Question about McCulloch FG7000MA 7000 Watt 13 HP 389cc Portable Generator
My generator turns on but, supply's no power?
    Scholar:
  • 142 Answers
You must check:
  1. Are your breakers ON?
  2. Measure the voltage on generator terminals.
  3. If the voltage is less than 20 V AC, you should check the excitation field, rings and brushes, AVR - rectifier, cables and fuses.
  4. If every thing is OK you may need to recharge the DC field with a short connection of "+" and "-" of a 12 V battery to respective field terminals when the engine is running.
  5. If the AC voltage raises for a second and drops when you disconnect the battery - the excitation circuit is bad.
Posted on Jul 14, 2010
Fixing an old generator, Whiting Hercules, won't turn over, starter and solenoid works. It doesn't click anymore and it runs on propane.
How is the battery Beverli? The battery not only turns over the motor but also supplies the spark.
You are posting to the category of 'Webcams'. I changed this post and your last one to 'Power Generators'.
Oct 07, 2015 | Electrical Supplies
Generac generator won't turn off in automatic
It is possibly a transfer switch issue, not the generator control board. Have an electrican kill utility power, let it start and run, then disconnect the sensing wires in the ATS. If it stops problem is ATS
Mar 01, 2015 | Generac Electrical Supplies
How to test the electrical system of the generator for free
Ez test to determine if stator wiring is ok. This test works on generators that have two sets of 115v plugs and 220v plug. Use a 12v, 1amp ac power supply ( smaller ac power supply should work ok ). With generator not running, apply 12v to one of the 115v outlet plugs. Now verify 12v output voltage with meter at another 115v outlet on generator. Also verify that there is about twice the voltage at the 220 v outlet plug (should be about 20v - 24v) . If the adjoining 115 v outlet plug has no output or very little voltage or if the 220 volt plug has no output, most likely stator is damaged or breaker is off. If the stator is shorted voltage reading will be very low and power supply will heat up. If stator is open, there will be no voltage at second 115v plug or 220 v plug. If voltage is ok at the other outlet plugs as per test above then most likely problem is with voltage regulator, or brushes not making contact or armature winding open or just needs to be energized. Unplug the 12v power supply after test to prevent it from overheating. Most generators have two 115v windings that together power the 220v plug. When you energize one of the windings with the 12v power supply, the second 115v winding will be energized also and give you a voltage reading about equal to 12v. You will not damage the generator with this small voltage being input thru the plug. Good luck
Oct 14, 2014 | Electrical Supplies
Just paid over 1,500 last year an has not rungood since. starts up real good, but once aair is turned on it stops running, or it might run one air at times. on my way back to michigan an not a happy...
This generator is a 5KW model. This means it can supply up to 5000 watts of power, total. Not all devices list the watts they need to be provided - instead these devices list the power they need as volts and amps. This can make it hard to determine what the actual watt requirements are for the device.
Overly simplified, watts is equal volts times amps (watts = volts x amps). A single 120 volt light bulb that uses .833 amps consumes 100 watts. If you checked a regular 100 watt light bulb with an ammeter, you'd find it does indeed draw .833 amps.
Working the formula a different way, we can learn how many amps this 5000 watt generator can supply at 120 volts, too. If all the loads you need to connect to this generator are 120 volt types, that means the total amount of amps the generator can supply is 5000 watts / 120 volts = 41 amps purely resistive loads (like a toaster or light bulb) maximum under ideal conditions. There is never a time when ideal actually happens, and not all loads are purely resistive - many are inductive. Inductive loads are motors (like your A/C), fluorescent lamps, computer power supplies, etc. - so figure more like around 30 amps total instead.
If you try to connect devices that require more than 30 - 35 amps, the generator will probably have problems trying to supply this load for any longer that a short length of time. Additionally, motors like those in A/C compressors draw significantly more power when first starting and can cause the problem you are describing. Try running the generator with loads other then the A/C to see how well it can supply the load(s). Or try running only 1 A/C unit and other non-A/C loads.
What I'm trying to tell you is that you may need to do some active load management to be sure that you aren't trying to get more power out of the generator than it is capable of supplying. You may need additional generators or swap this one to a larger size to handle the load properly and safely.
I hope this helps & good luck!
Apr 09, 2011 | Watts Onan Portable Generator - 5000 ,...
I'm dumb. Can I hook an inverater to my generator and produce more enegry than my generator produces???
Please understand that the generator produces power from fuel with an engine wheras the invertor is one which genrerates power from a stored battery using the principle of frequency switching a DC source to induct and produce AC.
Now you can have an uninterupted power supply setting with the invertor backed up by the generator so that when the battery voltage goes down you can start and charge the invertor and also supply the extra energy .
the ratings of both must also be considered.
Sep 25, 2010 | Electronics - Others
Honda 7000w generator outputs 6vAc when idling. When I rev it, power is then supplied. Why?
Well I dont know, but I do know that when it idles nothing is going to work. So whats the use of having a generator idle? Generators must turn at 1800 or 3600 rpm to operate.
Mar 13, 2010 | Honda Electrical Supplies
I can't remember if you plug in the generator to the electric panel first (with power turned to the generator and off of the main line feed) and then start the generator, or start the generator and then...
OK, by talking about a plug, I am assuming you have made a double male plug to hook the generator to the electric panel. This is not really advised, because it is so easy for it to be plugged into an outlet by someone not knowing what it is far, and getting electricuted. Now, away from preaching, and to helping.
It is best to hook it to the generator and then crank it, so you are not dealing with a load when you plug the systems together. When your power is restored, it would be good to install a plug to your electrical box and have it go to a disconnect like is on your outside A/C unit. It moves you away from the hot wires.
Hope your power is on soon!
Dec 21, 2008 | McCulloch 13HP 338 Cc Portable Generator #...
Fridge displaying F16 and sonic alarm sounding.
Could be that the generator cannot supply the surge power needed for the compressor to get going.
Jul 04, 2008 | Whirlpool GS6NBEXR Side by Side...
Non-operational in RV when Onan generator and Xantrex inverter are on
Are you still under warranty with your RV? If so, take your RV back to them and try to get this problem fixed through them. You know more about electronics than I do (LOL) however, I do believe the RV sales/repair should be taking care of this issue for you.
I on the other hand own the Majestic brand washer and dryer and I am very dissapointed with them. The washer is broken already and is only 15 months old. Ugh!
Good luck, I hope your issue is a simple fix.
Oct 28, 2007 | Splendide 2100 Vented Washer-Dryer
Tv Is not respondind
This denotes a problem with the power supply either the low voltage power supply of the high voltage power supply. You will need the following documents and equipment if you plan on doing this yourself: 1) a schematic diagram 2) a Multimeter 3) an oscilloscope 4) a signal generator (color bar, cross hatch, and purity) The schematic will let you know where the test points are and the level of voltage and signal are supposed o be at the test point. The multimeter will allow you to trace and measure DC and AC voltages throughout the set. The oscilloscope will allow you to view the waveforms generated by the signal generator, this is needed to tell if a component is not processing the signal in the proper fashion. The signal generator creates a standard reference to measure by. Since this prolem is in the power supply section you should determine if the problem is a blown fuse by visually inspecting the fuse. Than you will need to determine if the problem is in the high voltage power supply. You do this by checking the transistors in the horizontal section of the TV. you will find the problem either in the low or high voltage power supplies.
Oct 01, 2007 | Televison & Video
McCulloch FG7000MA 7000 Watt 13 HP 389cc Portable Generator Logo
495 people viewed this question
Top McCulloch Electrical Supplies Experts
John Trevino
Craig Butler
Craig Butler
Are you a McCulloch Electrical Supply Expert? Answer questions, earn points and help others
