samsung HCL552W 55" Rear Projection...
Black Lines when picture is bright
Are those lines all the way up/down your set? Or just in small zig-zags?
Dec 17, 2006 | Samsung PCL545R 54" Rear Projection...
Samsung PCL545R 54" Rear Projection Television Logo
131 people viewed this question
cce772000
Level 1 Expert
