Question about Toshiba Satellite M45-S351 Notebook
Backlight turns off after a minute or two. I can push down the tab at the front of the case where the lock is and it turns back on. Is there a fix for this?
    Novelist:
    Champion:
  • 226 Answers
It sounds like there is a loose connection in the area you apply pressure to. If you are confident enough you could open the machine an inspect that area. Any cables you see in that area should be disconnected and then reconnected and taped in place using an insulating tape.
Hope this helps,
www.PuterCare.com
Posted on Jul 14, 2010
Need to remove a glove box lock from a 78 chev corvette
if you can open the door, there is a small 'window' on the case inside the glove box. With a pointed tool (paper clip?) there is a tab you need to push in through the window. While holding the tab down, spin the cylinder to remove. If it is a locking cylinder, while pushing the tab down, insert the key. This will hold the tab down. Then you can turn the cylinder to remove it.
Aug 31, 2014 | 1978 Chevrolet Corvette
Tail light is burned out on tail light. I have the bulbs but can't figure out how to remove and replace burned out light.
  1. Check with your local auto parts store or look in your owner's manual to find the proper model number of the replacement tail light globe.
  2. Open your trunk or lift your hatchback. Find the cover just on the inside of your vehicle next to the burnt-out bulb.
  3. Turn the two latches counterclockwise to open them so the cover may be removed. In most cases you can turn the latches with your fingers; in some cases you may need a coin or a slot screwdriver to turn them. Remove the cover.
  4. Press the tabs that allow you to remove the tray that holds the tail light globes. There are four tabs on most VW models. Each tab must be depressed to release the tray. Pull the tray out a few inches, as far as the wiring allows.
  5. Press down slightly on the burned-out globe and turn it counterclockwise with your thumb and fingers. It should release easily and then pull straight out. Push the replacement bulb in and turn it clockwise until it locks in place.
  6. Snap the tail light tray back in place. The tray should simply push back into place and the four tabs should "snap" into their locked position. Replace the door cover and turn the door locks clockwise. Test your bulb to see that it is working.
Good Luck
Nov 20, 2010 | 2004 Volkswagen Beetle
I am having problems locating the front screws/tabs needed to remove the cover of the Canon PIXMA iP4300
There are two tabs on the front. They are nothing like the other four and there are no arrows to indicate where they are.
Turn the computer up on its back so you can access the front tabs from underneath.
Get a good flashlight and look up the deep, rectangular recesses so you can see which two have the little plastic piece holding the case down. With a normal screwdriver, push the little tabs toward the sides. If the other four tabs have already been popped, the whole case will pull away easily.
Sep 08, 2010 | Canon PIXMA iP4300 InkJet Photo Printer
How to dismantle a jacuzzi magnum pool filter pump 1228
When you go to loosten the lock ring you will need to find the lock tab that will keep it from comming off. This tab I think will pull out but it may push in and this will free the ring to turn. Once this is off if the motor runs turn it on for a second and let it push the front and back half apart. If it won't run you can use a flush bag to pressure it off. In worst case you can pry the halvs apart with a big screwdriver. If you do this be careful not to hurt the case of the pump it is just plastic.
When the pump is opener you remove the difusser and look inside the impeller. If you have a screw in the center of the impeller it will be a left hand thread so to remove you will turn it clockwise. Now just unscrew the impeller turning it counter clockwise and take the rear plate off the motor by removing the four bolts on the back. Good luck.
Sep 03, 2010 | Jacuzzi MAGNUM POOL PUMP 1-1/2 HP MAGNUM...
Can anyone tell me a way to get the back off a htc tattoo Ive had it off once to charge the battery but can't get it off again
The instructions on the internet were half right. The actual tabs that lock the back into place are at the top of the rear case, not the bottom. I pushed like hell following the instruction manual online, and it was no good. In the end I managed to manipulate the top of the rear case to open it. It is not easy, and should have been designed easier that it is. Just had another go. Push the front down at the top, while pushing the back up at the top. It worked first time this time! Best of luck to All. :)
Feb 23, 2010 | HTC Tattoo Cell Phone
Error code 010-397 dell printer 5100. Have change fuser and restart printer keeps coming up as error message
) The fuser gets very Hot!! Let cool for 10 minutes after turning off the power and unplugging the copier!
2) Pull the two blue locking tabs forward and remove the fuser unit. Reinsert and push back on the tabs to lock back into place. Sometimes just reinserting the fuser will allow the catch on the locking tab to function correctly and push the trigger on the sensing unit. Turn the copier back on and pray the error code doesn't reappear..
3) Mine reappeared. Evidently the catch on the fuser unit was still not pushing the trigger forward, causing the copier to surmise that no fuser unit was installed.
CBR Tech Solutions or http://www.cbrtechsolutions.com
Oct 14, 2009 | Dell 5100cn Laser Printer
My camera is locking my memory card. I slide the lever on the memory card to unlocked, which is down, and when i insert it in the phone and push it down to lock it in, it pushes the 'lock' on the memory...
I have had a similar problem with flimsy lock tabs. I solved it by placing a small amount of scotch tape over the tab - starting near the connection pads, over the tab to the back edge of the card. There's usually not a whole lot of extra room in the slot, so insert carefully and remove portions of tape as needed.
Worst case scenario - if you never use the locking tab (I never do) you could place a small dab of super glue to hold it in place. Let it "set up" before reinserting - you don't want the tab to move an be held on the lock position.
Sep 18, 2009 | Casio Exilim Zoom EX-Z80 Digital Camera
Everytime the backlight would die out, and i push the back button to call or something, it always tell me to unlock it. how do i fix it to where i dont have to keep doing it?
Hey (:
It's just the autokeyguard.
it you push back (like hold it for a while) it'll go
to the main part.
if you want to turn that off..
go to settings
and go down until you find the
autokey guard part.
and turn it off.
now it won't auto lock itself!
Hope this helped!
-Selena
Jun 04, 2009 | LG RUMOR Cellular Phone
Load Staples in a Canon ImageRunner 2200
First step, have staple cartridge on hand, type J1 for the iR2200.
Open the front cover of the finisher, which is the door directly below the control panel, which opens from left to right.
There's a handle to grab on the front right corner where the paper comes out, pull it out all the way.
This will expose that module's back right corner where the green staple holder handle is.
With thumb and forefinger, reach in, take hold and lift up and pull out the staple case by its green tab.
You'll see "push" on the sides of the staple case, squeeze thumb and forefinger, one on each "push" sign, and the top will spring up, which is the clear plastic case through which you can see a large spring. Pull out the staple cartridge from the back, under the green tab.
Put the new cartridge in with the orange seal tape hanging out the back.
Press down on the spring-loaded case until it clicks into place again.
Remove the orange seal tab by pulling straight back, then down, not at an angle, as you don't want it to break, just to come off.
Holding it by the green tab, lower the staple case back into the finisher until it settles snugly into place.
Hope that helps!
Feb 09, 2009 | Canon imageRUNNER 2870 Copier
Series Back Light
It is possible that by holding the power button down too long, that you turned off the backlight. When you hold down the power button, a menu eventually comes up with "Backlight Off" highlighted. The easiest way to undo this, is to simply do a soft reset. Or, you can hold down the power button again, and "Backlight On" will be highlighted (if there's enough ambient light you can see this message); just tap it, and the backlight will come on again. Also check out your backlight settings by tapping: [Start][Settings]tab[System][Backlight] the tab [Battery Power] should be highlighted; adjust as desired. Next tap the tab [External Power]; adjust as desired. Finally, tap the tab [Brightness] and make sure the sliders are high enough.
Sep 07, 2005 | HP iPAQ H6300 Pocket PC
Toshiba Satellite M45-S351 Notebook Logo
51 people viewed this question
Top Toshiba Computers & Internet Experts
Are you a Toshiba Computer and Internet Expert? Answer questions, earn points and help others
