Question about Nintendo DS Lite Console
My DS's top half has broken off, along with a black wire on the left side and the golden film, the white wire has not been broken though, what should i do?
  • 206 Answers
The only thing that you can try to d is calling the manufacturer and ask if you can get a replacement because there are not alot of things to do with damage like that
hope i could help !
Posted on Jul 15, 2010
How to fix half of a ds without screwdriver nor black and white whire
First, learn to communicate better. Your issue is indistinct and your question is unclear. Proper communication skills are necessary, especially when trying to troubleshoot technical issues. If you are no more capable of communicating in writing than what you wrote, just give up.
Second, BUY A SCREWDRIVER.
Jul 20, 2014 | Nintendo DS Lite Console
Ds goes black and white
Hi Tristan,
Does the ds still turn on, which hinge is broken? Left,right or both as you open the lid?(very carefully though if you damage the ribbon cable for the top screen it'll need replacing for sure.
Jul 31, 2012 | Nintendo DS Lite Console
I took my toshiba sat. 1415 apart. i have two wires, 1 black, 1 white with little round ends. they go from top half threw a hole to the bottom half at the top right corner. what does these wires connect...
They connect to the wireless card. If you flip the laptop on its back so the bottom is up and the front of the laptop is towards you, the wireless card access door is to the back of the laptop on the left side. It has a single screw holding the door in place. The little sockets on the card should have a small black and a small white triangle by each socket. That is where you clip the wires to. I believe the white cable connects to the left and black to the right. Below is an illustration of the card in the slot with the wires connected.
Aug 01, 2010 | Computers & Internet
Scanner error 5
Try this one open up the scanning lid, use a small allen wrench and pull the screw at the left side of the frame that holds a 1 inch wide by 12 inch long piece of glass. pot ur finger inside the housing and begin to roll the gear/rubber belt to move the scanner bulb assembly towards the left side as far as you can go. Then, turn the machine off and on.
If you are adept at printer repair, remove the right side cover, by removing the two screws in the hand hold area. pull the cover out at the bottom, using the handhold area, it will pop quite loudly. Once you get the cover off, you will find a large sheetmetal box with a row of connectors across the top of the circuit board. You do not need to remove the sheetmetal box to access the connector I am referring to. The four wire bundle I'm referring to has black, yellow, blue and red wires going to it. It's pretty much in the center of the row of connectors Be sure it is secure.
If the connector is securely inserted and no pinched wires are observed, the next most likely cause for this issue is a calibration stip for the scanner head inside of the scanner top. There are no spare parts for that level of repair. Opening the scanner top to repair it is likely to let in dust or debris and you won't find much that can be done if the calibration strip has moved or delaminated. The scanner top will need to be replaced. I believe the part number for the scanner top is Q3948-60191 unless it's been replaced with a newer part number.
that shud work if it doest contact hp....
good luck
Jul 12, 2009 | HP LaserJet 2820 Printer
Nintendo DS Original snapped in half
if you can't glue it to gether then go find your receipt and go to the store and buy a new one
Apr 21, 2009 | Nintendo DS Lite Console
Broken in half got new shell don't know how to put together
much of it is pretty straight forward, the only hard part is putting the ribbon cable thru the hinge for the top screen, without ripping it, best thing to say is put the ribbon cable in first, then the wifi and mic cables (black and white), rest is pretty straightforward.
Apr 17, 2009 | Nintendo DS Lite Console
Broken on the bottom
If you call nintendo or go to their website they will repair it or send you a new one if it is under warranty.
here is the nintendo link:
http://www.nintendo.com/consumer/systems/selectds.jsp
Aug 29, 2008 | Nintendo DS Lite Console
DS broken in half
I recommend you to change the broken case, you can choose to change only the hinge and keep the good case parts or change the entire shell. By the way stores usually sell the entire shell so you can choose. As your screens are still working you are lucky because so often the brown flexible conductor to the top screen get broken so be careful.
You can also use a silicon or hard plastic case to put over your broken NDSL to keep it in place just as the fast non technical option.
Here are some links and you can find text and video guides googling around.
Shells in ebay
Other stores items
Good Luck...
Nov 09, 2007 | Nintendo DS Lite Console
DS power problem
Hi Nerts,
These cables or ribbon cable and wire connects directly inside the upper LCD monitor. it is not feasible to replace these wires only.  I suggest you see about getting a replacement upper LCD screen which will give you the wires you need and a new screen to boot. Another porblem is the case itself is very hard to disassemble.  You will come near destroying the case to ge to the lcd.  You must disassemble the unit fully and put the correct curl in the ribbon cable to get it to fit right. In short, the price being what it is for a replacement LCD, and the trouble you have to go though to get this problem fixed, It may not be totally worth repairing. If you dont care and wish to do a repair, then my wishes for luck are with you.
Oct 18, 2007 | Nintendo DS Console
Nintendo DS Lite Console Logo
136 people viewed this question
Top Nintendo Video Game Consoles & Games Experts
Bee Santiago
Raj Patel
Martin Murray
Are you a Nintendo Video Game Console and Game Expert? Answer questions, earn points and help others
