Question about HP Photosmart C4580 All-in-One InkJet Printer
Printer set on 4500 need 4580 - HP Photosmart C4580 All-in-One InkJet Printer
  • 666 Answers
Direct link to driver page install the new drivers and let us know if you have any further problems
http://h10025.www1.hp.com/ewfrf/wc/product?lc=en&dlc=en&cc=us&product=3418707
Robb
Posted on Jul 13, 2010
Canon irc4580i print dark problem
In the process used printer, will be inevitable printed page by your printer have the bad quality prints. For example: Toner specks, Light image, Vertical line, Dropouts, background, Toner smear, Vertical black line and band, Vertical white line, Background scatter, Black pages, Loose toner, Horizontal stripes, Ghost, Uneven Density, poor fusing ...
The common print quality problem Canon IRC-4580 printer
Currently, The Canon IRC-4580 is the laser printer have high speed, easy to use, friendly for user and printing clear text.
However, we can not avoid the damage of some components of the printer when used.
In this article, I will introduce some basic errors with printing quality problems of Canon IRC-4580 printer and "How to fix it".
After viewed artical, you know:
- How to fix (repair/solve) Vertical line (black or white) in Canon IRC-4580 printer
- How to fix (repair/solve) Poor fusing (loose toner) in Canon IRC-4580 printer
- How to fix (repair/solve) Uneven Density in Canon IRC-4580 printer
- How to fix (repair/solve) Light image in Canon IRC-4580 printer
- How to fix (repair/solve) Ghost in Canon IRC-4580 printer
1. Fix print quality problem "Vertical line" for Canon IRC-4580 printer How to fix print quality problem Vertical line
This plobrem "Vertical line" is usally error of Canon IRC-4580 printer. For this "Vertical line" error, technicians divided into two smaller error are: Vertical black line and band and Vertical white line.
Description:
- Vertical line and band: On the printed image appear some straight thin black vertical.
- Vertical white line: On the printed image appear some white vertical voids.
Error location:
- Surface of the charge roller
- OPC drum
- Cleaning blade
- LSU unit
- Developing roller
Cause of error "Vertical line" on the printed page:
- May be surface of charge roller scratched or dirty by toner powder.
- May be have some grooves on the OPC drum.
- May be cleaning blade is damaged.
- May be LSU window or LSU lense has dirty.
- May be surface of developing roller has scratched.
How to fix(repair) "Vertical black Line and Band" for {{SPkey1}} machine:
- Replace the charge roller of toner cartridge.
- Replace the OCP drum.
- Replace the cleaning blade
If printed page are not improved
- Clean the LSU unit by soft cotton cloth and try to print. If Vertical line is not clear on the printed page you should replace LSU unit.
- Replace new axis developer and try to print
2. Solve print quality problem "Poor fusing (loose toner)" for Canon IRC-4580 printer. How to fix print quality problem loose toner
Description loose toner: Toner is not properly fixed on paper, use to hand rubbing lightly on the printed image toner powder may be stick in hand
Error location: toner cartridge or fuser unit
Cause of error "Dark Image or black" on the printed page:
When toner cartridge is empty. You toner refilled by toner powder ware not compatible. This is makes toner cartridge components demaged and temperature of fuser unit is not enough melt to toner powder
How to fix(repair)"Poor fusing (loose toner)" on the printed page for Canon IRC-4580 printer:
With this error, you should replace toner cartridge or fuser unit to fix it.
3. How to fix print quality problem "Uneven Density" for Canon IRC-4580 printe How to fix print quality problem Uneven Density
Description: The printed page has one half light and one half clear.
Error location: Toner cartridge, transfer roller, springs, doctor blade
Cause of error "Uneven Density":
- The pressure force on the left and right springs of the transfer roller is not even.
- May be toner low also causes this error
- Doctor blade has bent
How to repair error "Uneven Density" on the printed page for Canon IRC-4580 printer:
- Replace springs and transfer roller.
- Toner refill toner cartridge Canon IRC-4580 and reset toner cartridge chip (replace new chip) or replace new genuine toner cartridge.
- Replace doctor blade.
4. How to solve print quality problem "Light image" for Canon IRC-4580 printer How to fix print quality problem light image
Description: The printed image is all light and no Ghost.
Error location: Toner cartridge, Developer, HVPS board
Cause of error "Light image" on the printed page
- Enabled toner save.
- Toner cartridge is low
- OPC drum may be faulty by strong light intensity
- Temperature in room is below than 10*C
- Bad contact caused by the toner dirty between the high voltage terminal in the HVPS and the one in the set
- Abnormalities output from the HVPS
How to fix(repair) error "Light image" on the printed page for Canon IRC-4580 printer:
- Disable toner save by change in printer driver.
- Replace the OPC drum.
- Replace developer.
- After printer is power on, wait 30 minutes then start printing
- Clean up the contact between the high voltage terminal in the HVPS and the one in the se- Replace the new HVPS if the problems are not solved by 4 away above.
5. How to fix print quality problem "Ghost" for Canon IRC-4580 printer How to fix print quality problem Ghost
Description: Ghost occurs intervals of the OPC drum or transfer roller.
- OPC drum has fauty.
- The life of the transfer roller has been expired
- The high voltage terminal is contaminated by toner powder or
- Replace OPC drum
- Replace transfer roller
- If performed 2 away and the error does not clear, you should replace ganuine toner cartridge .
- Replacce HVPS board.
Oct 29, 2016 | Canon Office Equipment & Supplies
My hp 4500 cannon printer will not print my emails
Go into your printer settings on your computer, and make sure the HP 4500 is set as your default printer (right click on it and select "set as default")
Apr 13, 2015 | HP Office Equipment & Supplies
How do you remove/open printer to take out cartridge on hp 4580 printer
Access the manufacturer's web-site: http://support.hp.com
Enter: 4580
and do the search.
Choose from:
» HP Deskjet F4580 All-in-One Printer » HP Officejet J4580 All-in-One Printer » HP Photosmart C4580 All-in-One Printer and read the online documentation for the specific model. It will describe the exact steps.
Jul 12, 2011 | Computers & Internet
Changing font settings for HP 4580 Printer
You must change the font in the word processing program not the printer
Apr 10, 2010 | HP OfficeJet J4580 All-In-One Laser...
Users Manual for HP 4580 All-in-one Printer. How
Please download the user manual from this link
static.tigerdirect.com/pdf/HP-Officejet-J4580-Printer-Manual.pdf
Hope this information will help you
thank you
Oct 02, 2009 | HP Computers & Internet
OKIFAX 4580 - Comms error
Hi just a note to say first theing to check is that the phone line is connected at both ends to correct sockets and that the connector to teh fax unit is connected to the line socket and not the phone socket as this is the main cause of line errors.. Good luck you could also check to see of you need to dial 0 or 9 first before you dial your number as you ma y be on an exchange line.. also check the fax settings to see if you have set the line type correctly either pulse or tbx..
Jun 30, 2009 | OKIFAX 4580 Plain Paper LED Fax
Problem of incompatible cartridge occure in my new J 4580
i had the same problem with the hp 4580. i needed to replace the black ink which i did. then the error message appeared "incompatible print cartridge tri color"...chatted with hp customer support, wasted a hour. claimed its a hardware problem need to have it fixed. i asked would i be charge he said yes but the printer was under warranty. he asked other questions...bottom line i left the chat box....bought another hp 4580, used same cartridges, same message...THEN finally i replaced the color cartridge...and BAM! it worked on both printers. solution...replace the color cartridge...cons..if this happens again its a waste of money to keep buying the colored ink...
Feb 03, 2009 | HP J4680 Office Jet All-In-One Printer
Incompatible cartridge error in j 4580
refix your cartidge .may be your cartridge is faulty.
Dec 25, 2008 | HP OfficeJet J4580 All-In-One Laser...
Installation cd
Hi Teresa,
Double check your model number, I think the numbers you are quoting refer to a range of printers.
Check out Lexmarks website to find the correct driver.
Hope this helps,
Andy
Jun 26, 2008 | Office Equipment & Supplies
My printer is online and our network is working, but nobody can print to the central printer.
can you see the printer in your settings panel? Try a test print. If not, it's driver corruption 101. You may need to remove the printer(in Add printer mode) then reinstall it.
Feb 06, 2008 | Office Equipment & Supplies
HP Photosmart C4580 All-in-One InkJet Printer Logo
87 people viewed this question
Seeker5211
Seeker5211
