Question about Sears Craftsman LiftMaster Chamberlain Garage Door Opener Wireless Keypad Model 976LM Security+
How do I tighten sagging garage door chain?
The chain on my liftmaster garage door opener is sagging. When I press the button to open or close the door, it just hums. How do I tighten the chain?
    President:
  • 3,197 Answers
I think you have more problems than just a sagging chain. It is most likely sagging because the bronze bushing at the gear and sprocket assembly is bad. It lets the sprocket lean forward and loosens the chain. You will also need to remove the cover from the motor unit and check the drive gear. It is a white gear just in front of the motor and is most likely stripped.
Posted on Jul 13, 2010
With my door closed, i push door button to open and the chain and opener continues inthe closing mode. any help?
Shop for sears craftsman liftmaste... on Google
Garage Door Opener Gear...
$31.45
Sears Parts D... Liftmaster 41C4220A Ge...
$21.75
Preferred Do... Chamberlain/l... Sprocket, Gea...
$17.95
eBay Direct Replacement f...
$20.95
Moving Up G... Liftmaster 41c4220a gea...
$31.67
North Shore... Search Results
    Liftmaster Gear And Sprocket Kit 41c4220a Chamberlain ...
    www.sears.com/search=liftmaster%20gear%20and%20sprocket%20...
    Searsmore info. + -. Chamberlain LiftMaster 41C4220A Gear & Sprocket Assembly Kit. $31.40 ... Chamberlain Sears Craftsman Liftmaster 41A2817 Gear Kit. $27.65 ...
Jan 10, 2016 | Sears Craftsman LiftMaster Chamberlain...
Garage door has a dirty grease mark down middle of door as if chain or something is rubbing on it.as it opens. When I watch it opens it appears that nothing is even coming close to door as it opens and...
When the door is opening the chain on one side of the rail is pulled tight and the opposite side sags. It is just the opposite when the door is closing. It could be the sagging side is rubbing against the door but it seems you would have seen this. Also the chain shouldn't have grease on it. Just a light coat of lubricant from the factory. You might try tightening the chain just a tad.
Nov 11, 2010 | Sears Craftsman LiftMaster Chamberlain...
I press the button to close the door and i hear a click at the motor and nothing happens
Check to see if the trolley is jammed against the bolt just in front of the motor unit. If so, loosen the chain enough to take the strain off the chain and run the motor until the door is closed. While the door is closed locate the 'up limit' control on the side of the motor unit. Turn this 2 full turns in the opposite direction of the arrow printed on the cover. Tighten the chain.
Nov 02, 2010 | Sears Craftsman LiftMaster Chamberlain...
I just installed a craftsman garage door opener and the chain is sagging on one side and super tight on the other. When opening the door, the chain sags on both sides. I have tried tightening the nuts on...
When the door is opening the chain will be tight on one side and slack on the other. When it is closing it will be just the opposite. It is important that you do not over tighten the chain. I suppose the wrong chain could be shipped with the opener but it wouldn't be common.
Jul 29, 2010 | Sears Craftsman LiftMaster Chamberlain...
Liftmaster Garage Door Won't Close
Sounds like maybe the door traveled too far and the trolley has jammed against the bolt just in front of the motor. If so, loosen the chain enough to take the tension off the chain and then run the opener until the door closes. While the door is closed locate the 'up limit' control on the side of the motor unit and turn it 2 full turns in the opposite direction of the arrow printed on the cover. Tighten the chain.
May 27, 2010 | Sears Craftsman LiftMaster Chamberlain...
I am having a problem with my garage door opener. It just clicks. Its a craftsman opener. The lights are on but it does not move when the button is pressed.
If your door is stuck in the open position it is probably because the trolley is jammed against the bolt just in front of the motor. If so, loosen the chain enough to release the pressure on the trolley and run the opener until the door is closed. With the door closed locate the 'up limit' control on the side of the motor unit and turn this control 2 full turns in the opposite direction of the arrow printed on the cover. Tighten the chain.
Apr 06, 2010 | Sears Craftsman LiftMaster Chamberlain...
My older Craftsman garage door opener comes down about 6" & then goes back up. I just replaced all the rollers o& the opener worked fine. Then I tightened the chain on the opener & it worked ok...
If the main light flashes 10 times when the door goes back up it is a door sensor problem. You chain should sag just a little. If you tighten it too much it will click as it goes over the sprocket. You can increase the down force which is an adjustment near where all those white wires go. A 1/4 turn should be enough. Release the door from the opener and operate it by hand. It should move freely and when you have the door approximately waist high it should stay put. Neither raising nor closing.
Jan 11, 2010 | Sears Craftsman LiftMaster Chamberlain...
My i/2 hp crafstman chain drive opener stops about a foot from the floor i got it up and noticed the chain was sagging about a foot below the bar how dow I tighten the chain
The adjustment for the chain is on the trolley. That is the part the chain and the door are connected to. Your chain is sagging entirely too much. Have you done any other work to this opener?
Oct 30, 2009 | Sears Craftsman LiftMaster Chamberlain...
Garage door chain is sagging
If the chain is adjusted properly the chain will sag slightly on one side when the door is closed and on the other side when it is open. It should not sag enough that it is dragging on the T-rail. You can adjust it at the trolley. If you over tighten it you will hear a clicking sound when the opener opens or closes.
Jul 28, 2009 | Sears Craftsman LiftMaster Chamberlain...
I have a craftsman garage door opener and the chain came off trac
YES - YOU ALSO NEED TO BE SURE IT IS IN THE CORRECT POSITION WHEN YOU REINSTALL IT.
MOVE THE TRAVELER / TROLLEY TO THE CLOSED POSITION RUN THE OPENER TO THE CLOSED POSITION. LOOSEN CHAIN AND REINSTALL.
TIGTHEN CHAIN ONLY ENOUGH TO KEEP IT FROM SAGGING BELOW THE RAIL. (TOO TIGHT WILL RUIN THE BUSHINGS ON THE DRIVE).
NOTE; THE BUSHINGS MAY BE BAD THIS WOULD CAUSE THE CHAIN TO COME OFF OR SAG TOO FAR, LOOK FOR EXCESSIVE PLAY IN THE BUSHING UNDER THE CHAIN SPROCKET.
IF IT IS BAD A KIT IS AVAILABLE TO REPAIR.
HOPE THIS HELPS
Mar 22, 2009 | Sears Craftsman LiftMaster Chamberlain...
Sears Craftsman LiftMaster Chamberlain Garage Door Opener Wireless Keypad Model 976LM Security+ Logo
1,085 people viewed this question
Top Sears Building Materials Experts
Mike
Steve Allison
Steve Allison
Are you a Sears Building Material Expert? Answer questions, earn points and help others
