Question about IBM ThinkPad R30 2656 Notebook
When I power on my laptop it be's a white screen and then goes black after a few seconds. I can hear the sounds and everything else works normal. I'm confused about the problem.
  • IBM Master
  • 5,105 Answers
You have a failed backlight or an inverter issue. Look at the screen from about an inch away and check if you see a dim image. If you do, it's the backlight only. For a replacement backlight, see http://www.lcdparts.net/CCFL3D.aspx (look for the Lenovo/IBM and your screen size). To replace the backlight, take the screen away from the bezel (sometimes it is held with screws) Remove the tape, and the frame holding the parts together and separate the reflector (make a note of how things are put together) then you have to Dremel (or use another rotary tool) to remove the plastic to get the backlight out. (They are often molded into the frame.) Then put in the new backlight and reassemble everything. lcdparts.net has some specific laptop repairs (http://www.lcdparts.net/howto/default.aspx) but for an overview: http://www.inventgeek.com/Projects/BacklightFix/overview.aspx
To check the inverter, open up the screen section of the case and remove the shielding. The inverter is a board usually near the bottom of the screen Look for any scorch marks or bulging or damaged capacitors. (Sometimes other parts will fail on this part but these can be spotted easily. Capacitors look like cylinders on a tripod.)
If you borrow (or have a) high-end multimeter (able to measure high frequencies - 50 kHz) or an oscilloscope, hold the multimeter probes a fraction of an inch apart about an inch above the board and power up the TV. If you see a 1 or an actual value, you have a good inverter. If you see a reading near 0, the board is bad or the multimeter can't resolve the frequency.
In either case, you can buy a replacement inverter for $50-150 and just do a simple swap. Disconnect all of the wires (connections are similar to molex and ribbon cables in a computer) and remove board (a few screws usually). Connect the cables to the new inverter. (If you google backlight inverter replacement, you'll find videos and text descriptions.) Note the part number on the board, including the Rev number, and order the exact one (shopjimmy.com or lcdparts.net are good starting points). Universal inverters do exist but can result in reversed controls (up to lower the brightness). Replacing individual parts on the board is cheaper but more prone to not tracking down all of the bad parts.
I hope this helps.
Posted on Jul 13, 2010
KV-HP212M83 greenish blackout blinks 2 times
Measure B+ on the set , If normal check G2 voltage
G2 adjustment is on the Flyback Transformer
Oct 14, 2012 | Sony FD Trinitron WEGA KV-32FS120 32" TV
For the last 3months,my dell vostro 1088 laptop has started giving a lot of trouble.While i'm doing working on it,the screen suddenly starts blinking and it all goes white within a second.This pro
  • Remove the battery and disconnect the power cord.
  • Press power button for a few second.
  • Connect the power cord. Press the power button to start and then dock the battery.
  • White screen on a laptop is a connection problem between the LCD screen and the video cable running from the motherboard. The issue can arise with the motherboard or the screen might contain a defect.
Aug 22, 2012 | Dell Vostro 1088
Advent Laptop deemed unrepairable
Try using your laptop on power supply (not on batteries).
Jul 29, 2012 | Advent Computers & Internet
Dell monitor screen suddenly went white. Can it be fixed?
I have a strong suspicion that you have burned a capacitor or two on the monitor. You will need to bring this in to have it serviced as it will require the monitor to be opened up and new capacitors replaced/resoldered.
Mar 18, 2017 | Dell Model 2208WFP - 22 Inch Widescreen...
My Inspiron 15r is not allowing me to use it. I was dropped slightly yesterday, a little over a foot, but looks physically fine. Sounds normal too. When I turn it on, it starts booting up normally, but...
Hello
The problem you defined shows that the windows gone corrupt, the cause may be due to hard drive or just data lose.
The quick remedy is re-installtion of operating system, hopefully it will works otherwise i am afraid the hard drive may physically damaged. which will also repaired if shock is low intensity.
Good Luck
Dec 15, 2010 | Computers & Internet
My averatec 3700 laptop is not performing properly. When the computer is powered on, I hear the fans as usual; the "Averatec'' screen flashes for a couple of seconds; then the screen goes black. I can...
Does not sound good, the onboard video chip is more than likely fried. all you can do now is try plugging in a external monitor and see if that port still works. You may try replacing the LCD inverter board, but I don't think it will help.
Jul 07, 2009 | Computers & Internet
Blank screen upon startup
Try taking out the hard disk, plug in power and see if you have a display on your screen or external monitor. if same thing happen, try taking out the memory card. If you hear a beep sound it's a faulty mem. card, if no beep sound appears I suspected it's a motherboard faulty.
May 31, 2009 | Lenovo ThinkPad T61 Notebook
Monitor comes on, I can see everything perfect then goes black
"Most" newer monitors will let you know if the are no longer receiving a signal. Sounds like the backlight is burnt out. Try getting a bright (LED works best) flashlight and shining it at the screen at all angles to see if you can see any of what you were doing. If the backlight is on the fritz, either return it on warranty or buy a new one.
Jan 31, 2009 | Westinghouse L2046NV Monitor
Negative screen image
Look in System Preferences for Universal Access, there is a Display option which says Black on White(the normal setting) and White on Black (the setting that has been enabled).
There is a keyboard short cut to change the setting, it involves pressing four keys - Apple, Option, ^ and 8.
Nov 29, 2008 | Apple iBook G3 Mac Notebook
IBM ThinkPad R30 2656 Notebook Logo
148 people viewed this question
Top IBM Computers & Internet Experts
Computer Links
Are you an IBM Computer and Internet Expert? Answer questions, earn points and help others
